Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
2005 fxsti electrical problem
I started to leave work yesterday.It turned over like it was going to start and suddenly evrything went dead.no lights no nothing.I checked the fuses and none were blown.Help.
    Scholar:
  • 29 Answers
Probably as simple as a bad battery connection. Don't just look at them, disconnect, clean and retighten them. It is also possible that the battery opened up. Put a voltmeter across the terminals and read the voltage. If it is less than 10 volts the battery is junk. If it is more than 10 volts, turn on the ignition and if the voltage drops way off the battery is junk.
Posted on Jan 01, 2009
1999 Crown turned ignition switch to start - heard pop - no electrical power
If nothing works including the lights, something happened between the battery and the fuse box.
There are some fuseable links between the battery and the starter solenoid or between the solenoid and the fuse box.
I'd start with the battery cables and look for those fuseable link wires.
Jul 09, 2012 | 1999 Ford Crown Victoria
My 2005 Jeep wrangler suddenly would not start yesterday after several trips around town. I turned the key it made a funny noise then nothing except all the dash gage arms were jumping around making a...
probly need a new batt if over 3 yrs--it has scewed ur computer up--do a tuneup-chec plug wires-clean throttle area-test alternator now cause a bad batt cant ruin it--also inspec trans fluid etc-get a haynes manual at parts place
May 14, 2011 | Jeep Wrangler Cars & Trucks
I just bought this car yesterday. Went out to start the car and it wouldn't start. I turn the key in the ignition and the radio, heater and lights come on, but the engine won't start.
have you try giving it a boost ,if so and started your battery is dead ,also check alternator by disconnecting the pos, side of battery if it turns off is the alt ,bad
Mar 06, 2011 | 2005 Chevrolet Equinox
Had starting problems and cleaned terminal wires, car started. Yesterday same problem, adjusting wires did not work. Had battery jumped, car started. I warmed up car for 5 minuted before driving. Car...
I would say that you need to replace the alternator. The car was running on the batteries power. When you drove the car, it ran the battery completely dead.
Jan 14, 2011 | 1997 Ford Taurus
Electrical malfunction
U may have a problem with the BCM (body control module), it will happen again and becopme more frequent until it won't start. I suggest the next time ythis happens have the GM dealer test the BCM, it has a self testing feature to help ID these types of problems, it takes a GM electronic scanner to tap into the functions of the BCM..
Apr 21, 2010 | 2005 Cadillac CTS
Went to start my car yesterday and it wouldn't start. Got it jumped it worked fine. A few hours later started it again and radio went dead car went dead what could it be?
sounds like alternator may not be charging check voltage at battery while engine is running need to see at least 13.1 volts if not have alternator checked and or replaced
Mar 21, 2010 | 2005 Nissan Altima
Gilera runner sp50 - engine turns over but does not start
you went through the electric. system, now check fuel supply filter, tank, valve carb bowl for dirt
Aug 08, 2009 | 2005 Gilera Runner VX 125
Battery goes dead
You need to Check out the Alternator.
Jan 17, 2009 | 1995 Ford Thunderbird
Lands Phones Logo
78 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
