Laptop keys are locked.
The keys are all locked except a few of them which are9,o,l,. and del. I held down FN and pressed F11 but nothing happened all the keys are still locked. Please Help.......oh yeah its a TOSHIBA LAPTOP.
    Scholar:
  • 188 Answers
I think you are the numlock mode. My keyboard uses SHIFT+NUMLK to change back to regular keyboard mode.
Posted on Oct 03, 2008
  • 661 Answers
Sounds like your keyboard may be faulty / not connected properly
this is also a common symptom of a keyboard spillage, which causes some of the membrane tracks to fuse / short, if this is the case then a replacement keyboard unit is required,
you can check the keyboard connection by removing the keyboard by removing the facia above the keyboard and remove the retaining screws, the keyboard should be connected by a fine plastic cable this is held in place by a socket with a clip that wedges the contacts agains the connector and holds the plastic in place.
check the connector cable is fully in place and retest.....if this is not resolving your problem, you need to replace keyboard, the PN of the keyboard should be listed on the reverse of the keyboard so just order replacement online using that PN to get the correct part (ensuring that it is for the correct location (as a US keyboard varies from a uk keyb etc....))
  • Gareth Cockram
    Gareth Cockram Oct 03, 2008
    in the mean time you can connect a USB or PS/2 keyb (if PS/2 port is available) which will allow you to type
Fn+num lk not working
There is no standard meaning to any Fn +Fx key combinations. It depends on the manufacturer and the laptop model.
Usually the Fn key works in combination with the Function (Fn) keys F1-F12, and maybe ESC.
In my Toshiba, there is an overlaid numeric pad that can be activated by pressing Fn +F11. Once the sequence is pressed the F11 key led remains lit, and the overlay active. Pressing the F11 key restores the normal keyboard. Fn+Num Lock does not do anything.
Please check you laptop's manual to familiarize yourself with the uses of the Fn key on YOUR computer.
Dec 19, 2013 | ASUS Eee PC 1000H Laptop
How do i disable the f keys
Hi There,
After a few hours of research, it looks like the function or F keys under windows are pre-programmed and there's not a whole lot you can do to change it. There are, however, a few options:
Keymapping software: Usually ships with (and free to download) logitech or other gaming keyboards. The software allows you to reprogram any key on your keyboard to do what you want it to.
Hold down Fn+F11, while still holding F11 let go of Fn. Some laptop users have reported that this turns off Fn keys. Also, Holding down Fn+Scroll lock or Fn+Num lock in the same fashion has had varied results.
Jun 06, 2012 | Compaq Presario Notebook Notebook
Keyboard of myASUS K50IJ-XA1 15.6-Inch Versatile Entertainment Laptop (Black) is locked How to unlock the same? Kindly help
Well, do you mean only the keyboard is locked? Can you boot the system properly? Is the mouse working? Which Operating System is running on your Laptop?
Here are a couple solutions you can try before you let me know the above queries.
1. Press and hold down the Windows Logo key on the keyboard while pressing the L key on the keyboard once. In other words, Press Windows Key + L once. If this doesn't work, don't forget to include the Fn key while pressing these two keys. Windows+Fn+L. Still nothing?
2. Turn off the Machine, remove the battery and unplug the charger. Leave it for at least 10 seconds, you can press the power On button on the laptop without the battery and the charger installed/plugged in. Now re-install the battery, and turn back On the machine. It should work.
If you need further help, if the problem persists, Let me know with the details.
Good Luck.
Thanks for using FixYa.
Jul 24, 2011 | ASUS K50IJXA1 156Inch Versatile...
My laptop, a Satellite #L455, is giving me numbers when I type in letters. This does not occur all the time but often when I'm playing games.
the letter that does is U,I,O,PJ,K,L,M it happens all you need to do to fix that problem is press the Fn buttin and while keeping this down it should be the F11 button make sure you look at the other F button as it will show you a little box with load of dots inside it if it is the F11 button then pressing this once will turn it back to letters this function is for when your doing calculations its easier to use it but some people dont like it you can turn it on and or off by pressing the Fn button and pressing the F11 button
Jun 29, 2011 | Toshiba Computers & Internet
What is the third lock light, I have a Cap Lock, a Numerical Lock. What is the third one?
I beleive it is the scroll light:
Fn+F1 Suspend switch
Fn+F2 WLAN switch
Fn+F3 Keyboard light down
Fn+F4 Keyboard light up
Fn+F5 Brightness down
Fn+F6 Brightness up
Fn+F7 LCD on/off
Fn+F8 LCD/CRT switch display
Fn+F9 TouchPad Lock
Fn+F10 Volume on/mute
Fn+F11 Volume down
Fn+F12 Volume up
Fn+Ins Numeric Key Pad on/off
Fn+Num Lk: Scroll Lock on/off
Fn+Del Scroll Lock on/off
Fn+Space Power 4Gear
Fn+C Splendid
Fn+V: Life Frame
Jun 20, 2011 | ASUS 90-A4C1K1000 Keyboard
My samsug notebook when i press the m key changes to 0
ur num lock is switched on switch it off by pressing the fn key and num lock key
Sep 08, 2010 | Samsung NC10-14GW Notebook
Can you tell me how to switch my laptop keyboard
Hold function (Fn) key down and press the key on the top row that has a sign (picture) showing a padlock insde a square. (Num lock key) Normally "scroll" key
Apr 02, 2010 | Gateway 2520915 Keyboard
How to find and turn on scroll lock for toshiba satellite A305
To turn on Scroll lock you will need to press and hold the FUNCTION Key (FN), this is located beteween the Left CTRL key and the Windows key.
With FN Held you then need to press the F12 key on the keyboard, this will enable scroll lock.
just repeat the process to turn it off
quick keys:
FN + F11 = Num Lock
FN + F12 = Scroll Lock
Oct 17, 2009 | Toshiba Satellite A305-S6834 Notebook
Toshiba Satellite A45-S250 non-numeric keys locked
Your keyboard logic chip is in need of therapy.
Replacement of keyboard warranted.
Now, I thought that it might be a redesignation of your language code, but that proved not to be the case.
Mar 29, 2009 | Toshiba Satellite A45-S250 Notebook
ACER 5620 Extensa keyboard problem.
Hi, your Laptop has a integrated keypad. You or someone else might of turned this on, thankfully it is easily fixed. Just follow these steps,
1. Find and press the "Fn" key.
2. Find the F11 key there should be in blue letters "NumLk"
3. Press F11 while holding down the Fn key.
This should turn off the integrated keypad
Hope this works ~Kaleb~
Nov 12, 2008 | Computers & Internet
Computers & Internet Logo
531 people viewed this question
David Payne
David Payne
