Question about Opticon OPN 2001 Mobile Data Collector Barcode Scanner
Error synchronising clock
I am not able to scan anything, when i connect the scanner to my computer and click on scanner data transfer it says error synchronising clock
I think after the installation of the scanner driver and the program you should check for the properties and then again restart the computer. if not re install the whole driver and program for the same. your problem would be solved
Posted on Dec 12, 2009
How to save my messages in my memory card and in my PC.my mobile model is samsung champ
Use connectivity software and click synchronise. All data will be transferred to computer. Data wont be erased from mobile
Jul 18, 2011 | Cell Phones
How do I scan a document to my computer
  • First open the program that control the scanner.
  • Look for a command or section that say scanner or scan and click it.
  • Put the document to scan in the scanner.
  • Click the command in the program for scan the document
You can also use the scan tool that Windows provide that is really easy to use.
Jun 08, 2011 | Computers & Internet
I would like to transfer photo from my w380 to the desk top to start a photo album
To synchronise/data transfer your phone using PC Suite:
Connect the USB cable to the computer and the phone.
In the phone: When you attach the USB cable to the phone, a USB connection window appears; select Phone mode.
Start the Sony Ericsson PC Suite.
In the computer: The first time you connect your phone to the computer, you must identify and name the phone. Wait for the drivers to be installed (this is done automatically).
In the computer: Select Synchronisation, and select your items to synchronise.
To start the synchronisation, click the Start sync button.
Jun 17, 2010 | Computers & Internet
I have albums in my pc and want to transfer the albums to my nokia 97?
Not sure if you meant photo album or music album??? Here is the steps for both, music first:
Transfer music from a
computer
You can use the following methods to transfer
music:
● To install Nokia Music to manage and organise
your music files, download the PC software from
www.music.nokia.com/download, and follow
the instructions.
● To view your device on a computer as a mass
memory device where you can transfer any data
files, make the connection with a compatible USB
data cable or Bluetooth connectivity. If you are
using a USB data cable, select Mass storage as
the connection mode.
● To synchronise music with Windows Media
Player, connect a compatible USB data cable, and
select Media transfer as the connection mode.
To change the default USB connection mode, select
Menu > Settings and Connectivity > USB > USB
connection mode.
This works for music, photos, or video:
Select Menu > Settings and Connectivity >
USB.
To have the device
ask the purpose of
the connection
each time a
compatible data
cable is connected,
select Ask on connection > Yes.
If the Ask on connection option is turned off or you
want to change the mode during an active
connection, select USB connection mode and from
the following:
● PC Suite — Use Nokia PC applications such as
Nokia Ovi Suite, and Nokia Software Updater.
● Mass storage — Transfer data between your
device and a compatible PC.
● Image transfer — Print images with a
compatible printer.
● Media transfer — Synchronise music with Nokia
Music or Windows Media Player.
Here is the link for your manual online:
http://nds1.nokia.com/phones/files/guides/Nokia_N97-1_UG_en.pdf
Oct 22, 2009 | Nokia N97 Cell Phone
Scanner problem
Hi s2009edwards, double check the USB data cable from the printer to the computer. Power off the printer. Than, unplug the data cable connected to the printer & re-connect it. Follow the data cable to the PC & unplug the cable & re-connect it. Power on the printer & wait until its done making noise. Try scanning again. If it fails to complete & you receive the same error message than buy a new printer data USB cable & replace the old one.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=76&SRCCODE=WEBGOOCOMP&cm_mmc_o=7BBTkwCjC-p8ByplCjCabTwyKbywgfCjCmH4
If the HP director software is installed (Which it should be).
You can open HP printer software there should be an HP icon down by the clock. Right click on it once & left click open or launch. If you did not install your HP printer software suggest you do so.
Mike
Dec 17, 2008 | HP OfficeJet 6110 All-In-One InkJet...
SYNC LGKU990 to PC
This is what sorted it out for me.
When you go through the connection wizard on the LG PC Suite take note of the port number that it is using.
Then go to device manager(for win xp go to start/control panel/system, click on the Hardware tab then device manger) on your pc. Expand Ports(COM & LPT) and right click on LGE Mobile USB Serial Port and select properties. Take note of what port is indicated in brackets. Go to the Port Settings tab and select advanced. Change the com port number to what LG PC suite was using. Select OK, OK and try connecting again with the Wizard and see if you can transfer data etc
Let me know if that helped.
Sep 04, 2008 | LG KU990 Viewty
When trying to scan, 7210 doesn't see/recognize networked computers
From each computer, you need to run the HP Director. When opened, click on SETTINGS, then SCAN TO settings to configure. This way it will transfer data to the scanner so that when at the scanner, that computer will be in the list of places to send a scan job.
Jul 25, 2008 | HP Officejet 7210 All-In-One InkJet...
Scanner will not connect to PC
Make sure that the scanner file utility is running on the computer you are scanning to. Go to Start - Programs - Scanner User Software - Scanner File Utility. It will open in the system tray by the clock on the PC. Try to scan again. If still have the same error, go to the webpage of the scanner (just enter the IP address of the scanner NIC in Internet Explorer. Go to the bottom left side of the page and click Scan to PC Destination List. Click on the number to the left of the name you are scanning to. check the IP address listed on the webpage and make sure it matches the IP address of the Computer you are scanning to. One of these should fix it.
Please remember to rate you answers.
Dec 28, 2007 | Kyocera CS-2550 Black and White Copier
Getting error code Code[ffff:0024]while scanning
while i am trying to scan the images .. i am getting the error code like Code[ffff:0024] while warming up the scanner, besides a sound from the scanner making it power off (light inside the scanner goes off ) so that i could not get scanned anything ... what will be the reason ? please suggest me the trouble shoot kaarthik
Apr 14, 2007 | Acer Scan to Web 3300U Flatbed Scanner
Opticon OPN 2001 Mobile Data Collector Barcode Scanner Logo
153 people viewed this question
Top Opticon Computers & Internet Experts
David Payne
David Payne
Are you an Opticon Computer and Internet Expert? Answer questions, earn points and help others
