Question about Konica Minolta magicolor 5430 DL Laser Printer
Konica Minolta 5430DL error code 111112
I changed the yellow toner on my Konica Minolta 5430DL and it started printing very stripy colours, greens instead of blue etc. When I checked the status monitor it showed "undefined PJL status code: 111112" and suggested I re-install the driver. I have had a few error codes in the past callin for this action which turning the printer on and off has fixed but this time it has not cured the problem. The status monitor is now showing the printer as unavailable. Should I re-install the printer?
I couldn't find the install disks so downloaded the driver from the Konica website, un-installed the software and re-installed it. After calibrating the colours everything seems fine now.
Posted on Oct 02, 2008
Yellow deposit
Remove the Yellow Drum unit, Check the drum for any toner. The drums should be clean and I believe a Green color. If you see any toner on the yellow unit replace the unit. Some models have a charge cleaner built into the image units, if that is the case with yours you will see a light blue knob on the front of the unit. Pull this knob in and out about 5 times to clean the units charger this may correct the problem without replacing the yellow image unit.
Mar 09, 2010 | Konica Minolta Magicolor 5670EN Color...
Yellow toner usage is high , ventilator at back panel is yellow. Cannot print pure red colors
I would guess the yellow toner cartridge is leaking. Clean out the printer, including the fan and air path to the back panel vent, and inspect the mechanics of the yellow cartridge section. If no abnormalities are seen there, try a different yellow cartridge. Stray or excess yellow toner might mess up all of your colors - do you see green blotches in blue areas?
If you had normal toner usage, I'd suspect a problem with the corona wire for yellow that lets the toner blow away from the paper instead of adhering. That would leave your reds with a magenta hue and paint the fan yellow.
You could even have both problems if toner powder has contaminated the high voltage contacts.
Dec 09, 2009 | Konica Minolta bizhub C351 All-In-One...
KONICA MINOLTA magicolor 5430DL don't recognize paper
The machine keeps track of what paper was reqested last, and asks you to change paper if the new job is different. I get the "put media" message and have to open and close the drawer if my next print job requests a different paper. So I suggest you gently open and slam the drawer a couple of times, or see if you can find the sensor switch that monitors whether the drawer is open. Also check if your paper guides in the drawer are clicked in place.
Sep 03, 2009 | Konica Minolta magicolor 5430 DL Laser...
I think its a problem with the cyan (blue) toner...when i print a colour document the printer works but makes a very stranhge (high-ish pitch) noise and the colour which should come out green comes out a...
The Cyan toner cartridge is jammed, it needs to be taken out and try and move the white plastic gear round a bit to free it. It normally is very stiff and wont move much, but if you can move it a fraction that will do. One thing, did you overfill the cartridge with toner? sometimes that will cause them to seize up.
Delboy
Jan 25, 2009 | Konica Minolta MAGICOLOR 2300W LASER...
To change opc drum in konica minolta
To Change OPC DRUM UNIT in KONICA MINOLTA 2300 w
Switch Printer Off
Open Front Door Cover
Remove Waste Toner Box
Lift Transfer Belts Blue Knob until it's placed at 11 o'clock. (it's directly behind the waste toner box)
The OPC DRUM UNIT is directly under the BLUE KNOB
SQUEEZE HANDLE and PULL OUT the OPC UNIT
Be VERY CAREFUL NOT TO SCRATCH THE GREEN COLOURED ROLLER on the OPC DRUM UNIT.
Replace new OPC DRUM and turn BLUE KNOB of TRANSFER BELT back to 7 o'clock position
Replace Waste Toner Box, Close Front Cover and Switch On.
Status Display will show OPC Drum at 100%
(You can also replace the fuse in the OPC DRUM UNIT and save yourself HUNDREDS on a new one)
I posted this on another solve problem previously, worth looking at.
Jan 06, 2009 | Minolta magicolor 2300W Laser Printer
Konica magicolor 5430 smuding all over page
also there can be problem with the waste toner pipes, that the waste toner wont go away and smug the page. check waste toner box also check transfer belt and pc drums that they are clean.
Jun 03, 2008 | Konica Minolta magicolor 5430 DL Laser...
Konica minolta 5430dl colour printer
13D0H: Parameter Chip failure
Unplug the power cord and plug it in, then turn
OFF and ON the Power Switch.
the PWB-A may be faulty.
May 21, 2008 | Konica Minolta magicolor 5430 DL Laser...
Printing colours?
solutions :
Try changing consumables, if near emty or maybe with defect.
If it does't help, there may be problem with cleaning system, then you have to call for service.
First try consumables
Apr 11, 2007 | Konica Minolta magicolor 5430 DL Laser...
Konica Minolta magicolor 5430 DL Laser Printer Logo
343 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
