Question about Fuji FinePix S5000 Digital Camera
Display screen is White
The display screen in my camera has gone white and takes similar pictures. I understand that the CCD has to be replaced. Where can it be done in my town which is Bhopal in madhya Pradesh in India.The camera is four years old with me.
Ashok
  • 593 Answers
Look up Fuji India, I dont believe the local camera shop has the parts.
Posted on Nov 16, 2008
My screen has gone white?
The display being white can be due to failure of the LCD or the CCD which is the optical sensor of the camera. So to confirm check the older picture to be seen on the display. Confirm this by checking the card on your PC. If the images/picture is seen to be of good quality, then the LCD can be faulty, fault on the linking cable or the control board.
However if the older images are seen well then the LCD is working correctly and the fault can be failure of the CCD- charge coupled device in the camera. If you have accidently exposed the camera directly to high intensity light / sunlight, then it is possible that it is damaged. Remove the battery and keep the camera aside to reset and try as a last resort. Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
Please click on the link for tips to replace a LCD
http://www.youtube.com/watch?v=aB4x7F5Chow
Dec 14, 2011 | Nikon COOLPIX L20 Digital Camera
White screen
that is could be the ccd imager, or the video processor ic...
hope that give you an idea
regards A.S
May 07, 2010 | Fuji FinePix S5000 Digital Camera
Wont show image in the lcd display while taking photo?
Can you more clearly what you mean "while taking photo"?If lcd not display image...is that any text or symbol in the lcd?If you can still see the symbol or text in the lcd, I think you have trouble in your lens or ccd.
Trouble in the lens usually make the lcd display white screen. And, if ccd trouble the lcd display white horisontal line and if so hard broken the lcd display black screen, but the symbol or text is shown.
Sep 20, 2009 | Canon PowerShot A75 Digital Camera
Help display camera
Try adjusting the white balance "WB" both ways, if that does not work then it could be the CCD needs replacing.
Jun 19, 2009 | General Electric A835 Digital Camera
Canon sd 1000
does it give you a lens error? are the shutter closed?
It is either the lens or the CCD.
Aug 01, 2008 | Cameras
White Vignette ('Artistic' white edge) around all photos
I sent my camera back to Fuji and they replaced the CCD free of charge. I had the same problem plus sometimes the pics just came out completely white
Jul 24, 2008 | Fuji FinePix F700 Digital Camera
My lcd screen is black
From what I can understand, if the camera is sill able take pictures but is not displaying any thing on the LCD, then it is a problem with the LCD or LCD cable connecting to rest of the camera or LCD driver on main board.
It can be as simple as a loose flexible PCB connection to the camera main board.
' + '' + google_ads[i].line1 + '
' + '' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
' + '' + google_ads[i].visible_url + '
'; } } var adsByGoogleRight = "-40px"; if(dartRecieved){ document.getElementById("ga_300x250").style.clear="both"; document.getElementById("ga_300x250").style.left = "0px"; document.getElementById("inner_adv_caption").style.display = "block"; adsByGoogleRight = "5px"; } else if(isHealthinationExist){ var healthinationBox = $('healthonationBox'); if(healthinationBox){ var helthinationBot = getObjXY(healthinationBox)[1]+healthinationBox.clientHeight; var ga_top =getObjXY(document.getElementById("ga_300x250"))[1]; if(ga_top-helthinationBot >0){ document.getElementById("ga_300x250").style.width = "530px"; } else{ document.getElementById("ga_300x250").style.width = "410px"; } } $('boxAdWrapper').style.display = "none"; } else{ document.getElementById("ga_300x250").style.width = "530px"; $('boxAdWrapper').style.display = "none"; } //add "ads by google" var logo_img = 'abg-en-100c-000000.gif'+versionno+''; s += '' + logo_img + ''; document.getElementById("ga_300x250").innerHTML = s; var currl = $('related_links'); var currq = $('related_questions'); if(currl!=null && currq!=null){ var currltop = getObjXY(currl)[1]; if(currltop > rltop ) currq.style.clear="left"; } return; }; //--> var niB = document.getElementById("niBannerID"); if(niB && niB.style.display=="block"){ document.getElementById("q_answer").style.marginTop = (niB.offsetHeight+70)+"px"; } -->
Jun 20, 2008 | Panasonic Lumix DMC-LZ2 Digital Camera
White screen
possible bad CCD imager device and or CCD imager board ribbon.Unless it got wet and corrosion is on video process area. try alamo camera service .com
May 25, 2008 | Sony Cyber-Shot DSC-S90 Digital Camera
Diplay turning white on mju 700...
Hi
Sounds like your camera was dropped and the LCD was damaged. The white screen you see is typical for a defective LCD screen. The only way to repair the camera is to replace the bad part with a known good one.
One solution would be to buy a defective camera online that has a good LCD screen and swap them out.
Good luck from Darntoothysam com
Thomas
May 01, 2008 | Olympus Stylus 700 / 700 Digital Camera
Turn on camera but the lcd sceen is black
Have you checked the display mode you're in? If you have the display set to off (to save power) and also the picture review time set to off, then you'll just see a black screen. Try pressing the 'Disp.' button below the screen when the camera is on - it should cycle through different settings with each press: Off, On, On with picture info. Similarly, in the playback mode this will show you more or less info about the picture you are viewing.
Even if the display is switched off, if you have your 'review' option in the menu set to anything other than Off (i.e. 2 seconds), then you should see the picture you've taken appear on the screen straight after taking it.
If it's not that, then I don't know the answer....
Oct 17, 2007 | Canon PowerShot S500 IXUS 500 Digital...
Fuji FinePix S5000 Digital Camera Logo
223 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
