Is there a code reset button or a way to reset the lock code so that i can use my tv
Devices: Mitsubishi VS-45603 45 in. Rear Projection TV (only)
I'm hoping your have a working original remote for this creature from 1998 (the dark ages of Analog).
The first thing to try to reset a stored "lock code" is to unplug the set and leave it unplugged until the code is lost (or reset to the default). How long will this be? Mitsubishi won't tell (see below).
Service Codes are for the use of qualified service technicians only. Damage resulting from the unauthorized use of Service Codes will not be covered under warranty.
Manufacturer: Mitsubishi
Model: VS-45603
TV type: Analog Rear Projection Television
Chassis: VZ5
Year of Manufacture: 1998
Option Menu Code: 1370
Circuit Adjust Code: 2357
Convergence Adjust Code: 2359<4><5><6>
Since Mitsubishi fails to provide online support for its own products (even Users Manuals are unavailable), its left to the consumer to discover how to use & maintain Mitsubishi Electronics Products. Accordingly, I've no way to provide guidance on how to use the above Service Codes, nor is assistance possible if something goes horribly awry during the course of experimenting with them.
Please post your results.
Press the
"Menu" button to set the lock code for your JVC TV. A padlock icon
will appear on the menu display.
Press "Zero"
to access the lock code function then use the left and right arrows to select
the four-digit number for your code. Use the up and down arrows to move to the
next area of the display.
Select the up or down
arrow to finish your lock code then use the left or right arrow to save your
lock code settings and exit the menu. You can return to this display if you
forget your four-digit lock code and set another code.
Write your four-digit
lock code down and keep it in a safe, private area.
Select the locked TV
channel you desire to watch or want to unlock. A message will appear on the
display requesting you to enter your lock code to unlock the channel.
Unlock your JVC TV by
entering your lock code on the 10-key pad. The message "Invalid Lock
Code!" will appear on the screen if you enter the wrong lock code.
If you wish to know more, check this link.
Channel guard and V-Chip settings are protected by a four-digit lock code. Your TV comes
preset with a lock code of "0000". You may change the code to any four-digit number you wish.
To change the lock code, follow the steps below.
Press the MENU button
To SET LOCK CODE use UP/DOWN buttons.
To operate (lock icon appeares on pressing =>/
Press ZERO to access the lock code
The first digit will be highlighted
Use =>/<= button to
To select the number
Press Up/Down button to
To move to the next digit
Continue to follow these directions for all four numbers
Press the OK button to finish (your lock code is now set)
Press the Menu button when finished
OK. Thanks for using Fixya.
Channel Guard and V-Chip settings are protected by a four-digit Lock Code. Your TV comes pre-set
with a Lock Code of "0000". You may change the code to any four-digit number you wish. To
change the Lock Code, follow these steps
Press "UP" or "DOWN" button RESET LOCK CODE
Press RIGHT or LEFT button to operate
The Lcck Icon appears.
Press ZERO to access the Lock Code
Press RIGHT or LEFT button to seelct the number.
Press UP or DOWN BUTTON to move to the next digit
Press UP or DOWN button To FINISH
Press RIGHT or LEFT button to save settings and exit
Your new Lock Code is now set.
OK.
