Question about Datacard Group SP75 Color Card Printer
Heater error in Sp75
Prints the card but indicates heater error thus does not laminate, (thermocouple problem in L1 laminator).
the card does not go beyond the duplex until u switch off and then on for it to be ejected at the back hopper.
alexmnjoro@yahoo.com
  • 1 more comment
  • Kevin Burke Dec 04, 2008
    Card prints but then gets stuck in the pass-through module, laminator non responsive, nor is it detected in settings.
    card prints then gets stuck in the pass-through module, laminator is non responsive and isnt detected in settings. error recieved is Card jammed in pass-through module
  • emills09
    emills09 Feb 14, 2012
    Hey did you figure anything out for this? I am having trouble finding any solution.
Tenia el mismo problema, se soluciona verificando que el "ribbon" del laminador este colocado de la manera correcta y la cintilla blanca que tiene pegado uno de los extremos del "ribbon laminador" este pegada al mismo, ya que este funciona como un sensor, si este se despega, la impresora enviara una señal de error y no laminara
Posted on Aug 26, 2009
  • 39 Answers
Sounds like either the thermocouple or the heater went out. Was this the error code?
OP-01604 Thermocouple problem in L1 laminator
The comments in the service manual states:
- Check the thermocouple wire for damage.
- If the thermocouple was recently replaced, verify that it is not installed backwards
- Verify that the thermocouple connector is not unplugged or plugged in backwards
I would probably order a replacement part, call in your local DataCard service representitive or send it to DataCard for repair.
Posted on Aug 19, 2009
HOW DO I DISASSEMBLE TO CHANGE LAMINATE POWER BOARD
try utube or go to manufacture website for instructions.
Dec 05, 2014 | Datacard SP75 Plus Color Card Printer (P/N...
Lamination Problem
You have to go to printer driver, see the general settings and put more darkness(normally it ranges from 0-20, it should be set at 10. Try puting the darkness at 11,12,13, etc until it laminates properly. Don't forget to put back the setting when printing ymcko, or you will burn ribbon.
If the head that prints color is the same that laminates, then you should be cleaning the head after use.
Jan 17, 2014 | Datacard SP75 Plus Card Printer
Card Jam Error 112 & 245
please calibrate the Lam Film sensor.error 245 is lam sync error please check Lam power/connections and restart the Printer.
Oct 02, 2012 | Fargo HDP5000-LC ID Card Printer...
I have a zebra p520i and it will print a one sided card then go into mechanical error, I then can press the select button and it will travel the card past the laminator section and into the exit hopper and...
This sounds like the feed rollers need cleaning. You can use the correct cleaning cards (your dealer should be able to get them for you - but make sure you follow the instructions on the card carefully) or use IPA fluid.on a lint free cloth.
Jun 03, 2011 | Office Equipment & Supplies
My datacard printer ribbon is supposed to get upto 500 images, but it is skipping every other color series so I am only getting 250 images
Every time you open the printer, it advances CMYK panel 01 to position the print head.This can cause loss of ribbon. Avoid opening the printer to the maximum you canoptimize your prints.
Jan 20, 2011 | Datacard Group Datacard SP75 Color Card...
Running "test" cards on the SP75 Plus.
Is the test card meant to the laminator heated?
If so, you should be able to set the laminator time out from 30 minutes to 5 hours.
This is done through the front panel under the configuration menu.
Hope this helps
Apr 27, 2009 | Datacard Group SP75 Color Card Printer
Air bubbles in laminate
Do you have a dual lamination station in your printer? How old is the printer?
There may be contaminates on heated platen that is causing the bubbles. I would go into the printer settings and try various settings such as LAM1-BOTH SIDES and LAM2-NONE then LAM1-NONE LAM2-BOTH SIDES to isolate the issue
Feb 11, 2009 | Datacard Group SP75 Color Card Printer
Low temp error on DTC525 Laminating unit
I believe, it is the thermocoupler. We can get you this part.
Jan 21, 2009 | Fargo DTC525 ID Card Printer
Uper Duplex not holding card in place
early model sp75s have that type of problem. It can normally be fixed by replacing the clutch and duplex board. Very easy to replace. Be sure to be aware of the clutch spring when removing the duplex tray. Use the lower duplex assembly as a guide.
Jul 02, 2008 | Datacard Group SP75 Color Card Printer
Fargo pro l lamination
I cant even get my cards to print the lamination on there. Can you please help me!.. Can you show me pics on how you installed the Lamination rolls. Also is there a special driver you installed or option you clicked beside the over laminate one. THANK YOU SO MUCH!
Dec 06, 2007 | Fargo Pro L ID Thermal Printer
Datacard Group SP75 Color Card Printer Logo
751 people viewed this question
Top Datacard Group Office Equipment & Supplies Experts
Jaime Hernandez
Are you a Datacard Group Office Equipment and Supply Expert? Answer questions, earn points and help others
