Question about OKI MICROLINE 521 Matrix Printer
Printing settings My OKI Microline 521 is only printing half a page and the text is not vertically straight? How may I resolve this issue?
    Sergeant:
  • 208 Answers
Hi,I have a doubt, whether the perview is good and only the print out is bad or both are bad.
Anyway i am giving solutions for both.
The Statement or Report Looks Fine When Previewed, but Looks Bad When Printed If the appearance of the statement or report when printed differs from its appearance when previewed, this may indicate a problem with the printer driver (such as corruption of the driver files). Make sure you are using the most current version of the correct printer driver for the operating system on your computer. For example, a printer driver for an OkiData MicroLine 390 for Windows 98 may not work well at all when printing from Windows XP.
  1. If you need to check for a different printer driver, begin by checking the installation disk or CD-ROM that was provided with your printer.
  2. If you can't find the driver you need on the installation media provided by your printer's manufacturer, check the CD-ROM from which your operating system was installed (i.e., your Windows CD-ROM).
  3. If you can't find the driver you need on your Windows CD-ROM, or if you need to try an updated version of the driver you are currently using, check your printer manufacturer's Web site.my.okidata.com/pp-ML521.nsf/openingdrivermenu?OpenFrameSet
The Statement or Report Looks Bad Whether Previewed or Printed There are many factors that can contribute to undesirable printed output, such as margins, fonts, and custom paper sizes. Use the following steps to troubleshoot this problem.
  • Try using a different font size. See if there is a separate font size available for the same font family (e.g., 15 cpi vs.10 cpi).
  • Try adjusting the page margins and printer offset adjustments in the Page Setup window.
  • Check the printer driver properties to determine if a custom paper size is specified. If not, you may need to specify one. For example, when printing checks that have only one stub, you may need to set up a custom paper size of 8.5 inches wide by 7 inches tall. Conversely, if a custom paper size is incorrectly selected, printed output of reports and statements may be adversely affected.
  • In the Advanced Printing Features window, select the Optimize for Print to File check box and clear all other options and check boxes.
  • Try temporarily renaming the STI.INI file and restarting the Tabs3 or PracticeMaster program. The STI.INI file holds all of the printer settings. If this helps, you may have to recreate the margins, font selections, and other settings used for printing since that information is stored in the STI.INI file. If this does not help, delete the new STI.INI file and rename the original file back to STI.INI.
  • Is the printer configured to emulate another type of printer? Consult the printer's manual and/or the printer manufacturer's Web site to determine if the printer is able to emulate another type of printer such as an IBM Proprinter. If you have tried all of the internal fonts available in the printer's current configuration, it may be beneficial to configure the printer to emulate a different type of printer and then install the corresponding printer driver. Then you can test each of the internal fonts available in the new driver.
  • Once your printing issue has been resolved, check the printed output to ensure that lines are not wrapping or breaking when they should not. Make sure the margins all appear correct.
  • When you are satisfied that the printed output is completely correct, be sure to look at a preview of the same print job, to ensure that the preview is legible. For some printer drivers and fonts, it may be necessary to make a second installation of the printer that uses TrueType fonts. This second installation would then be selected whenever you need to preview reports or statements, and the original installation would be used for the actual printing.
Hope my info solves your problem,
Thanx for using fixya.
Posted on Oct 01, 2008
I the printer is not printing the top of letters instead it is dragging that ink across the paper
Look at the print head for jewel failure. AFTERMARKET ribbons lack requried lubrication for this style of printer. If you see wear, replace the head. There are remanufactured heads available that have a lubrication wick installed that helps this issue.
Sep 28, 2010 | OKI MICROLINE 521 Matrix Printer
Printing does not conform to the spacing of the pages on A3 continuous stationery
kindly set the page lenght and the font size and mode in printer setup by going in to printer menu by pressing the pause and menu button.
Feb 11, 2010 | OKI MICROLINE 521 Matrix Printer
When it prints there is a line through the text printed that does not print and i need to know why it started printing like that all of a sudden. So it will print a line of text but there is a part of the...
Sounds like the print head is at fault. The print head is actually a vertical line of small wires that move in and out to form the dots as the head moves across the page printing one row of characters at a time. One of the wires has failed. While it is possible that cleaning the print head with contact cleaner will resolve the problem, it might be time to replace the print head, or likely buy a used working replacement printer at less money than the cost to repair.
Jan 18, 2010 | OKI MICROLINE 321 Turbo Matrix Printer
Rolling halfway down the page
is the form tear off on?
if it is try changing it to off
Dec 03, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Printing
It sounds like the 'form length' is misset.
Check the initial setup settings.
Aug 20, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Printing trouble
I think your alignment is out you need to get the printer serviced and aligned.
Dezzi
Apr 10, 2008 | OKI MICROLINE 521 Matrix Printer
Oki Microline 320 Turbo page alignment
This sounds like a problem in the computer program that is sending the prints to the printers....especially since it is happening in several of them.
Jan 23, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Page advance problem
print out your menu of the printer and load the IBM Proprinter driver in windows ,your printer default driver is IBM Proprinter this will sort out the problem.you have probably loaded a OKI driver while the printer is set for IBM.Hope this helps.
Dezzi
Oct 16, 2007 | OKI MICROLINE 320 Turbo Matrix Printer
Printing in one direction only
Your printers alignment is out that is why it prints only in one direction.
Dezzi
Oct 11, 2007 | OKI MICROLINE 521 Matrix Printer
OKI MICROLINE 521 Matrix Printer Logo
510 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
