Question about Panasonic PT-47WX49 47" Rear Projection Television
Pt 47wxd63g main screen not showing but pip shows when swap pip program for main screen pip program not show
  • 185 Answers
Trace your video path from input to output
Posted on Oct 08, 2008
How do I disable PIP?
Some remotes allow PIP to be turned on and off but your initial set up routine may have to be revisited to prevent PIP from popping up uninvited.
Aug 18, 2015 | Televison & Video
How to replace bulb on panasonic pt-47wxd63g ?
This model has three picture tubes and no bulbs or lamps.
you have provided a model number and if you tell me what set is doing or not doing I may be able to help.
Dec 23, 2012 | Televison & Video
How reset the lamp in panasonic tv PT-50LC-14 ?
While holding Volume Down button on TV Front and press and hold Play/ PIP button on tv Remote at same time for 6 or more seconds to reset lamp hours.
TV will show lamp reset message on screen.
Thanks.
May 02, 2010 | Panasonic PT-50LC14 50" Rear Projection...
Color problem
I don't know how much experience in working on stuff like this, but it sounds like a solder run might be cracked. If you're lucky, it might be that a gang plug needs to be "exercised" by pulling off and the replacing a couple of times. You might want to try to do this - anyone with a modicum of experience in working on electronics and computers will be able to pull this off. Chances are, you'll disturb the connection to either get it to work, or to make it worse. If worse, that is actually better, as intermittent problems are expensive to have fixed.
Nov 26, 2009 | Toshiba 61A61 61" Rear Projection...
Mitsubishi 60603
try switching your pip to the main screen and see if the pip shows blue while the main screen works.
May 29, 2008 | Mitsubishi VS-60603 60" Rear Projection...
Channels disappearing
this would apear to be a defective main tuner which a tech can replace this unit has two identical tuner modules one for main and one for pip There could be a issue with something called rf switcher. the signal goes in and is switch or routed to the pip tuner. so somewhere between the switcher and tuner the signal is lost.
Jan 28, 2008 | RCA D61W130 61" Rear Projection Television
Picture-in-Picture
I'm not at my shop so I'll see what I can do. Most sets will show PIP in just analog. If the video game is in High Definition or in component then it may not show it. If the main input you are using is the computer input, then the set may not show PIP in that mode at all.
Aug 26, 2007 | AOC Envision L32W461 32 in. LCD HDTV
Need help with PIP
When you go into the menu to choose the PIP source the PIP comes on to confirm that a valid source has been selected. It is normal for the PIP to close when the menu is exited. To display the PIP normally you will need a remote with a PIP button. Most universal remotes today have PIP functions but if you get a Zenith original replacement then you are guaranteed to enjoy the other PIP features such as size, position, freeze and swap.
Jul 25, 2007 | Zenith Z36X31D TV
Blue screen
check the agc circuit it is becomming defected.good luck.
May 16, 2007 | Mitsubishi VS-60703 60" Rear Projection...
No pic/sound on main screen
I will recommend replacement of the main tuner
Dec 10, 2006 | Toshiba CN35F95 35" TV
Panasonic PT-47WX49 47" Rear Projection Television Logo
73 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
