Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Red crt tube
My philips hdtv's red tube just shot down,, i opened it and it still not totally shot down, but it light so dimmed that it turn look like its busted,, what do you think is the problem? is it have to be replaced?
  • Philips Master
  • 3,459 Answers
I'm parting out the same set and may have a spare red tube if you are interested.
Posted on Oct 20, 2008
    Problem Solver:
  • 21 Answers
IT IS PROBABLY TIME TO CHANGE IT OR THE LIGTH DIFFUSER THAT SENDS THE LIGTH TO THE TUBES OR LAMPS IS MALFUNCTIONING
Posted on Oct 03, 2008
Screen is red and I cannot adjust it enough to get the red out
Problem is going to be in the Green and Blue Tube ,you need to change the Coolant Fuild out and out in New,Philips is well known for having Bad Coolant fuild in the G/B Tubes.
With Back Off and TV on Look down inside of each Tube you should be able to see a Clear picture, in each Tube, If you do Not then you need to change out the coolant fuild.
You also have a Screen/Focus Control Block, it controls the Screen Drive and Focus to Each Tube R/G/B 3 controls on top and 3 below them. Top 3 should be for Focuse and Bottom 3 Screen Drive /Brightness to each Tube.
Now in order to aline for Correct Color you will need to adjust all 3 Tubes , Turn Color OFF in Menu then aline the Tubes untill you have a Black and white Picture ,Then go back to menu and turn Color on.
Mar 01, 2011 | Philips 51PW9303 51" Rear Projection...
UPON TURNING TV ON RED BLINKING LIGHT COMES ON, CAN NOT SHUT OFF TV,NEED TO UNPLUG POWER SOURCE
you have a problem in the power supply module more then likely their a caps blown they will be obvious tops blown off or busted open youll have to take back off look on module in the middle
May 06, 2010 | Philips 42FD9954 42 in. Plasma HDTV
Turn on pic turns red with thin bright red horizontal lines
Sorry to say, but that's usually the sign of a bad picture tube. One of the elements inside the tube shorts and you see the picture you describe, and the set shuts down due to high voltages getting to places it shouldn't. There's no solution except picture tube replacement, and that is uneconomical. You're better off replacing the TV when the tube goes bad.
Mar 31, 2009 | Toshiba Televison & Video
Power button stays red when you press it
Might be a bad tube or flyback transformer. Best thing to do is take the back off, turn down the lights, and stand behind it while someone turns it on. you may see one of the tubes arching or the flyback itself. Let me know if this helps or if you need more info.
Tim Nolan
Sep 11, 2008 | Philips 60PP9202 60" Rear Projection...
Picture turned green
It sound like a bad tube there are three tubes red green and blue.
i suspect the blue tube is bad. tubes cost 160.00 plus labor 450.total . sometimes the tubes
can be fixed or the tv tech can adjust the screen voltage on the tube.
good luck thanks jay leadingedgeelectronics.com
Apr 29, 2008 | Philips 60PP9202 60" Rear Projection...
RED LIGHT
Does the light blink?
there is a
Sony Picture tube recall
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Feb 07, 2008 | Sony KP-46WT500 46" Rear Projection...
Philips HDTV
most common problem is convergance ic's
when the red light blinks how many times short blinks and long blinks.
Nov 29, 2007 | Philips 60PP9202 60" Rear Projection...
Lamp
red light indicates lamp is expired. even though you get temporary light, the lamp is shot. Try BULBMAN.COM for a new lamp.
Sep 25, 2007 | Toshiba TDP-S20U Multimedia Projector
Power on but busting [no eht]
could be a y-sustain board, av board or power supply board. i would think y-sustain if i had to guess
Oct 24, 2006 | Philips 42FD9954 42 in. Plasma HDTV
No picture coming from red lamp
Sounds like you have two differant problems. A red drive or red picture tube is bad and the conbvergence IC's are bad. To test the red drive disconnect the green picture tube socket BUT MAKE SURE THE SET IS UNPLUGGED!!Then remove the red socket and move over to the green tube. Then turn on the set. If you get the same out of the green then you have a drive problem that needs to be trouble shot for a bad componet. If you do get a picture with the red connected to the green then the red tube is shot. If you know how to read a schematic, get one and then you should have no problem troubleshooting the red drive and the convergence problem. If you dont then there is no easy or quick fix as this is a solid state set and there are no user replaceable parts inside this.,. Your going to need, for safetys sake, call in a trained tech to assist you with this repair
Sep 15, 2006 | Philips Magnavox 51MP392H Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
35 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
