Question about Samsung SGH-U600
Replacing the lcd screen on u700
How do i remove the lcd screen to replace it on my u700. i havs stripped the phone down but the last ribbon cable goes into the front casing to the wheel and i cant figure out how to remove it.
  • Anonymous Jan 21, 2009
    my lcd turns off when i slide up my phone but it turns on when i slide down again
Open the back side and pour somd medi sprit right over lcd screen and close all problems is solved
Posted on Oct 02, 2008
Blank screen after putting in a new LCD
did the ribbon cable stay connected during reassembly? these are difficult to work on.
Mar 12, 2014 | Samsung Exhibit 2 Smartphone
In my P1I touch screen not working? how to rectify?
just try this.. enter service menu by pressing jog dial up, *, jog dial down, jog dial down, *, jog dial down, *.
jog dial is rounded things at the right side of the p1, slide it up or down, follow the instruction.
then enter the menu hardware test, lcd test, write something in ur touch pad, if the letter u wrote visible it mean ur lcd fine.. so , just close the menu and its magic.... its worked.
Apr 27, 2010 | Sony Ericsson P1i
I lost the sensitivity because of some moisture formed inside the screen.. How much it costs to replace the screen?
Hi,before replacing the screen,why don't you dry out the LCD screen to get rid of the moisture,you can use a hand dryer to dry out the moisture of the screen after taking it out.If after drying the screen the problem remains,then you can go ahead to get a new screen.
Here is a detailed step on how to dissassemble your P1i;
STEP 1 Tools required: Torx 6 screwdriver, Phillips size 0 screwdriver
  • First remove the battery cover, battery, memory card and stylus. Remove the three screws you see
STEP 2 Run your fingernail around the join of the back cover and then pry the back cover off
STEP 3 Now remove the two screws you can see at the top of the phone
STEP 4
  • Now run your fingernail along the join of the front cover and you'll hear the clips, which hold the cover on, click. The front cover is on quite tight so use some force to pry the cover off
STEP 5 Remove the keypad and lift the part underneath from right to left, this will reveal two more screws. Remove these screws
STEP 6 Remove the metal plate that the screws were holding in place and you now have access to the ribbon which attaches the screen to the circuit board
STEP 7
  • Detach the ribbon to remove the LCD screen. The ribbon attaches like a plug and socket. Simply lift the ribbon up away from the circuit board to detach it
STEP 8 You have now removed the LCD screen then you dry, Reverse the whole process to reassemble. However,the LCD screen costs $92.if you have the reason to purchase it.
Thanks and take care
Apr 22, 2010 | Sony Ericsson P1i
Screen Problems
hi,i bet that you really need the LCD and touch sreen for your PDA,as you wrote a lot for the problem of your PDA.If you need LCD replacement.pls go to www.keyuda-lcd.com
i think it will be helpful for you.
KIM
MSN/EMAIL:kingyijin@hotmail.com
Mar 16, 2009 | HP iPAQ HX4700 Pocket PC
Help please.,
There is no sure way to know if the problem is the cable without taking apart the phone, and testing or replaceiong parts.
How ever, if your screen goes blank when you touch the cable, then the problem is either the ribbon cable, or the screen itself that has a broken connector, or in rare cases the connetor on the small board.
Check first if the cable is not just misplaced in the connector, and eventually adjust it.
Replace the cable, that cost a couple of dollars. If you still get the problem replace the LCD display.
Oct 28, 2008 | Nokia 3230
Ppc 6670
You just need the touch screen (digitizer). There are actually 2 pieces that are mistaken to be the screen. The other piece is the touch screen and beneath that is the LCD display. Be certain to order the correct piece.
To replace, you need a micro phillips head screw driver and a T-6 torx screw driver. Also patience, and a steady hand.
You must start at the back of the device, through the battery door. Remove the 2 micro phillips at the top of the battery opening (one is covered with a tamper evidence sticker). Then carefully, starting at the bottom of the camera plate, pry upwards and to the speaker to unsnap the smaller facing. Remove the camera by gentally pulling up to unplug, then unscrew the circuitry and remove. This will expose the 4 torxs (2 in batt opening) to remove the back cover. After screws are removed, gentally work the covers snaps loose around perimeter and remove (pay attention to the speaker wire) unplug it from the circuitboard. Pull the antenna nub to detach.
Remove the screws holding the circuitboard, unpluging the keyboard and slider ribbon cable. Gentally hold the ribbon cable and remove the securing tape. (dont pull too hard!) Pulling the circuitboard exposes the 4 micro phillips screws (2 each side) to detach the slider.
Remove the 4 torx screws on the back of the LCD slider, then gentally pry around to separate the housing.
To remove the LCD / Touch screen you must unplug the ribbon cables. To do this you need to open the connector's trap (black bar). It hinges. Just pry upwards from the ribbon side. Once bar is lifted ribbon will slide out. Be careful if you need to remove the gold foil tape. Remove the single screw holding the ear speaker, and the ribbon should come out. The screen will not come out after gentally prying it free of the holding snaps in the casing.
Installation is simply the reserve. Hope this helps....
Jul 03, 2008 | Audiovox PPC 6700
Dash screen will go white.
For me, the problem was definitely the ribbon connector between the graphics chip and LCD. The YouTube video below describes how to open the dash. You only need to open the device (i.e. no need to take out the printed circuit board) and then you should re-seat the ribbon cable in the lower left hand corner back onto the PCB. Hardest part was finding a #6 torx screwdriver.
Jan 09, 2008 | T-Mobile Dash Smartphone
Scratched audiovox screen
You just need the touch screen (digitizer). There are actually 2 pieces that are mistaken to be the screen. The other piece is the touch screen and beneath that is the LCD display. The outer scratched screen is the touch screen.
Ebay, and various online retailers have them for around $40. You can do it yourself if you try.
Dec 07, 2007 | Audiovox PPC 6700
700w lcd replacement now is black screen
Yes, most likely you have missed the proper technique of installing the ribbon strips correctly into the connection block.
I did the same thing and it took me three tries to get it right... I stumbled on this by playing with other ribbon strips on the phone that I could access better and found that there is some sort of “step” or “threshold” inside of the connection block that makes you feel like to have "seated" the ribbon strip at the bottom of the block when in fact you have to push harder to actually push the ribbon into the block fully and make contact with the connectors, and then snap the locking bar down.
It's an easy mistake to make since the connection block and ribbon strip for the screen are hard to get hold of with your fingers... try using some tweezers or small long nose pliers to hold the ribbon and seat it fully.
Now I still am trying to figure out how to unlock and install the touch screen ribbon into the connection block… it’s really small and does not seem to what to unlock to allow for a full installation of the really small ribbon strip and lock it in, so I used a piece of duct tape to hold it in place and it works fine… not my perfect fix on this one, but my ph works…
Robert R.
Oct 03, 2007 | Palm Treo 700w Smartphone
Samsung SGH-U600 Logo
91 people viewed this question
Top Samsung Computers & Internet Experts
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
