Question about Frigidaire GLTF2940ES Front Load Washer
Broken Machnine I have a Crosby washing machine that is about 5 years old. Last night we was washing towels and when the machine will not pump the water out (about half full) and when it hits spin it makes kind of a whinning noise and you can smell burning rubber like the belt is hot or something and it does not even try to spin.
  • cbtawa Oct 01, 2008
    I have a frigidaire washer front load about same age do not remember exactly the model but 3 weeks ago it was doing some noise at the last spin and then we had a small leak under it. The repair guy told me the leak was the water pump seal defect we had to change it ($260) and now the noise at the last spin is still there but at every wash (even on empty) and this time they told us it was the drum bearing system that was gone ($500 at least). I am furious and I wonder why the Frigidaire front load are so well rated when you have to change a machine after 5 years. Did you and me just got the rare defective ones or are they all bad??? I am sorry to let you know that you might have to purchase a new washer if this is also a drum bearing. The noise happens only on the last spin and you have the feeling that the drum is running loose inside the machine. I hope this will help you to not have to pay someone to tell you that your machine is gone (here just for that you have to pay $69). Good luck!
  • 943 Answers
Hi. thanks for the question. the problem is .there is something caught in the water pump, and a burnt out belt ,replace both parts thanks the appliance doc
Posted on Oct 01, 2008
I have a 5 year old Midea aw60-982 washing
Sounds like a bad belt or a locked up pump.
Sep 16, 2013 | Washing Machines
I have a LG front loading direct drive washing machine (WM1812CW) that is 5 years old that is making a loud knocking noise during the spin cycle and is emitting a burnt smell after the cycle ends. ...
It seems you need to have a new sealing rubber fitted. IN THE MEANTIME, if the knocking happens again when the spin starts, stop the machine, let the washing drop to rest, and then start it again, the re-positioning of the fabric inside the drum should even out. Also, do not load with say.. only towels, that way the weight is one sided and will make the drum spin in an uneven way.
Oct 07, 2017 | LG WM1812C Front Load Washer
74810 won't spin
Sounds like spin drive belt has either come of or is broken...unplug take back of machine off ,its not difficult to do then you can seeif belt still on or not its not an uncommon occurence
Sep 06, 2009 | AEG Washing Machines
Hotpoint WD64 is not spinning or emptying
check the pump, make sure drain hose is not cloghed, ensure the belt is in the place, spin the drum a bit by pulling the belt. then give it a go.
Update me about your progress
Jul 24, 2009 | Hotpoint Aquarius WD640 Front Load...
F/L Washing machine doesn't spin
Normal 0 First drop the lower front panel and remove the pump so you can check the hose leading to the drainpump for debris, coins, etc.
Lower front panel has two? screws holding it in place.
Be prepared for water on floor... use shop vac or have several towels ready for water. Recommend putting at least one towel undermachine before removing pump.
Clamps that hold hose to pump can be a challenger to removeand replace. Consider replacing stockclamps with screw clamps.
This is a great fix.... did it last night.. Found coins, screws, etc. in pump. Once I cleaned out the hose area leading to the pump the spin cycleworked fine.
Apr 22, 2009 | Washing Machines
The washer does not spin during washing cycle or drain & spin cyc
I can a very simple part called the motor coupler...you can find the part at www.repairclinic.com. It costs 13.95. I am fixing my washing machine today, as this happened before and was the answer. Goodluck
Apr 11, 2009 | Kenmore 46462 Front Load Washer
Crosby washing machine has lint issue,,,my cloths gets linted,,,how to fix this,,,this machine is upward loader,,,has no window for lint remove
Hi khan,
Happy to be of assistance for you!
sounds like this time you need to,
call Service and have them come out.
If it's new your our under warranty for 1 year!
If it's 10 years or older then do not waste the money .
The newer ones are more efficient!
Good work done here.
A&E Factory Service
Nation Wide
7days/24 hours
They do Frigidaire warranty work.
Thank You for asking!
Please rate my, solution solved in this fixya site!
Neil
Aug 09, 2008 | Frigidaire GLTF2940ES Front Load Washer
5 yr old washer is leaking
Ellbee, remove the two screws at the bottom of the front panel and lift it towards you. Two clips on the top that hold it will release. You can now get a good look at the pump. Catriver..post back.
Sep 19, 2006 | Frigidaire GLWS1339C 3.0 Cu. Ft. Top...
Frigidaire GLTF2940ES Front Load Washer Logo
80 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
