Question about Kenwood Car Audio & Video
I have a kenwood dpx6100md head unit and cant seem 2 get the display 2 work. we got power 2 the unit but not sure on the wiring details
SOURCE: Kenwood CD changer wiring diagram
Posted on Jan 18, 2008
  • 7 Answers
SOURCE: Wiring a Kenwood KSC-WD250 Subwoofer
7e83231.jpgi had the same problem Here is the diagram i used from someone else on fixya.  Thank you.
Posted on Jul 21, 2008
  • 60 Answers
SOURCE: i have tried to wire
i would try and make sure that the power antenna is grounded like it should be!
Posted on Dec 07, 2008
  • 63 Answers
SOURCE: cant get my head unite 2 work??
You May Want To Re-Check Your Wire Connections If Problem Persists After Everything Is Properly Connected And There Are No Breaks In Connectivity You May Want To Think About Takeing the product Back
Posted on May 10, 2009
  • 417 Answers
SOURCE: new system, head unit jvc, mono amp kenwood,
No to be jerky but, bring it back to the "professional Installer".
Posted on Apr 23, 2010
I have a kenwood kdc 241 head unit about 4 months old which displays protect on the screen, it was new when i got the car & I removed it to install my own jvc chameleon, now I want to sell the car I...
It might be. Normally protect turns on when you have something wrong. A power wire goin in the ground or polarity of the speakers (+/- wires) are crossed or especially if 2 speaker wires are touching. If not hooking up the 2 green speaker wires for example, dont twist them together. seperate all non used wires
Jan 12, 2011 | Kenwood Car Audio & Video
Dvd screens in headrests are not getting power
The problem seems to be that the video out from the kenwood head unit is either faulty or the leads from the head unit to the monitors are faulty. Have you checked to see that the head unit when playing a DVD is set on ZONE 2 so that it transfers the video signal to the headrest monitors?
Jul 12, 2009 | Kenwood DDX-6019 Car DVD Player
My Kenwood KAC-929 gets power but DOES NOT put any sound out. Whats My Possible problem(s).
Hello Spicer_kyle6,
Possible problems: 1) No output from the head unit. Try a different set of preamp outs. 2) No input to the amp. Check the RCA's and make sure that they are good and coming from a functioning preamp or subwoofer output on the head unit. 3) Input gain turned off or down too low. 4) Speaker wiring shorted, grounded, or open. Check all wires. 5) Speakers defective. Connect to a known good output to test. 6) The amp itself could be defective and still show a power-on indication.
Hope this helps.
Apr 28, 2009 | Kenwood KAC-929 Car Audio Amplifier
Aftermarket Stereo connection
hi there
if you matched all the wires from the harness to the kenwood deck and its not working don't worry you just missed the last step........(all wires attached that a colour coded connected)
simply turn your car on the front of the kenwood deck there is a SOURCE button with all units it could be a (S, SRC, Power) hold the source button down till your kenwood unit powers up ..........if your unit still doesn't work check the fuse on back of kenwood unit should be a 10a fuse (blue) if the fuse is fine put the unit back in check the fuse panel on driver side dash with the door open you will see this panel pull it off (some describe the fuse panel as looking like an air vent but its not its a handle to open) now on the panel that you just pulled off there is a fuse diagram on the inside look at it find radio fuse it will be a (blue fuse) located in the top row of fuses check it if blown replace and unit should work.............if this doesn't solve the issue than its a (sneaky) fuse not to many people know about if you pop the hood of your car there is a black plastic panel located just below the battery pins and just above the driver head light (usually black box with yellow writing on this there are mini fuses check all of them do not touch the black relays in there just the small tiny fuses the fuse you will look at should be yellow 20a (this fuse is closest to engine and comes after the abs relay if you look inside the lid you took off it will have fuse locations cant remember which one it is for sure but check see if your kenwood unit powers up if not the last option is to ground to the black wire from back of kenwood unit to metal frame.............this last part is also done if your unit does power on but your car lights don't work if this happens ground the kenwood unit to the frame of car and open up fuse panel on driver side dash replace the blown fuse for lights or radio (make sure the kenwood unit is grounded to the frame before replacing the fuse in dash panel............if this doesnt help you than i would assume the kenwood deck needs to be repaired by kenwood.......
good luck
hope i was able to help and sorry this list is so long
Feb 26, 2009 | Car Audio & Video
Power unit on test for Kenwood kgc 7043
should not need the head up unit and start testing continuity along wire an board.possible break in connection.
Feb 24, 2009 | Kenwood Car Audio & Video
Seakers shorting out... wiring or amplifyer?
Sounds like a wiring problem. check the connections on whatever is easier first (radio/speakers) if the connections are good you may have to trace the wires to see if there is a break or short somewhere.
Nov 11, 2008 | Kenwood DPX-MP4030 CD / Cassette Player
2 problems, what are the red and yellow wires on a Kenwood kdc-mp2028? and can you install a used kenwood without the remote?
You can use the head unit with no remote - that's just an accessory. As for the wires, the red is switched power (this gets wired in so that it only has power when the key is on - when the key is off, it turns off the radio). The yellow is constant 12v power (to maintain power to the head unit so that memory settings, treble/bass settings, and the clock are maintained when the vehicle is shut off).
Sep 24, 2008 | Kenwood Car Audio & Video
Kenwood head unit CD and AUX sound not working
I fixed the sound problem with tech support from Kenwood. I had the blue wire from the Kenwood which is the antennae turn on wired to the amp turn on for the vehicle (2001 Blazer with Bose factory stereo). This is how I was told to wire it from the installation tech where I purchased the wiring harness. The tuning played fine because the Bose amp turned on when I played the tuner but when I played the cd or aux the amp turned off, thus no sound. The kenwood tech toldd me to wire the blue/white wire to the amp turn on for the vehicle so the amp would be on when ever power to the Kenwood was on. I rewired this way and everything works great now.
Jun 09, 2008 | Kenwood KDC -X815
No Sound Through Speakers
Hi Jake,
If you haven't done so already, I'd try double checking the speaker wiring, you may have some exposed or badly kinked wires behind the unit.
Matt Coyote
Feb 20, 2008 | Car Audio & Video
Kenwood Head Unit Making a Loud Popping Noise at the Start and Finish of each track
my mate had the same problem with his stereo in his case it was power related if u are usin crimp connections or any other form of connection to the speakers or the subs that is not a soldered joint it could be that we had to re wire his system with soldered joints and it worked ok. but other than that it could also be ur wires themselves with power cutting out cos the poppin sounds to me like the power cuttin out or in. other than that i really cant think of anything hopefully that helps
Jun 11, 2007 | Kenwood KDC-MP228 CD Player
Car Audio & Video Logo
119 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
