Question about Cameras
My son broke my digital camera memory card i cant excatly discrape the damage the metals which is connect to the chip some off them separate from there connection point do you think it might possible to recovery my pictures
  • 21 Answers
This is just to test ur luck but i am not really sure if its gonna work..y dont u give it a try.Connect the camera to the computer and make sure the card is in the camera.And then go to the MY computer.....UNder My Computer ,look for a "removable disc" of the camera.just open it and check if u r able to open it....if u open it u will find a DCIM folder and once u click open it u will find all the pictures.....hope it works...i'll pray ya....lol...good day...
Posted on Oct 01, 2008
Broke battery cover
And now you can't use the camera? the cover must be closed complete. There is a switch, to check if the cover is closed. this is checked, to prevent damage to the memory card. When the camera is powered down while accessing the memory, the already saved pictures can become damaged.
You better contact an authorised service centre, for a repair of the camera.
Mar 23, 2014 | GE Power PRO Series X2600 16.1-Megapixel...
I cant use my cam the screen appear full card
Delete some pictures off of the memory card. If you don't have a memory card that's your problem. Your camera can only hold 1-10 pictures without a memory chip installed
Sep 21, 2012 | GE A830 Digital Camera
Cant find how to download my memory chip{pictures] into the computer. Did it once, but cant find how i did it, only thing that shows up is for a disc.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Sep 17, 2011 | Olympus Stylus 790SW Digital Camera
Camera did not have a disc in the package. My son started taking pictures and now i can't print them. Is there a solution? thank you
This camera does not use a separate memory card....only internal memory of 8mb. Since the camera only has a 1.3 megapixel resolution, it will hold quite a few pictures.You must use the included USB cord to connect the camera to your computer for downloading the pics. You must also install the included software first.
Oct 15, 2010 | Vivitar ViviCam V15 Digital Camera
MAMARY CARD PHOTO NOT REEDING
It may be that you have an older version of a camera that does not support a large capacity memory card. Before you panic, try to format the card in the camera. It would help to know excatly which model of camera you have.
Oct 06, 2010 | Cameras
Dear all, I bought my olympus camera (FE-320) since 2 years but i lost my wire to connect my device to the laptop. I know that i can use my chip memory card ( xD-picture card..M 1G) but it doesn't work...
Two solutions...you can get a replacement USB cord at stores like Walmart, Best Buy, etc....take your camera with you to get the correct size. Or, you could get a separate card reader and use it instead of the camera. This one is $13 at Walmart: 8abf15e.jpg
Sep 27, 2010 | Olympus Cameras
USB Device Not Recognized, Works with Other Camera, Same USB Cable
Looks as if the usb device of your camera? is malfunctioning. Try putting in the MMC/SD/MS Duo card into a dedicated card reader to get the pictures and videos or in the other camera.
In this instance your USB cable is the medium connecting the usb device (camera) to your pc. As the other camera and same cable are working fine this means that both the cable and your pc's usb port are working properly as well. Time for you to change the device from which you are trying to read information from.
Sep 29, 2009 | Cameras
MY COMPuter doesnt read the memory card, i cant
The hardware may not be connect.Go in control and press hardware then you reinstall memory card drive.See if that works
Aug 27, 2009 | Cameras
Card error coming up constantly
there is a chip in the device that lets you to know whats in it. maybe its broked down.
Jun 02, 2009 | Casio Exilim EX-Z55 Digital Camera
Cant take photos and the LCD screen says "Memory card is locked. Slide lock to 'write' position"
I don't own this camera but My guess is your memory card is in a LOCK SETTING you need to move the memory card to unlocked " wrirte " so you memory card isn't locked.....
Step 1 remove the card from you're camera
Step 2 there is a small little side on the side of the memory chip move that to the unlock position.
step 3 insert the card and start shooting!
Apr 16, 2009 | Nikon D90 Digital Camera with 18-105mm...
Cameras Logo
41 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
