Transceivers
Problem for Transceivers
Generic problem for all Transceivers
Problem with a Kenwood TS 2000 Amateur Rad...
By Ham Radio Op on Oct 01, 2008
Fault description: About 2 years ago, the rig started off by randomly turning itself OFF any time from 2 hours after initial power on, as time progressed the fault became more frequent and time to switch-off dropped down to less than 5 minutes recently. And until recently I could switch the rig back on, after waiting a minute or two and it would often perform OK.
However; once the self switch off time progressed down to less than 3 to 5 minutes as noted above, the rig would refuse to operate correctly, in that it would come back on, on a different ban or a memory frequency, or, on the alternative VFO, (that is if it were initially on VFO A , when switched back on it would come back on VFO B). I have checked the Lithium memory support battery, it is OK at 3.1 Volts.
The rig had also started having difficulties with the Processor in & out gain settings and mike gain settings not being stable & repeatable! I suspect all part of the same problem. It (the rig) has never been fiddled with at all just used as is out of the box, although on SSB it never made better than 50 Watts out this however never was a worry to me!
Best Solution
posted on Oct 15, 2008
Helpful)
GRITTY
Rank: Apprentice
Rating: 85%, 1 votes
73s I have heard of similar problems and some were heating related. the best is to check if your rig is heating up causing it to switch off and lose memory when switched back on. I have a buddy who had an unusual experience where he actually dropped frequencies so low that he could pick up ordinary radio frequency and also go into bands like 27mhz and 25mhz. But once switched off, the rig worked normal again. If you are experiencing heat problems then i suggest you put in a fan and remove all dust from inside the rig. You could probably also be having problems with power supply either internal or external. If all else fails, refer to a good repair shop this type of radios are very sensitive.
Was this helpful?
Yes
No
Popular Solutions for Transceivers
Questions and Unsolved Problems for Transceivers
Answer
i have a 48 volt club car. i have two working chargers. when i plug it in nothing happens not even a... (More)
Answer
iam unable to trunk the port to connect to layer 2 switch from layer 3 switch
Answer
I have a W300i brand new which is flashing on and off since I tried to charge the battery. Can you... (More)
Answer
How do i reprogramme my Gibidi 4-Button Transmitter? I have found instruction that says hold two... (More)
Answer
i HAVE ONE OF THESE ON A NORTLE SWITCH AND WAS WONDERING WHAT THE POLARITY LIGHT BEING SOLID WAS... (More)
Describe your Transceivers problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Transceiver Experts
Top Computer & Laptop Repairmen
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
