Question about Asrock P4VM890 Motherboard
Bios setting Utility for asrock Motherboard P4VM8
Under Advanced Setting for Bios I found the following mess. (Setting wrong values in below sections may cause system malfunction). What I'm missing to setup?, Thanks for your help.
    New Friend:
  • 161 Answers
I would set the bios back to default to cure any problems.....to do this the easy way i would take out the battery on the motherboard.....it looks like a watch battery and the numbers on the battery are usually 3023 or 2032.....levae it out for 10 minutes minimum and then instal it again the same way you took it out....thatll clear the bios and reset the settings. try that and tell me what happens.
Posted on Oct 01, 2008
Where is the ram memory slot in my p4vm8 motherboard
http://www.asrock.com/MB/overview.asp?Model=P4VM8
The TWO blue long connectors on the board with clips at either end are the ram slots, this model uses DDR1 ram, make sure you align the ram module correctly in the slot
Dec 30, 2010 | Asrock P4VM8 Motherboard
Setting wrong values in below sections may cause system to malfunction,how fix this
I can't get what exactly you mean by "wrong values" If you mean jumpers, you need to refer the motherboard user manual. If it's with the Bios settings, just remove the bios battery and leave it outside for few mins (max 5 mins) and reinsert, it'll be ok, there should be no more problem with your settings. Good luck..
May 15, 2010 | Asrock P4VM890 Motherboard
How to increase the shared memory for the internal graphics. i searched everywhere in the bios but i couldn't find a setting. the upper limit is 64 mb and it is currently set to 8 mb. i want to increase...
Your AGP aperture size is 64 MB but your "Onboard VGA Share Memory" may be set only to the maximum available setting in your BIOS. (You may already be at maximum)
1. Highlight "Onboard VGA Share" press <Enter>
2. Change value with [+] or [-]
3. F10 Save and Exit
Dec 14, 2009 | Asrock 845GV (P4I45GV) Motherboard
Not able to complete windows xp setup
First let's try to "flash" the BIOS to correct the erroneous data crashes. Here's the link for the motherboard:
http://www.asrock.com/mb/overview.asp?Model=P4VM8
After flashing go back to the BIOS and setup the appropriate settings, after that reboot and try to load Windows. If this fails then possibly you may have faulty memory modules or they are not seated correctly in the motherboard, try swapping them, hopefully they are the same. I hope this helps.
Jul 03, 2009 | Asrock P4VM8 Motherboard
Bios update
Visit the Asrock support website and download it from there.
Feb 20, 2009 | Asrock P4VM8 Motherboard
Does Asrock P4VM8 support 500GB SATA hard disks?
near the interface port of the hard drive you have to put a jumper that limit the connection speed from 3.0giga per second to 1.5giga per second, I think that would solve the problem because the hard drive speed goes to 3 giga per second and the motherboard p4vm8 serial ata port can support up to 1.5giga per second.
Jun 23, 2008 | Asrock P4VM8 Motherboard
Graphics card:Nvidia EN7300GE
The Asrock P4VM8 motherboard does not have a PCIE slot. Only a AGP. Listed below, click the link:
Unless you have given the wrong information. Please clear this issue before I can help.
Feb 08, 2008 | Asrock P4VM8 Motherboard
BIOS
You did not mention what problem you have! Either way it's an old board, if the bios is messed up all you can do is flash your bios with the latest firmware from the link below:
http://www.asrock.com/mb/download.asp?Model=K7VT2&s=
Or is it a setting issue?
Jan 13, 2008 | Asrock K7VT2 Motherboard
Asrock P4VM890 Motherboard Logo
739 people viewed this question
Top Asrock Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Mark Taylor
Mark Taylor
David
David
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
