Question about Canon Office Equipment & Supplies
Mf8100 keeps displaying paper jam with red light flashing have pulled everything i can possibly find. can not find any jammed paper anywhere.
  • PRAYER MAHLALELA Oct 03, 2013
I used a bit of strapping cable and slid it up between where the paper first goes into the printer from the paper tray and found there was a bit of paper there. that fixed the problem.
Posted on Oct 02, 2008
Keeps flashing up error and light a b c keep flashing
you either have a paper jam or the scanner module has jammed. open the printer and check the paper path for possible jams. then open the scanner lid and make sure the scanner light bar is in the home position at the end of the scanner deck and not stuck mid path.
Feb 27, 2012 | Canon Office Equipment & Supplies
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Canon FC 120 Photocopier. Red Paper jam light keeps flashing
hi,clean any sensor & clear any hide misfeed sheet.send me result.
thank you.
May 31, 2009 | Canon PC-160 Black and White Copier
Paper Jam error - red light flashing, but no paper jam!
There may be some tiny shard of paper stuck in some inaccessible part of your printer. Examination with a bright light source may help you find it.
Sep 17, 2017 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Xante 1200, paper jam front. Red light is blinking without a paper jam.
PROBLEM: Paper Jam. XANTE 1200, Tabloid size, B&W, Printer —Red light blinking fast indicating paper jam upfront. If you checked everything, trays, ink cartridge etc., and see no paper jam anywhere, take the top cover off and look inside the (head) for the jammed paper! This printer is problem free. It has given us the best service for many years.
Michael J. Frangos, Baltimore, Md.
Feb 04, 2009 | Xante AW 1200 Laser Printer
Flashing red light - no paper jam
I had this problem and couldn't figure out until I opened the front, pulled out the toner cartridge and found a paper jam.  Removed it and now I have the green light.
Oct 23, 2008 | Brother HL-2040 Laser Printer
Brother 5250
I had the same problem on 4 Brother HL-5250's, I checked the whole printer, and couldn't find a paper jam, yet the red printer light wouldn't shut off. I finally followed the instructions on Brother's website for removing a paper jam, and the solution for all 4 printers was paper stuck in the fuser cover. See below on how to open the fuser cover.
Pull the tabs at the left and right hand sides toward you to open the fuser cover (1).
  2. Hint
  3. There are 2 kinds of covers at the rear of the printer. Please make sure to open both the back cover (step 7) and the fuser cover (step8).
  • May 27, 2008 | Brother HL 5250DN Laser Printer
    Red Paper light keeps flashing
    Try to find thge combination of buttons that reset the printer. there are many possiblities due to the modles - but try pressing any 2 and whilst holding them down switch off and then on again. Also this utility could proce use full. When it is loaded -right click the task bar icon.
    Oct 02, 2007 | Epson Stylus C86 InkJet Printer
    Can't print - paper light is on
    turn the printer off, count to ten, then note the light sequence ie: flashing organge solid orange, flashing green or solid green
    Jul 25, 2007 | Brother HL-5250dnt Laser Printer
    211 people viewed this question
    old marine
    old marine
