Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Wireless connection but internet is offline
I have installed my Belkin G router along with the USB thingy but when I try to connect to the internet through Tesco's the computer (laptop) states it is offline. All the lights are green on the router apart from the internet light.
Also when I unplug the ethernet cable the laptop says there is cable unplugged so I'm not "wireless" yet.
Please help!
  • 87 Answers
There may be another program intersecting with your program make sure that in your start up you only have the program that you want to be your networking program.
Posted on Oct 07, 2008
Hi. I have just set up a Belkin Share wireless router, Connecting to internet fine, but can't get printer to work via usb. Green light above socket doesn't come on when I plug it in. Thanks in advance -...
Ian, you have to 1st of all connect that printer to the computer and check if its working fine or not. Check if you have installed the necessary drivers and software that came along with the printer. Once that gets to go, then, connect the printer to Share router and check if the light above the USB is lit up to check if the port on router is working. If that is lit, you have to be connected to the router (make sure that you aren't connected wireless as a guest). Guest access doesn't have the rights to have file and printer sharing! Install the router monitor software properly that would be on the disk which came along with router or download the latest version of software from: http://en-us-support.belkin.com/app/answers/detail/a_id/3714/p/5132
You also have a brief tutorial on how to configure a printer with this router on the Belkin Support website. Here is the link for that. http://en-us-support.belkin.com/app/answers/detail/a_id/3796/p/5132.
For further clarifications, do revert!
Thanks for asking.
Regards,
Arvind S Iyer
Oct 03, 2010 | Belkin Wireless Share Router (F7D3302)
I have a embarq 660 series router and using a compaq presario computer. I have already installed the belkin surf/share wireless USB adapter to this laptop. When I go to Internet explorer it says offline.
your problem is a IP address conflict
Embarq and Belkin have the same IP address 192.168.2.1
change the IP address in to your Router.
To restore the router to factory default settings, please do the following:
1. Unplug the router's power supply
2. Press and hold the reset button on the bottom of the router
3. Keep the reset button depressed and, at the same time, plug the power supply back in
4. Keep the reset button depressed for another 10 seconds
5. Release the reset button
======================= Manually configuration ==============================
Step 1 : Connect modem - Router - Computer ( Wired )
Step 2 : Open router setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left side under internet WAN click Connection Type
Step 4 : leave the Password Blank and click submit
Step 5 : Choose the connection type as dynamic and click next
Now go to lan settings and change the IP address 192.168.2.1 in to 192.168.1.2
Step 6 : Leave the Host name blank and click apply
Step 7 : On the left Under Internet WAN Click MAC Address
Step 8 : Click Clone and Click Apply changes
Step 9 : If the Internet status on the top right is connected
Step 10 : Then check if you have internet
Step 11 : if not Then unplug the Power Cable from the Modem And the Router
Step 12 : Plug the power Cord to the Modem
Step 13 : Wait till all the lights are on
Step 14 : Plug the power to the belkin
Step 15 : Check the color of the light in the belkin
Step 16 :If green then Check if you have internet
If not working then call belkin
=================== WIRELESS SETTING UP A WIRELESS CONNECTION ====================
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Sep 06, 2010 | Belkin Surf Share Wireless USB Adapters...
What is a belkin n wireless usb adapter model # fsd8053v4 used for and can u connect to the internet with it and where do i get the driver?
The wireless adapter is used to connect wireless to the internet, You can use it to make your desktop wireless and laptop.
You can connect to the internet as long as you have a wireless router in your place that will supply the wireless signal.
The driver can be download on this website
http://www.belkin.com/
cheers,
KA
Jun 15, 2010 | Linksys Wireless-G WRT54G Router
How do i connect my verizon dsl westell 6100 to my belkin g rtr?
Wellll....since it seemed an impossible task, I tried the next best thing.
I bought a wireless adapter for the other pc and voila! they are on the internet, and I am returning the router.
Westell modem + Verizon DSL w/usb = No connection to router.
Dec 28, 2009 | Belkin Wireless G Plus MIMO (F5D9010)
I cannot get my Dell Inspiron Laptop to connect with Belkin router, any idea why??
Are you trying to connect to the wireless network on the laptop ?
It is very simple.
first you will need to make sure that you have all the wireless settings of the network.
Click Here for more info about wireless network connections
Oct 17, 2009 | Belkin (F5D5231-4) Router
Two PC's,no access to internet upon PC connected by Adaptor.
solution 1:Reset the new password for accessing for internet.
solution 2:check with adapter.plug out and plug in the adapter(and also antenna too )
Feb 27, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Help
One solution might be to go into the file menu of Internet Explorer and de-selecting "work offline".
May 12, 2008 | Belkin (F5D7230-4) Router (587009)
Sprint aircard 595U to belkin router model no# F5D7230-4
Try connecting the sprint card to your router's internet port. You will need a usb-to-ethernet adaptor, along with a networking patch cable, to connect the sprint card to the router.
Then either connect to the router with your two computers using cables, or wireless. If using wireless, you will need wireless adaptors for each of your computers, preferrably Belkin brand to ensure compatibity.
Apr 10, 2008 | Belkin (F5D7230-4) Router (587009)
D-Link wireless router and Belkin Wireless G USB Network adapter
Set your wireless network as a preferred network and to automatically connect to it. Also set it at the top of the list so that it takes precedence. If you continue to get conflicts, change the channel of the router.
Mike
Oct 31, 2007 | Computers & Internet
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
128 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
