Question about Nokia 6681 Cellular Phone
Nokia 6681 continous restart
3 months back, my phone got wet with rainwater. When I reach home, i found my phone switch off. Thinking battery must have gone low, I plug in the charger. Then Phone started showing peculiar kind of behavior.
1) Continuous restart occurs randomly until battery wasted off. When phone is locked it is not able to do so.
2) Some buttons like POWER BUTTON, LEFT SELECTION KEY, RIGHT SELECTION KEY & NAVIGATION KEY doesn't respond normally.
3) I perform software upgrade. It didnt fix the problem
4) Format the flash memory by pressing "GREEN CALL KEY + * + 3" & Power button when the phone is off. It work for sometime & problem returns.
I would like to know the possible problem with my phone.
Is some part of my flash memory corrupted??
please provide me a solution.
  • Anonymous Feb 26, 2009
    My phone restarted atometically after 2 or 1 minite
  • 31 Answers
Its uem problem or viruse problem virus problem can be sold by formating card and phone bhoth but if problem countinui its very hard to repair this kind of problem
Posted on Oct 09, 2008
SOURCE:
PHONE RESTARTING CONTINOUSLY
khare your device has a software problem do hard reset by *#7370# and default code is 12345, or swith off device and press and hold * 3 green button and then power on wait until show insert card. it will solve your problem.Best of Luck, if my answer was helpful please rate it.
Jul 18, 2012 | Nokia 6681 Cellular Phone
When i open manager application in nokia 6681 scanning memory comes automatically. i m not able open it.
reformat your phone to avoid , just long press *3 and call color green must press at the same time and then,, switch. you will see the select country or language. remove memory card before reformatting.
Sep 16, 2011 | Nokia 6681 Cellular Phone
I have nokia 6681 start up failed
Here is your solution just follow the instruction below ...If there is no Hardware problem definitely it works..
Press and hold 3 keys i.e. Green, dial key, *, Star key, no. 3 , key on keypad and then press the power on/off to switch on the phone.Examine the battery backup of your phone. Remember, do not let go the 3 button i.e * + 3 + green just press and hold keys until you see a formatting word screen shown........But in N series don't release the three button until the time set shown . original system and factory setting has also done automatically.There is no guarantee coz it might not work with some phone.............................................Try and Enjoy
Aug 15, 2010 | Nokia 6681 Cellular Phone
Bluetooth peripheral driver
Switch-off your phone. 1. Press and hold 3
keys; Green dial key, *
Star key, no. 3 key on keypad and then press
the power on/off to
swtich on the phone. Remember, do not let go the 3
press and hold
keys until you see a formatting word screen show! 2.
After a few
minutes when the Full phone formatting completed, your phone
will
back to original system and factory settting.
Jun 18, 2010 | Nokia 6681 Cellular Phone
My nokia 6681 fell in the water and is not turning on.all my contact details are stored in it.i cannot retrieve them as the phone is not turning on.please help immediately
dry the phone out and keep it off for a day or two. Your phone is interanlly wet and trying to tamper with it while wet will only fry your phone. Once it is dried inside and out put your battery back on and turn it on :o)
Oct 20, 2009 | Nokia 6681 Cellular Phone
I have a problem with switching my nokia 3110 classic answer pls!
The Problem with Nokia 3110c – Switching off and automatically restarting This is what happens. Nokia 3110 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Possible Causes and Solutions Cause 1 – Phone Memory Full – Nokia 3110c mobile phone has got 9MB of internal memory.
Solution – Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
Cause 2 – Changing Themes – Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution – Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
Cause 3 – Memory Cards – Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution – Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 – Transferring data via Blueooth / USB data cable (or) Updating Music Library – A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library.
Solution – Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 – MP3 files
Solution – This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
Also try this:-----
It ll work . you dont need to go 4 the firmware v5.05
If ur phone restarted 3 or 4 times and switched off automatically. Try this
method
1] Remove the battery and Micro SD card
2] wait about 5 minutes
3] Then switch On the phone WITHOUT the memory card
Now ur phone working well without restarting
4] Then you must restore Factory settings frm the Settings Menu
[default security code:12345]
{i know most of people have done this thing,but remember u have 2 go
with the correct order.Unless it will not work.OK}
5] Now apply a theme. The theme's size should be below 100kb
6] Now ur phone working fine without the Micro SD
7] Then wait about 5 minutes and Switch off ur phone
8] Remove the battery and insert the Micro SD
{Don t Format the memory card}
9] Switch On ur Nokia 3110c phone.
10] Now Keep ur free Phone memory space [Not the memory card's free space]
between 470kb - 499kb.
Now surely ur 3110c working fine about 5
months.During these time u can
1] Send/receive any file via bluetooth.
2] Enjoy Music,video, GPRS,Yahoo Go .....etc
3] Also u can Update music library anytime.
but remember below DONTs
1] Don t try to change themes.{u have to stick with a theme}
2] Charge ur phone in ON mode
3] Dont fully discharge the battery
4] Start charging ur phone when there is only a bar on Battery indicator
5] Dont erase calender notes
Make sure about above 5 Donts
Dont worry if ur phone restarted once.{U know the problem is restarting several times
and automatically swiched off.}
After 4 or 5 month there is a possibility to occur the problem again.
if so Follow the above steps again.
Good luck
To be frank, This mobile has this as a generic problem. As I told, The problem can come back again.
Thank you Sir, Have a nice day.
Sep 21, 2009 | Nokia 3110 Cellular Phone
Nokia 6681 Restarts automatically
Type *#7370# and give phone security code. This is a soft format. If no result, go to a better mobile servicing center. Make a whole flash (mobile phones OS repair). Still have problem, change UM chip. Keep informing.
Feb 19, 2009 | Nokia 6681 Cellular Phone
Nokia 6681 restart problem
please remove its battery first than take it to the service center or contact me at 09999 916148
Jun 17, 2008 | Nokia 6630 Cellular Phone
Nokia/6681 lcd problem
well no program or code will work for you.you need to show it to mobile repairing shop..............
Feb 28, 2008 | Nokia 6681 Cellular Phone
Problems with Nokia 6681...
1. sms uusually don't get backuped,unless uploading information from your phone to a pc is supported by your phone. try to look up user's guide. 2. rebooting BB5 class phones such as 6630,6680,6681, N series usually require full reformatting. try visiting your local non-Nokia/independent service stations.
Jun 19, 2007 | Nokia 6681 Cellular Phone
Nokia 6681 Cellular Phone Logo
208 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
