Question about Samsung ML 1610 Laser Printer
Black ink smudges
When I print a document with a black title border this then smudges on to the next pages. Any suggestions?
    Problem Solver:
  • 8 Answers
If this is within the return policy at the store where you bought it, exchange for a new one,
it maybe the fuser is defective or not getting hot enough.
Posted on Oct 04, 2008
  • cableguys Oct 04, 2008
    or even something wrong with the toner it self
I have an Epson Stylus DX4850 when i print a document it prints black verticle lines on the back of document.
if you are using a word document to open it on the top select the format tab open it
borders and shadings at the top you wil lsee list of options borders ,page borders and shading across on the left panel select NONE do this for all options
in the preview tab you will see what lines and shadings are on the document
around the edge of the preview panel will be 4 small boxes with lines on the outside of each box make sure none are selected
at the bottom you will see
Apply to with a drop down list with paragraph and a text option make sure paragraph is selected
you can always go back to make sure that NONE is selected
hope this helps
Sep 28, 2011 | Epson Stylus DX4850 All-In-One InkJet...
My dcp165c printer print quality prints black & yellow colour. i clean print head through maintance 76 but problem cannot be solved
How is the printer printing black and yellow color? Is it a smudge?
When I print, the pages are smudged with ink. What should I do?
Description:
- If smudged stains appear at the top center of the printed page:
  • Make sure the paper is not too thick or curled.
    Also, verify that the appropriate paper is being used and that the paper type set in the machine matches the media used.
  • Make sure the paper is not curled when you print on the back side of the paper with the Print Odd Pages and Print Even Pages settings.
- If smudged stains appear at the right or left corner of the printed page:
- If smudged stains appear on the reverse side or at the bottom of the page:
NOTE: Illustrations shown below are from the representative product and may differ from your Brother machine.
  • Make sure the printer platen is not dirty with ink.
    How to clean the machine's printer platen
    1. Unplug the machine from the AC power outlet.
    2. Lift the scanner cover until it locks securely in the open position.
    3. Clean the machine's printer platen(1) and the area around it, wiping off any scattered ink with a soft, dry, lint-free cloth.
    4. Close the scanner cover.
  • Make sure you are using Genuine Brother Innobella™ Ink.
    > Brother Genuine Supplies information
  • Make sure you are using the paper support flap.
    To use the paper support flap, pull out the paper support (1) until it clicks and unfold the paper support flap(2).
Aug 03, 2010 | Brother Computers & Internet
4 - black ink smudges (1/32" wide x 1/16" high) in right margin
Very nice trouble shooting. The image defect you describe point to the OPC or drum unit this is essentially the toner cart. In your case black. Measureing the distance between repetitive defects is a sure way of diagnosing problems such as yours. Again nice work.
Google repetitive defect ruler for your model to help in the future.
Hope this helps
Apr 07, 2009 | HP Color LaserJet 2600n Printer
Ink smudges on the right side of the paper
Your problem is due to a worn fuser unit (upper fuser roller).
The teflon coating has worn again, alowing the toner to stick to the roller and then "repeat" about 3x down the paper (getting fainter each time).
You need to order a new fuser unit.
Click here to go to HP direct
RM1-1083-070CN Fuser assembly - 110 VAC - For LaserJet 4250/4350 series RM1-1083-070CN Fuser assembly - 220 VAC - For LaserJet 4250/4350 series
Make sure you order the currect voltage (US or UK)
Regards
Vince.
Mar 04, 2009 | HP LaserJet 4250n Printer
Canon PIXMA MX700 printhead immediately coated with ink, smudges
It's likely that the foam pads that the print head rests on when the printer is not in use are saturated with ink. They're to the right as you look into the printer: a rectangular one for black ink and a square one for the colored ink. If you power the printer off and back on, with the cover open, you'll see where the printhead goes to rest.
The pads aren't easy to get at, but you can blot them with a paper towel. Gummy, half-dried ink dissolves in rubbing alcohol, and you can soak a paper towel or a cotton ball with alcohol and wipe down the area. I've had good luck soaking the pads with alcohol, then blotting them dry with a rag.
Feb 18, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Black and white not printing correctly, color is fine
If you are not using Epson ink, your printer will do this. Epson printers hate knock-off ink. Always use Epson ink if you want to keep your printer working properly. To solve the problem you are having, try cleaning the ink tubes. Make sure you re-install them properly. Hope this helps. Charlene
Feb 10, 2009 | Epson Stylus CX3810 All-In-One InkJet...
Black ink smudges for color print mode only, not for grayscale
- Try to reallign the cartridge, run a print test, after that if the issue still persist - uninstall and reinstall software - run test and re-allign again the cardtridge using software. run print test again.
Oct 08, 2008 | Samsung CLP 300 Laser Printer
Not printing correctly
you need to run the clean print head from the software utility or from the printer menu. you may need to run it a few times until the test pages looks good
this is common on ink jet printers, the nozzles may get clogged
Jan 07, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
Ink
There is a problem with your fuser assembly. It is not heating up enough to burn the ink onto the paper. This is usually replaced by a tech.
Sep 27, 2007 | Konica Minolta Magicolor 2530 DL Laser...
Samsung ML 1610 Laser Printer Logo
144 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
