Question about ViewSonic Computers & Internet
ViewSonic P815 VCDTS21492
Hi!
I have intermitent off/on video the screen was black and restart.
I found this problem is origined by spark gaps s671 and s371.
Wich is the function of theys? Is for prevent an over voltage?
And wich is the origin of the problem if i think is an over voltage?
If it is can i go down it? perhaps at some regulator on flyback?
or adding a resistor in order to low the exitation perhaps at base on tr driving the HT ?
Thankfully for your answers in advance
Sifliginius
PD: I found a lot of ViewSsonic different models with the same problem.
  • SIFLIGINIUS Oct 03, 2008
    Hi!
    Thanks for your answer.
    Do you have the gentless to send me the schematic for this specific
    model? Monitor ViewSonic P815 VCDTS21492-4M HV12S
    In order to take out the components that you has mentioned.
    And if its possible some theorical explication for this action,
    only for to learn, i'm only a ham electronic.
    email sifliginius@hotmail.com
  • 65 Answers
1.Remove all spark gapecapacitors at RGB cathodes and G2, G1 cathodes.
2. Remove G2 pf (G2 cathode to Ground).
3.check video section any dry points.
4. Replace boosting FET (power supply output to LOT supply)
Posted on Oct 03, 2008
What is the spark plug gap for the above car which is 4 cylinder. thanks
1988 Oldsmobile Cutlass Ciera, original GM plug gap .045".
this is what i would gap new plugs too, AC Delco Part # R44LTS plugs probably gaped at this already.
press the helpful button
How To Change Spark Plugs on 1987 Cutlass Ciera SL 3 8L
Spark Plug Gap NGK Spark Plugs Tech Video
How to Gap Spark Plug
Feb 04, 2016 | 1988 Oldsmobile Cutlass Ciera
Spark plug gap 1991 2.3 ltr
Hi
original spark plugs ( MOTORCRAFT AGPS22PP1 1.0mm gap
you can use ( CHAMPION RC8PCY 0.8mm gap
or ( NGK PFR6B-II 1.1mm gap
Note that the specs given are for euro ford 2.3 engine code E5FA
Good luck
Aug 17, 2014 | 1991 Ford Ranger Supercab
Viewsonic monitor vx2035wm goes black with a steady blue light on power button when the monitor is turned off or computer is restarted. Disconnecting it and letting it sit for a minimum of 24 hours makes...
I've been having the same problems with my Viewsonic.I plug it in and the blue light blinks but there's no picture it's just a black screen.I do know if Viewsonic doesn't repair my monitor I'll never buy anything from them again.I have the LCD Viewsonic 22' Vx2235wm monitor.
Does anyone have any idea what could be wrong with mine?I've bought a new video cable & video card but the monitor still does the same thing?Thanks
Oct 29, 2010 | ViewSonic VX2035WM LCD Monitor
Want manual for p815
here is
ftp://fvd.ru/drivers/ViewSonic/p815.pdf
Aug 11, 2010 | ViewSonic P815 21" CRT Monitor
Optiquest q20wb LCD has black screen & green power light flashing
Hi Rickyknows2,
If you are not hearing any beep I assume you are having problem with your video so, please ...
- open your PC and check whether your video card is well placed (sometimes it looks fine but you never know) remove it and put it back.
- If you used to remove often the cable from the PC, it might be that the pins from the monitor cable are even broke... please check.
- try to find another video card and replace it just to make sure its the video ...
- last... reset the bios (but I doubt that this is your problem)
chsers ..
May 03, 2010 | ViewSonic OptiQuest Monitor
Black screen
Look in the power/inverter board for bad caps with bulging top first, post back what you see inside so we can you further, see failed VIEWSOINC due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 02, 2010 | ViewSonic VX2235WM Monitor
ViewSonic P815 scren suddenly went black
either the bulb/tube has deteriorated. or long shot but happened to our old telly and that was, the power cable solder joints had worn loose.
If you feel capable of yeilding a solder gun then read on.
ANY LOOKING OR OPENING UP OF TV CASES MAY VOID ANY WARRANTIES. YOU MUST UNPLUG ANY POWER LEADS AND AVOID TOUCHING THE TUBE END INSIDE THE UNIT AT ALL COSTS. speech over we shall continue...
remove back of telly and carefully arrange screws in a circle shape to mimic their removal locations. trace the power lead cable physically by following the lead to the motherboard. to the man in the street thats the platform where all the components sit. the cable will be soldered to this board. visually check to see if there is a sound solid solder joint, marrying the two as one. if these are loose then you might be in luck.
resolder joints, cleaning off any residue of flux. replace back cover and power up.
Hope this helps
AndystUK
Oct 24, 2009 | ViewSonic P815 21" CRT Monitor
ViewSonic 19" flat screen monitor goes black - intermittently
There could be a problem with your display card settings or the display card itself. If you are using Windows operating system, make sure that you have the monitor driver installed for that specific monitor. This is to ensure that Windows only allows settings for which your particular monitor was designed.
Let me know if I can assist you any further regarding this.
Best wishes,
Graemevm
Jun 12, 2009 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Black screen when monitor power is on
Flyback has given up the ghost at this point on computer monitors there not worth fixing because flat panels are cheaper now a days but you can use best buy recycle program to see if you can get soemthing back for it www.bestbuy.com if you find this information useful please rate fixya when your rating thanks.
Apr 26, 2009 | ViewSonic P815 21" CRT Monitor
Computers & Internet Logo
154 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
