Question about Boating
Evinrude 25 pk 2 stroke 2cyl outbord boatmotor
Hi ,
i have the problem that my 2 cylinders evinrude boatengine is only working on 1 cyl after approx 10 to 15 min on sea.
When i release the trottle then (sometimes) the second cylinder is catching up again and keep on working when i stay below a certain rpm.
I have changed the 2 spark plugs and then it works again on 2 cylinders, but again after approx 10-15 minutes the 2nd cylinder is again giving up... i think it is a combined problem, unless i use the wrong sparkplugs. I have now the Champion L85 short spark plugs. Starting the engine (manual) is no problem, even when working on 1 cylinder.
I have technical education and can do a lot myself, i only need suggestions.
I have tested the spark plugs when not fitted into the engine to check the spark and i have the impression that the little spark of one cylinder is white and i think it should be blue.
Thanks anyway for some advice.
  • Anonymous Mar 14, 2014
    new starter,solenoid,coils,powerpack,plugs snd plug wires. using fresh gas out of portable gas tank. motor turns over good and grtting both fuel and spark to cylinder but wii\ll not start.any ideas on this would be a great help
    Scholar:
  • 157 Answers
Hello enjoy42. From the information you have provided I would lean to the weak cylinder coil. Unplug the good spark plug wire & test run the engine on the weak cylinder. You could go to swapping the coils on the cylinders. Check your wiring terminals on the coils. Check with a marine dealer for the correct plug. I owned a 35 Evinrude on a Bass boat & it would out run my buddys 40 Mercury. Good Fishing.
Posted on Oct 03, 2008
How do i fit a rectifier to a 2013 25hp evinrude 2 stroke???? Rectifier-4wires-2go battery & 2 go AC lighting coil system. Need to identify were to connect my 2 coloured wires from rectifier????
This is what Johnson say;
Technical Contact Information
We Take Your Boating Pleasure Seriously!
Your selling dealer has a special interest in your satisfaction and should be consulted first if you have any concerns about your Johnson power product. Your authorized Evinrude dealer is your primary contact for service, product information, and Evinrude and Johnson® Genuine Parts.
Protect your investment. Please read your owners manual for all operation and maintenance information for your engine. It lists all the adjustments and routine maintenance procedures for your motor, including off-season storage and pre-season service. We encourage you to work with your authorized Evinrude dealer for all the services you require.
If you have a concern with your engine that your dealer is unable to resolve, please have your engine model number and serial number available, and contact us.
Ta
Take a look at these videos though.
https://www.google.ca/search?q=25+hp+evinrude+2+stroke+rectifier&rls=com.microsoft:en-US:IE-ContextMenu&source=lnms&tbm=vid&sa=X&ved=0ahUKEwjVu_XQ2ZnLAhVMQCYKHbMwBnoQ_AUICCgC&biw=1600&bih=729
25 hp evinrude 2 stroke rectifier Google Search
Feb 28, 2016 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
What is the idle timing for 1993 90hp evinrude
90 hp 1993 evinrude idle speed - MarineEngine
www.marineengine.com > ... > Johnson Evinrude Outboard Archive
Aug 3, 2008 - 2 posts - ‎2 authors
"How many rpm should the engine idle at,and where and how do you adjust it Thanks" 50 hp evinrude no idle and no top speed need assistance ...
Jul 6, 2013
1993 50 HP 2 cyl Evinrude stalls, runs at idle when ...
May 7, 2012
adjust carburators and idle speed 1993 48hp
Jul 29, 2010
90 hp stalls when going in gear
May 21, 2010
More results from www.marineengine.com
1993 Johnson 90-HP Runs Only At Idle Speed On Spring Start-Up
Johnson 1993 115 xflow Link and Sync - YouTube? 4:55https://www.youtube.com/watch?v=ReeuaVh8uZQNov 25, 2012 - Uploaded by Brian O'DellJohnson 1993 115 xflow Link and Sync. Brian O' ... Also if you can give me some details on how you got the ...DOWNLOAD Evinrude 90HP (90 HP) Repair Manual
Dec 14, 2015 | Boating
I have a 1998 model E25RMECA I NEED TO KNOW WHAT TYPE GAS TO USE IN IT. AND IF IT IS 2 CYCLE OR 4CYCLE.
I found a mixture of sites for the information
one owner of a 1998 25 hp evinrude says that it is a 2 stroke with a fuel mix ratio of 50:1 as 25:1 is a bit smokey
another site says that the recommended octane fuel rating is 87 although it might run better on 91
best advice is to find an evinrude service dealer and get the right information as the later 25 hp units are etec engine which will be 4 strokes
Oct 23, 2015 | Clymer Evinrude/Johnson 5-70 Hp...
Evinrude outboards
Johnson and Evinrude carbureted 2-stroke outboards since 1964 require a 50:1 fuel to oil mixture (2%) on engines without an automatic oiling system - 6 gallons of gas to 1 pint of outboard oil.
Aug 30, 2014 | Garden
Hi , i have an evinrude lightwin 3hp 1969, water does not circulate and the outbord is overheating !
2 CRITICAL THINGS:
1. Replace Thermostat
2. Replace Water Pump:IMPELLER, CUP, PLATE(IF APPLICABLE) SEALS & GASKETS
***ALSO: MAKE SURE DISCHARGE AND INTAKE PASSAGES ARE CLEAR
Jul 25, 2013 | Boating
How do i replace the water pump in a 2005 150 hp evinrude outboard motor
Take the cowling off. Also drop the foot. There wil be a stainless linkage rod that runs the length of the motor that you will have undo to drop the foot. The water impeller will be inside a stainless casing that you will have to disassemble.
Aug 17, 2012 | Boating
I have no spark on 1989 7.5 evinrude outboard motor
Hi have you tried it with the stop switchl/button disconnected, if so you have only got the stator under the flywheel left to replace, regards Phil.
Jun 04, 2012 | Boating
1991 EVINRUDE 25 HP 2CYL 2CYCLE IT RUNS ON BOTTOM
get a spark tester that has 2 leads and test spark .
Jan 26, 2010 | Light Outboard Motor Boat Bass Fishing...
Boating Logo
414 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
