I have a panasonic stereo sa - ak220 and you turn it on and comes up with F61 and a humming noise through the speakers
  • Anonymous Apr 01, 2009
    Panasonic SA-AK22 music system will not power up. When power button is pushed it does not come on. The ac in light is is the only thing on when plugged in.
    Scholar:
  • 142 Answers
Remove cover and make sure the fan is ok...not clogged. Also, you could have a bad audio output IC or cold solder joints on the output IC. Use a volt meter to see if voltage is present on the speaker lines. If it is then your output IC is bad.
barneyluc
Posted on Oct 01, 2008
Got a Panasonic CD stereo system SA-AK410 When I turn it off after a few seconds it turns back on. Is this normal?
That's because you haven't set the clock on the system. I jumps to DEMO mode once you turn it off without the clock set. Clock can be set through your remote. Hope this helps. Cheers.
Oct 04, 2013 | Panasonic Remote Control Eur7710020...
F61 on panasonic SA-AK220
There are no error codes in the users manual. In this series of models panasonic has standardized error code meanings. F61 means a failure in the power out circuits. Your first option is to remove all your speakers and the associated wiring with the power off. Repower unit and see if error is still there. If not, you have a speaker or wiring problem. If still there, you have an internal failure requiring service.
May 19, 2012 | Panasonic Audio Players & Recorders
Panasonic sa ak220 wont turn on
The problem is in the audio output ic, it is loading the unit into shutdown. The only option is have the ic in the stereo replaced.
Mar 07, 2012 | Panasonic SC-AK220 CD Shelf System
My dvd stereo system panasonic model SA DK2 , F61 error,and immediately power down, comes on when turned on and then powers back off. please help
F61 usually means the amp has detected a short.
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections as a root cause for intermittent shutdown.
Feb 21, 2011 | Panasonic sa-ht800V Home Theater Audio...
Error F61 on Panasonic Stereo System SA-AK80
HELLO
As far as I can know, F61 means your output IC is dead. Contact a service centre in your locality for repair!
May 12, 2010 | Panasonic Home Theater System System
Repeated F61 fault code on Panasonic Home cinema system Model: SC-HT990 Is it the fan in the sub woofer?
Hello
F 61 error means the failure of FAN
most probably dust in the fan made it to stop working so clean the dust and connect the fan to an external supply of 12v(using red and black wire) for 5 minutes and reconnect it to the unit otherwise replace the fan with new one.
Surely this will solve the problem.
Kind regards
Andrea
Dec 12, 2009 | Panasonic Home Theater System System
Humming through speakes when on auxillary
Most humming in North America is either 60Hz or a harmonic of 60Hz. The number one cause of humming is a poor common. On co-axial cables this is the outside connection where as the signal is the male post in the centre. Corrosion, oxidation, poor contact are all possible things to check.
Jun 10, 2009 | Panasonic SA-HE200 Receiver
Panasonic SA VK550 - F61 eror
Hi, i had the same problem with a panasonic player, when you see the code F61 in the screen it is because the audio output IC is defective,change that and the set will work perfectly. hope it work.
Feb 05, 2008 | Panasonic SC-AK33 CD Shelf System
247 people viewed this question
 Grubhead
Grubhead
