Home | PC Desktops | I have a Presario 1700T
PC Desktops
Problem for Compaq PC Desktops
Generic problem for all Compaq PC Desktops
By waynewong on Oct 01, 2008
I have a Presario 1700T notebook. It freezes after 5 minutes of usage. I think it's heat related. How do I disassemble the laptop to replace the heatsink/fan?
Comments:
Oct 05, 2008
- After I opened 10 screws, I can separate the keyboard from the lower case for only about half inch. Are there more screws? If so, where? Also where do I look to see the "long" screw? Thanks, Wayne
Solution #1
posted on Oct 03, 2008
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
A little more detail on my disassemble problem. I opened 10 screws (4 at the top, 3 middle & 3 bottom), the keyboard/palmrest still will not separate from the lower case. I don't see the "long" screw. More suggestions? Thanks, Wayne
Solution #2
posted on Oct 01, 2008
Somewhat Helpful)
Temab
Rank: Wiz
Rating: 79%, 48 votes
yes, to do that turn over your Laptop and let it relax on a well balance area then remove your battery slide out your hard drive and then use your appropriate Screwdriver and open the screws at the back then look to your long screw that comes out its meant for the Keyboard then turn over after loosing the screws then raise your keyboard a little about 45 degree then push it out at the back u will find a cord at the back so transparent be gentle when removing those part and target those place in case of puting them back then your palmrest pull-tab that is attached to the palm rest flex cable connector to remove it from the interface connector on the system board
Notice: Carefully separate the palm rest from the buttom case to avoid damage to the palm rest.then after making it open u see the microprocessor thermal cooling assembly then loosen the four captive screws that secure the processor then u have the thermal heat sink is with the processor remove it and make sure u add the cooling paste to ensure well cooling and replace as required u for open.
bye
rate this solution .
Was this helpful?
Yes
No
Popular Solutions for PC Desktops
Questions and Unsolved Problems for PC Desktops
Answer
Looking for a replacement for a Logitech wingman force 3D Joystick used mainly with Microsoft flight... (More)
Answer
The screen on my pc keeps getting a green tinge to it, ive tried a diferent screen, but same thing.... (More)
Answer
how do i configure my sony vaio to connect with my lg plasma and kenwood receiver through hdmi... (More)
Answer
My Mother has been asked to play a recently donated Technics U60 keyboard/synthesizer/organ at the... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Compaq PC Desktops:
Top PC Desktop Experts
Rank: Guru Guru
Solutions: 1447
Experience: Self taught, Keep up with the manufacturer's service manuals, Beta Tester
Ask Me
Find more PC Desktop Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
