Question about JVC Audio Players & Recorders
Hello, I've been having a problem with my JVC RX-D302B 7.1 Receiver. Whenever I try to power it on, the blue power light comes on for a moment, then it clicks off. I'm planning to take it to a repair shop, but I was wondering if someone here had an idea on what was causing this problem--or if it was something I could fix (I have a soldering iron from my ITT days)? Thanks!
  • Tennno Oct 02, 2008
    Ahh. Thanks for the timely response! I'll just send it to a shop then.
    Scholar:
  • 142 Answers
Unit is going into protection mode because the amplifier output stage is shorted. Measure output voltage of the speaker lines coming out of each output channel...front/center/rear...take measurement before the channel speaker line protection relay. If any voltage is present then that is the output channel that is at fault. Replacement parts are available to the consumer through tritronicsinc.com. If you have experience with a volt meter\checking transistors\soldering it is something you can do. If not it should be left to a service shop. Have a great day!!
barneyluc
Posted on Oct 01, 2008
Have jvc rx-2020v receiver with mono rca out for sub and trying to hook it up with polk audio rm 1000 w sub woofer with +/- terminals for both left ane right channels plus blue terminal(?). How to?
Your Polk Audio subwoofer is a passive sub and your JVC mono output is for connection to a powered sub. If the JVC does not have an amplified output for a passive sub, you'll either need to get an amplified sub, a different receiver, or buy a dedicated mono subwoofer amplifier.
Oct 14, 2016 | JVC Audio Players & Recorders
How do i connect my JVC screen tv so that i can hear out of my speakers
If your JVC TV has AUDIO OUT outputs on the rear and a provision in the initial set up screen to disable the internal speakers, you can connect to your Yamaha receiver and enjoy improved sound.
Dec 14, 2014 | Yamaha RX-V471 Receiver
Connecting to samsung smart tv
For digital connections on your TV ( unknown model) read on page 7
[PDF] RX-6000VBK / RX-6008VBK INSTRUCTIONS AUDIO/VIDEO - JVC
Sep 30, 2012 | JVC RX-6008V Receiver
JVC RX-801V - No sound from right channel in speakers or headphones.
I'd troubleshoot first, even though you've already tried the headphones (good thinking). Get a battery (AA battery works) and put the black and red wires on opposite sides to see if the speakers are working.
Is there a menu of settings on the jvc, and is it set to 5.1? Just trying to help...
Jan 15, 2012 | JVC RX-8010V Receiver
Won't power up
Yes this is a power supply problem,you better replaced the regulator IC there or replaced the whole board,so it will works normal again..
hope this may help you;
DON'T FORGET TO RATE:
Sep 04, 2008 | JVC RX-D302 7.1 Channels Receiver
JVC A/V Receiver RX 7042S - DSP NG
it seems the problem of your unit is in the power amplifier section,the IC chip there is defected that why only analog source .you better bring back to them the unit it is the only option, that is there back job...
Jul 03, 2008 | JVC RX-6042 Receiver
Getting no audio to game systems, pc connect won't connect
I also had the same problem when using my optical output for DBS and DIGITAL DVR/DVD.. you need to change the setting for this by on the remote changing to either analouge..rca sound input or Digital...for Optical input. The same problem cuaght me oput for a long time as well. The button is when you slide down the remote cover and the button is called analoug /digital
Dec 30, 2007 | JVC RX-D301S Receiver
Speackers
Hello 6423,
The RX-664VBK is capable of having 6 speakers connected to it, 2-front, 1-center, 2-surround and 1-powered subwoofer.
Hope this helps.
cancerags
Dec 28, 2007 | JVC RX-664V Receiver
JVC RX-6008v faceplate
have a jvc home theater with this next problem, when I turn the display lights up then see the name overload and shuts down the display, and it does not connect the speakers
Sep 27, 2006 | JVC RX-6008V Receiver
149 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
