Question about Acer AL1711 17" LCD Monitor
Screen stays on after + - 20 times turn on
I must turn the screen on for + - 20 times then he finally stays on
    Scholar:
  • 92 Answers
There are some electrolytic capacitors in the power supply that need to be replaced. I believe it's 1000uf @25V. They put in 16V caps at the factory and they don't seem to hold up.
Posted on Oct 07, 2008
Once the TV is turned on, the sound and picture disappears and replaced by a blank screen. If one turns it off again and on imediately the picture and sound returns. This may happen several times in a row,...
Could be ethier one the dish box or the tv itself have cold solders joints on the FBT-Flyback transformer.That the big black block of plastic with a red wire with a black cap hook to the CRT-(tv tube).Call ur tv Dish box customer service,get a replacement box.See, if this will solved ur tv problems.If not,than the tv must be taken aparts and must have tools like a soldering iron,a roll of solders,also must know basic soldering.Resolders all the coldsolders joints on the FBT for a better High voltages contact to the CRT-(tv tube).This problems,will be solved.
Dec 03, 2010 | Philips Magnavox 27MS343S 27" TV
It pops and shuts off when I first turn it on. It finally stays on with sound and grey screen which changes colors. then the picture finally comes in about 20 minutes later
NEVER operate a set after it makes a loud pop. Only high voltage discharges can make such a sound. It is DANGEROUS to operate a set under those conditions. The chassis could be electrified or it could start a fire. Contact a qualified service technician.
Jan 09, 2010 | Westinghouse LTV-27w6 27 in. LCD HDTV
TV blinks and then no picture at all
HOW DO YOU CHANGE A LAMP BULD IN A SONY HDTV. MODEL#KDF-E60A20
Oct 11, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
My eMac doesn't like to restart after being put to sleep or turned off. When the power button is pushed it will beep 3-4 times and the white power light flashes in sets of 3 short lights, and the screen...
I know emacs have had there times and this might be the cause for yours as well. Do this: turn the mac upside down take off the memory cover from the unit using a screwedriver now you will see 2 round capcitors there check to see if there buldging at the top or leaking for the bottom. Now not all caps leak they just buldge. If this is the case you have a couple options here 1. repair it yourself 2. take the logicboard out of the system (a lots of work) and log on to www.badcaps.net this dude will repair it for $75.00 plus shipping Thanks
Aug 09, 2009 | Apple eMac G4 Desktop
Garmin 178C Stays on for 20 secs then turns off
I had the same problem. In your settings you can set this thing to monitor your battery's power so it auto shut down if your battery goes below 11.2 volts or so. I disabled this and it has worked ever since.
Jun 16, 2009 | Garmin GPSMAP 178C Sounder GPS Receiver
Computer won't work past login screen
from that error, it is likely one of 2 things. Either the bootloader is corrupted, which you can try to repair with the following tools:
http://neosmart.net/wiki/display/EBCD/Recovering+the+Vista+Bootloader+from+the+DVD
Worst case for a software error, clean install of Windows to resolve.
Or the hard drive is having a hardware failure and it is effecting the boot sector of the HDD. If it is a HW failure, you may be able to run diags to see if a fault is found. If the drive is bad, it will need to be replaced
Feb 05, 2009 | Acer Extensa 4620 Notebook
Monitor does not turn on automatic
change your power cable.
also check your power suply and earthing.
Nov 19, 2008 | Princeton Digital VL2018W Monitor
Jeep cherokee radio problem. will come on for about a second and after turning it off/on 20-30 times it will finally stay on.
sounds like a bad on/off switch in the stereo which means its time to replace it with a aftermarket stereo if you want to fix the problem
Aug 12, 2008 | Car Audio & Video
Boot up and down
I've had a couple of machines with similar symptoms.
The remedy will be one of a few.
Instead of a recovery, you may need to do a full system install.
The most likely problem is the heat sink/fan is getting clogged with debris, thus causing the system to run hot, which includes the video module. Cleaning this out is definitely something that needs to be done regularly in any case.
Also, the lcd cable may be slightly loose where it connects to the lcd.
Finally, it's possible that the video module is going bad... not much you can do about that.
Hope this helps.
Good luck
Oct 18, 2007 | Toshiba Satellite M45-S355 (PSM40U073001)...
Acer AL1711 17" LCD Monitor Logo
60 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
