Question about LG 42PX5D 42 in. Plasma HDTV
No signal recieved
Display on tv with 5 minute countdown
I am getting a "no signal" across the the screen of my 42lg30 TV
Posted on Nov 26, 2008
Brush Cleaning did not clear the (L / R) HPR> 45F (7C) AFTER 1 HR fault on my Taylor Model C723 soft serve ice cream freezer.
Certain conditions must be met. The machine needs to be empty. The freezer door must be off the machine. The power switch must be off. Once the machine is off, a 5 minute countdown will show. It will also show 4 temperature readings. All 4 of them must be above 60 degrees F. before the countdown will start. Once the counter reaches zero, the Brush Clean Cycle will be reset along with any temperature vs. time error codes. If at any time, one of the temp readings drop below 60 degrees F. before the end of the 5 minute countdown, the countdown will reset to 5 minutes and the machine will not reset. Generally, the freezing cylinders take longer to come to temperature. Even when you run warm water through it first, there is sometimes enough residual cold to bring the temperature back below 60. A successful Brush clean Cycle will display "Power Switch Off---Unit Cleaned" and the 2 digit green display under the main display will reset to 00. if this happens and you turn the machine back on and you are hit with the same message then you may have an issue with one of your boards.
Aug 02, 2017 | Taylor Ice Cream Makers
We have just got a second hand Taylor c723 machine and it keeps saying freezer locked. Any ideas
Empty the machine, clean it out. Remove the freezer door assembly, shut the machine off. it should display a 5 minute timer and 4 temp readings. All 4 of the temp readings need to be above 60 degrees F. for the counter to start. Once it reaches zero, the machine will reset and you should be good to go. If successful the machine will display "Power Switch Off---Unit Cleaned". if at any point during the 5 minute countdown, one of the temp readings drops below 60, the countdown will reset to 5 minutes and the machine will stay freezer locked.
Apr 13, 2017 | Taylor Ice Cream Makers
Model ESL 499. Why doesn't it start?
You have activated the delayed start function. Please read following instruction from user manual.
8. Delayed Start button
Allows the start of the programme to be delayed by a minimum of 1 hour, up to 9 hours. How to set the delayed start When the button is pressed, the number appears in the display (4). Press the button again to select the number of hours by which you wish to delay the programme start, up to a maximum of 9. E.g.: if you have selected number , the wash programme will start in 2 hours' time. To cancel the delayed start set, press the button until the number appears. Close the dishwasher door to start the countdown: a long audible signal (about one second) informs you that the function is active. If you open the door again you will see, in the display (4), how long there is to go (in hours) before the programme starts. A flashing dot in the digital display means that the delayed start function has been activated. Opening the door has no effect on a countdown which has already been started. If, during the countdown, you wish to see the programme number selected in the display, press the Programme Selector button (5). If, after having started the countdown by closing the dishwasher door, you wish to cancel the delayed start, press button (9) (Cancel) for about 2 seconds until the short «instruction accepted «signal is heard».
Sep 16, 2015 | Electrolux Dishwashers
Set clock and be able to tell am from pm setting
The Clock uses a 12-hour cycle with a.m. and p.m.
1. Check that the oven is off.
2. Press CLOCK.
3. Press TEMP/TIME "+" or "-" arrow pads to set the time of day, including a.m. or p.m.
4. Press CLOCK or START
The Timer can be set in hours or minutes up to 12 hours and 59 minutes.
1. Press TIMER.
2. Press TEMP/TIME "+" or "-" arrow pads to set the length of time.
3. Press START to begin the countdown. If enabled, end-of-cycle tones will sound at end of countdown.
4. Press TIMER twice to cancel the Timer. Do not press the CANCEL/OFF keypad because the oven will turn off.
5. If the TIMER is running, but not in the display, press TIMER to display the countdown for 5 seconds
Delay Start:
The Start Time keypad is used to enter the starting time for an oven function with a delayed start.
Hope this answers all you questions about your stove.
Nov 04, 2013 | Whirlpool RF263LXTQ Range
After turning on the computer (Apple CUBE MacOS 9.1) the vision of the monitor is normal but after a few seconds a screen with a window countdown will start automatically and reads "signal ing"...
you may try this came from manual.
Power Management" "countdown 20 sec
This OSD may appear to inform you that the signal being sent to the display is not within its frequency range. In this case, you would need to check the resolution and refresh rate you have your video card set to, and adjust to be within the range of the display
Sep 09, 2011 | LG Flatron L1510S 15" LCD Monitor
TV comes on but will not recieve channel. It displays no signal & the code65535. The cable is working here so it is in the TV. It is a 37" dynex flat screen bought 2 yrs plus 4 months.
Try the resetting the TV. To do this unplug the power chord from power socket, and wait for atleast 45 minute. TV will reset itself. The try to get signals.
If your TV receive poor quality telivision signals, captioning may contain errors, or there might be no captioning at all. Some possible reasons for poor quality are automobile ignition noise, electic motor noise, weak signal reception or multiplex signal reception like ghosts etc.
If reset also didn't help you, the tuner inside your TV is defective, or weak. It should be replaced with same type and number. OK.
Mar 27, 2011 | Dynex DX-LCD37 TV
I have tried re-tuning my mums tv but all I get now is no signal with a countdown from 5 minutes before it switches off. I have tried going back into menu then settings etc but I'm not getting this come...
It sounds like you are not getting a signal from your antenna connection. Check the cable & connector which goes into the back aerial connection of the TV. It will switch off after 5 minutes because it is not receiving a signal & if you are getting the menu box then the TV is working ok.
Oct 07, 2009 | Televison & Video
WD 57733 picture color problem
Good Day;
Try resetting both devices TV & BOX, unplugg power for 2 to 5 minutes then plug back in.
good Luck, big IRISH.
Sep 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
LG 42PX5D 42 in. Plasma HDTV Logo
115 people viewed this question
Computer Repairing
Computer Repairing
