Question about Smeg DWI614 Built-in Dishwasher
Smeg DW1614 diswasher won't start
I took the front panel off the diswasher in order to re-fix the handle on the decor cover (couldn't manage to get decor cover off any other way) & after putting back together again the door closes, the wash cycle displays but nothing happens - as if the dishwasher still thinks it's open? - any help greatly appreciated
5 Suggested Answers
  • 641 Answers
SOURCE: smeg dishwasher wash cycle freezes ,
Thanks for the information.
Posted on Jul 24, 2007
SOURCE: Smeg DI 612 C Domestic Dishwasher
I was told by a SMEG engineer that I needed to replace the detergent dispencer. Just waiting for him to get back with a new one.
Posted on Sep 06, 2009
SOURCE: Smeg dishwasher Beeps when trying to drain...seems to wash ok but
thanks for the above. I solved the problem by cleaning ALL of the drainage pipes--removing them and thoroughly cleaning in detergent and bleach--the small diameter outlet from the dishwasher WAS partially blocked. More to the point I connected from my hot/cold sink tap to the end of the outlet hose and put (carefully) back pressure into the D/W--after a short wait there was a surge and loads of rubbish including small bit of broken glass, a large staple (?) etc came back into the bowl below the d/w filter. I cleaned it all out and repeated 3 times, vacuuming out from the bowl any debris. After that I tested the d/w and it worked faultlessly. Why can't they tell you this in their troubleshooting? Trust SMEG service!
Posted on Mar 04, 2010
  • 6 Answers
SOURCE: i have a smeg dish
Thanks to hijoloo for pointing me in the right direction. The offending part is the diverter valve, a paddle inside blocks one of two outlets in turn actuated by a micro switch, a motor and reduction gears. Check switch for continuity with multimeter (ohms) then check motor and gears turn freely by hand. My problem was a stiff paddle due to limescale. Soak in boiling water to free off then oil cog (externally) and rebuild.
turn the washer on its side and open up the bottom black plastic plate, than disconnect the two black hoses from the white pumphouse in the middle of the washer. disconnect the connector and open carefully the housing by removing two screws and the motor. check the switch and clean the white housing. Check also if there is nothing inside the rotorhouse. after this build every thing back and hope that its running. it worked for me. succes!
hijoloo.
Posted on Nov 19, 2011
Remove interior door panel 2002 Chevy tracker
No you don't need any special tool . Find all screws on out side of door trim panel and the window handle , the mirror cover plate , then just pull on edge of the panel .
Gently pry the front side door trim panel (3) from the front side door by disengaging the plastic retainers which secure the panel.
Position the door trim panel (3) away from the door in order to gain access to the front side window switch electrical connector, if equipped.
Disconnect the window switch electrical connector, if equipped.
Remove the door trim panel (3) from the vehicle.
Remove the front side window switch from the door trim panel (3) by releasing the 4 plastic retaining tabs, as needed.
Use a cloth in order to pull off the snap ring which secures the front side door window regulator handle (1), if equipped.
Remove the window regulator handle (1), if equipped.
Remove the front side master window switch, if equipped. Refer to Power Accessory Switch Panel Replacement .
Remove the front side door inside handle (1). Refer to Front Side Door Inside Handle Replacement .
Remove the outside rearview mirror opening cover (2).
Remove the screw which secures the front side door pull handle (4).
Removal Procedure
Remove the screw which secures the front side door inside handle (1).
Slide the inside handle (1) forward in order to release the retaining tabs which secure the handle to the door.
Open the front side door inside handle rod retainer and remove the front side door inside handle rod from the inside handle (1).
Remove the inside handle (1) from the vehicle.
Check out youtube video showing how to do it !
How To Remove Install Front Door Panel Suzuki XL 7
Jun 10, 2017 | Cars & Trucks
Manual instructio of Smeg model SA 8210 X7
http://www.manualslib.com/manual/343995/Smeg-Pl8210x-1.html
Apr 30, 2014 | Dishwashers
2000 Mazda MPV Starts & runs won't go out of Park Shifter handle moves won't change gears??
I had this issue in the past. All I did was to replace the brake switch. This part is located behind the brake pedal. Btw, if you this run into this issue again in the future, you can always push this switch with your finger and it's located on top of your steering wheel enclosure, this will disengage the shifter.there is a small rectangle shape cover that you need to remove first.
Aug 08, 2017 | 2000 Mazda MPV
HOW DO i GET A PARTS DIAGRAM/SCHEMATIC/EXPLODED VIEW FOR MY SMEG SDCY66 DISWASHER?
there should be one inside the front panel or in a plastick sack attached to back or under cariage if all else fails go to manu. web site and go to product support
Dec 24, 2011 | Dishwashers
We have a bosch integrated dishwasher with a broken handle. We can't get the cover off to replace it! There are no visible screws on door front and I am unsure about unscrewing the metal panel door in case...
On mine there is a 5mm hole on each side of the metal part of the door, about one third of the way down. Inside is a torx screw. Loosen these off a few turns and you should be able to pull the top of the decor panel towards you, (away from the door, not up). Then lift it up to release it from the lugs at the bottom of the door.
That works for mine - yours may be a different model, but it's likely to use a similar mechanism.
Jan 12, 2010 | Neff 24 in. S5443X2 Built-in Dishwasher
Amana SR520S with NO ice dispenser
1. Unscrew the philips screw at the top of the door handle and take off the cap.
2. Go to open the door and your knuckles will be touching a cover panel.
3. Release this cover panel to reveal the screws that hold the door.
4. Unscew the screws to release the door handle.
5. With the handle now off the decor panel can be removed by sliding it out.
Jun 25, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Where does the second front cover on my diswasher go?
The second cover goes just behind the front one. It has slotted holes in it so that one can adjust to the floor hight and the front on is at a fixed location. The 2 screws go thru both of them
Jun 21, 2009 | Dishwashers
Fitting ne hinges on a smeg 90 oven door
very easy unscrew screws on doors the one on inner glass attaches to hinges be careful when lifting off as door handle will come off took me 15 mins and i took it easy
Mar 25, 2009 | Smeg SUK91MFX5 Dual Fuel (Electric and...
NO WATER COMING THROUGH ON DISHWASHER JUST LOUD BUZZING NOISE
The buzz that you hear is the water line solenoid. It probably is not opening up to let the water through. You should replace this solenoid and it will fix your problem as long as you have water coming up to the diswasher's solenoid valve.
Dec 03, 2008 | Smeg 18 in. DWF409WH Slim-Line...
Smeg WD1 12C, error code 10
I have a smeg wd1 12c washer dryer showing error code e01 any idea how to fix it?
Gilly
Nov 06, 2008 | Smeg WDI12 Front Load Washer / Dryer
Smeg DWI614 Built-in Dishwasher Logo
216 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
