Question about Electrical Supplies
Two way lighting switches
A qualified electrician recently moved a two way switch (SW1) in my kitchen
The light works normally on one switch (SW2). (SW1) will not switch it on but if already on will switch it off (SW2) will not switch it back on
Which wires should be live at all times and which are switched
  • 45 Answers
Assuming that your electrician is in fact qualified, he should have tested the switches after completing the work. Some people get in a hurry and overlook this important practice.
If the 3-way switches (there is no such thing as a "2-way" switch) were working correctly after being moved, then one of your switches is bad.
Don't mess around with this yourself, this is how many homeowners get hurt (or killed). Call your electrician back.
Posted on Aug 25, 2009
  • 4,234 Answers
This switch system is not wired correctly which makes me wonder if the "qualified" electrician is actually qualified. Since the system is not working properly, I would first request that the original electrician comeback to fix it at no charge to you. Failing that, get another to trace the problem and fix it. I would get this fixed ASAP as there is the possibility of short circuits and fire if not addressed.
Dan
Posted on Oct 07, 2008
Bizhub 500 error code c-3901
do below once if the code comes back replace the fuser continue reset cause fire ruining a perfectly good day
1. Turn ON the main power switch (SW1).
2. With the Utility/Counter key pressed, turn ON the power switch (SW2).
3. Press [Trouble reset] to release a trouble with [OK] displayed.
4. Turn OFF and ON the power switch (SW2).
Jan 03, 2014 | Konica Minolta bizhub C250 All-In-One...
Error code 3901 konica minolta bizhub 420
sir/mam
Do below once if the code comes back replace the fuser continue reset cause fire ruining a perfectly good day
Jan 03, 2014 | Konica Minolta Office Equipment & Supplies
There is no headlight switch for my 2000 jeep wrangler
have a qualified auto electrician move the power for the lights to the ignition switch so that when you turn off the ignition the lights go off. or have a qualified put an extremely loud beeper in the light circuit so that it sounds when you turn off the ignition. Actually there is a beeper that sounds when you leave the lights on after you turn off the ignition.
Dec 20, 2013 | 2000 Jeep Wrangler
Schematic diagram of cobra 148 gtl cb radio china made
  • Locate the MB8719 chip that is right behind the channel selector. Wire a SPST switch from pin 10 to ground and another from pin 11 to pin 12.
  • Channel Chart
  • Position 1: sw1 down, sw2 down
  • NORMAL CHANNELS
  • Position 2: sw1 up, sw2 down
  • 15=26.815 20=26.885 25=26.925 30=26.985(ch3)
  • 16=26.835 21=26.895 26=26.945 31=26.995(ch3A)
  • 17=26.845 22=26.905 27=26.955 32=27.005(ch4)
  • 18=26.855 23=26.935 28=26.965(ch1)
  • 19=26.865 24=26.915 29=26.975(ch2)
  • Position 3: sw1 up, sw2 up
  • 1=27.605 6=27.505 10=27.555 14=27.605
  • 2=27.455 7=27.515 11=27.565 16=27.475
  • 3=27.465 8=27.535 12=27.585 20=27.525
  • 4=27.485 9=27.545 13=27.595 23=27.575
  • 5=27.495
  • Position 4: sw1 down, sw2 up
  • 1=27.605 11=27.725 21=27.855 31=27.955
  • 2=27.615 12=27.745 22=27.865 32=27.965
  • 3=27.625 13=27.755 23=27.895 33=27.975
  • 4=27.645 14=27.765 24=27.875 34=27.985
Nov 09, 2011 | Cobra 148 GTL 120-Channels Base CB Radio
How do i wire in a 2 light colour signal to a 2 way switch
Two Way Light Switch Wiring Have you ever wonder how a lamp that is used to light up the stairs of a building is connected to the two switches that controls it from either end? These two way switches have a single pole double throw (SPDT) configuration. Each has a common terminal (COM) with a pole that can be switched between position L1 or L2. The two way light switch wiring can be implemented by using 2 different methods. Both of the methods used are described below.
The first method as shown in the figure above have the COM, L1 and L2 of both the SPDT switches connected together. For incandescent lamp, the recommended wire gauge used is AWG #18. The LIVE AC Source is connected to L1 of SW1 and one side of the load is connected to L2 of SW2. The other side of the load is then connected to NEUTRAL of the AC Source. With this configuration, the lamp will be turned ON when one switch is at ON position and the other is at OFF position. If both switches are in the same position, the lamp will be OFF.
The other method is as shown in the figure above. In this configuration, the L1 of both SW1 and SW2 are connected together. Similarly, the L2 of both SW1 and SW2 are connected together. The LIVE of the AC Source is connected to COM of SW1 and one side of the load is connected to COM of SW2. The other side of the load is then connected to the NEUTRAL of the AC Source. With this configuration, the lamp will be turned ON when one switch is ON and the other is also ON. If both switches are in different position, the lamp will be OFF.
Take note that as the installation involves mains power supply, only those who are qualified and have electrical wiring knowledge should do this wiring. When doing the wiring, it is recommended that the power supply is disconnected from the load and the switches.
Nov 13, 2010 | Computers & Internet
How do I wire for 2 seperat lights on a commom system?
{SW1}---Light 1 switched leg to fixture 1
HOT wire (Line or Feed)----{
{SW2}---Light 2 switched leg to fixture 2
The wire supplying power to the switches will be connected to the "LINE" terminals tied together with a breakaway tab (common feed). The upper "LOAD" side terminal will output to the first light and the lower "LOAD" side terminal will output to the second light. The neutral (White) wires if present will be joined together (wirenut).
All electrical work should only be done by qualified individuals.
Apr 12, 2010 | Leviton 5634 Dual 1 Pole Switch Decora...
My Daughter needs a timer placed on her front out side lights. I've puchased a GE 7 day digital timer. She has a plate with three switches ( left-right ) 1 switch, I haven't a clue what's it for ? Tried...
If you are in Australia, you are required by law to get a licenced electrician to do this work.
I cannot speak for other countries, but anything electrical behind a plate should be done by a qualified electrician.
If you are confused about the wiring, you are definitely not qualified. Either it is beyond your skill, or it was done in a non-standard way or before the current standards. Either way, please get someone qualified to fix it, for your own safety, and that of your family.
Dec 03, 2009 | GE RM24948 Remote Control
Two way light
FIrst of all, it is actually called a 3-way switch system. I would suggest that you either consult and elexctrician or look up the Time-Life series on home projects which contains a couple of volumes on electrical projects. Included in there are complete diagrams of how to hook up 3-way switch systems.
Dan
Oct 01, 2008 | Electrical Supplies
Ibm 61h2500 p/n 61h2471 sw1 and sw2 problem
All sw1 1-4 and sw2 1-8 = OFF, PIII at 133 MHz, SDRAM at 133MHz, and AGP card 2x, not 4x or 8x.
Try it PII and SDRAM 100MHz after.
Jul 22, 2008 | IBM PC 300PL Socket 370 Barebones Kit /...
Boolean Logic
I don't know the syntax but you could easily do this with setting the switches to a constant, then adding them up. The number set would need to be something so that there would only be one solution...the one that you were looking for.
sw1 = 1
sw2 = 2
sw3 = 4
If sw1 and sw2 is both on, but sw3 is off, the number would be 3
If sw2 and sw4 was on, the number would be 6
If all were on, the number would be 7, etc.
May 08, 2008 | Computers & Internet
Electrical Supplies Logo
187 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
