the action of rotating around an axis or center."the moon moves in the same direction as the earth's rotation"
synonyms:
revolving, turning, spinning, gyration, circlingMore
"the rotation of the wheels"
turn, revolution, orbit, spin
"a rotation of Jupiter"
the action or system of rotating crops.noun: crop rotation; plural noun: crop rotations
Forestrythe cycle of growth and felling or cutting of trees.
the passing of a privilege or responsibility from one member of a group to another in a regularly recurring succession."it has become common for senior academics to act as heads of department in rotation"
synonyms:
sequence, succession;More
alternation, cycle
"each member is chair for six months in rotation"
USa tour of duty, especially by a medical practitioner in training.
"she was completing a rotation in trauma surgery"
Mathematicsthe conceptual operation of turning a system around an axis.
Mathematicsanother term for curl (sense 2 of the noun).
Origin
mid 16th century: from Latin rotatio(n-), from the verb rotare (see rotate).
Hi Mitiku:
Not sure why, but your question ended up in the washing machine section. Looks a lot more like astronomy.
So, to your question.
1) The Earth rotates on it's axis because it does.
2) The time to complete one rotation is constant as far as I know.
3) What's this about anyway?
Winter solstice is an Astronomical phenomenon which marks the shortest day and the longest night of the year. Winter solstice occurs for the Northern Hemisphere in December and for the Southern Hemisphere in June
The axial tilt of Earth and gyroscopic events of the planet's daily rotation keep the axis of rotation pointed at the same point in the sky. As the Earth follows its orbit around the Sun, the same hemisphere that faced away from the Sun, experiencing winter, will, in half a year, face towards the Sun and experience summer. Since the two hemispheres face opposite directions along the planetary pole, as one polar hemisphere experiences winter, the other experiences summer.
I've almost the same problem. When the system turns on the monitor doesn't sync. After a variable trials with down/up the sync is enabled and the computer starts.A very clear event occurs : when the monitor can''t sync ( and system doesn't boot)you can hear very clear a high fan rotation. When I look/hear in the system the Isuspect the cpu fan. The system boots ( monitor syncs) when the fan rotationgoes from high to low. So the system hangs on an internal check on the rotation speed of the cpu fan.I've googled a lot , but until now doesn't find an answer . Possibilties which I think about : replace cpu fan , clean cpu fun ( but it looks clean).I cannot measure the fan rotation speed when the system is hanging. At normal rotation all info can retrieved witth the program cpu-z.Did you already have a solution ?
It could. If the x range doesn't include x=0 then the y axis will not show. Likewise, if the y range doesn't include y=0 then the x axis will not show.
Assuming you are talking about Age of Empires II: Gold Edition or Age of Empires III: Gold Edition, those games aren't available as digital copies. You'll have to acquire them in a retail store or through an online store.
Furthermore, downloading pirated versions of games is illegal and means to do it will not be given here.
-Organicbeing
Usually when a game cuts off like this the computer or pc's 3d graphics accelerator can't handle the program it's trying to run and will shut it down. Check your operating system info and compare it to the requirements of the software. If it is compatible you should contact their tech support which is usually in the read me file associated with the program for further help
