Question about Gateway DC-M40 Digital Camera
Samsung S1065 does not turn on, beeps 3 times before powering off. Lens is extended, have checked batteries, not sure what else to do??
  • 2 more comments
  • msalra Dec 08, 2008
    Basically, un damaged the camera will not turn on...
    the green light did flash when attempting to turn on... but nothing happens..
    any ideas?
  • Anonymous Dec 19, 2008
    my green light flashes too but doesn't beep. Pleasee help me!
  • murphyjamesw Dec 21, 2008
    the shutter is not completely shut. when i try to turn it on ot just beeps 3 times.
  • Anonymous May 10, 2009
    nightmare. mine is the same. i powered it up with the computer & i don't know now what else to do. the battery was changed, the camera won't work at all. ahhhhh.
I have had this problem, tried the new batteries idea (no go m), then thought-lens is out, should be in??
Give the lens a gentle pull & it should burst into life. Lens & cover gets stuck what do doapart from back to shop idunno. Tapping camera on table to shut lens cover seems to work but not a very technical solution
Posted on Jun 13, 2009
  • kez6670 Nov 07, 2010
    I also had this problem. I just switched it on and at the time same time pulled at the lens so it came up and now it is working fine. Thanks for your help was going to take it to be repaired but this has saved me the job!
  • robwilson26 Dec 25, 2010
    The 'Delboy computer tap' so simple but effective. Thank you
  • 903 Answers
I had the same problem, firstly you will be able to press the button on the back to view your pictures, when you do and the camera powers up quickly press the menu button. Check that your battery settings are set to alkaline, then buy some good alkaline batteries and not cheap ones. Check that they are alkaline and not like what I did and bought panasonic zinc carbon.
This worked for me and mine would not turn on either until i changed the batteries to a good make.
Posted on Oct 12, 2008
My camera had not been used for 8 months and i had this problem the lens stuck in the zoom position and when i swithed the camera on it bleeped three times and switched off gently push the lens against something flat and soft and at the same time swith it on ,after the 3rd time the lens started to go in via the motor it is now working great ,only push as you switch on the button as if it starts to bleep it has stopped trying and you could damage lens
Posted on Nov 14, 2011
I have a samsung S500 and when I turn it on the lens doesn't open or extend and it will beep 3 times and shut off. I have tried new batteries and nothing works. I took it to a camera shop and they
Well, have you ever considered that the lenses MIGHT be defected? If it's true, you can send it back to the manufacturer, as long as it wasn't YOU who made it defected.
Another tip, is maybe the lens isn't made for that type of camera.
Lastly, the lens can just be broken, so you should carefully examine it, and see INSIDE of it, to make sure all of the parts are their. Hope this helps (:
Jun 11, 2012 | Samsung Digimax S500 Digital Camera
Samsung S1065 digital camera. Won't witch on. Len won't extend, beeps three times, switches off. Any ideas gratefully accepted.
my samsung camera s1065 the lens wont extend when switching on the lens does not extend ,it bleeps 3 times but then closes down
Aug 28, 2010 | Gateway DC-M40 Digital Camera
My camera turns on then beeps 3 times then shuts off is it broken or is there a reset button?
The three beeps mean that the lens motor is unable to extend the lens assembly.
This could be due to a low battery situation, but the most likely cause is the lens drive train stuck or jammed. You'll find generic instructions on solving some cases of jamming here.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Unfortunately, more serious cases (due to falls, shocks, and most of all, the camera being turned on while some resistance prevents the lens from extending: e.g., if the camera accidentally turns on while in a pocket) require the repair shop.
Apr 27, 2010 | Samsung Digimax S730 Digital Camera
Samsung S1065 beeps 3 times and nothing else
If you have recently dropped the camera you may have damaged the lens tube (housing). This damage will prevent the lens from moving properly and will cause the camera to shut itself off after a few seconds. If the lens is damaged the camera will require professional repair. If the lens is not damaged, the problem may be battery related. Make sure that you have the correct battery type installed, and that the batteries are fresh/fully charged. If the problem persists, you may have corrosion on the battery contacts inside that camera that is preventing full battery power from flowing to the camera. Remove the batteries and wipe the inside camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and reinstall them in the camera. This cleaning solves the problem about 90% of the time, and I hope it works for you.
Sep 11, 2009 | Gateway DC-M40 Digital Camera
Camera beeps loud 3 times and shuts right off!!
sounds like a lens error, does the lens extend or retract? You probably have to get the lens back on track, use gentle pressure wiht the camera face down on a towel covered table and turn on to see if the camera tries to retract the lens. I really dislike these types of cameras that extend the lens everytime, if it turns on in your pocket, your doomed!
May 27, 2008 | Samsung Digimax S500 Digital Camera
When I try to turn on my camera (Samsung Digimax S500), it beeps 3 times.
My Samsung S500 kept shutting down (with lens extended but no beeping) as soon as it was turned on. After reading similar problems being caused by a jammed lens mechanism, I GENTLY twisted & tugged the extended lens mechanism (no crude comments please), and it worked the next time it was turned on.
Apr 20, 2008 | Samsung Cameras
Camera beeps 3 times the shuts off
I've decided to send the camera in for possible repair.
Feb 17, 2008 | Samsung S630 Digital Camera
It wont turn on, And the zoom is extended.
I had exactly the same problem. Lens stayed open, when powered on you get three beeps and nothing. I found when I pulled the lens out a little harder it gave a little click. When I powered on it worked perfectly.
Nov 25, 2007 | Samsung Digimax S800 Digital Camera
Camera Wont Turn on
Please eject camera battery and clean with a pin your battery tip in your camera with care fully.d36f20d.gif
Hope its helpful to you
Oct 17, 2007 | Samsung Digimax L60 Digital Camera
Gateway DC-M40 Digital Camera Logo
1,065 people viewed this question
Top Gateway Cameras Experts
mohamed salim shaikh
Steve
Are you a Gateway Camera Expert? Answer questions, earn points and help others
