Placing a TV in home, would over a radiator be a problem
  • 5,138 Answers
It can if there is heat coming out of it.
Posted on Oct 01, 2008
How do I take a radiator out of Chevy Malibu ?
Drain coolant, discharge A/C lines. remove front bumper for access. remove condenser, remove upper and lower hoses, remove hold down bolts on the top of radiator.
Feb 03, 2016 | Cars & Trucks
My philips lcd have statrting problem in winter tv turn on some after statrting room heater
Some flat screen TV's generate a lot of heat at the back. You can do some test by placing the palm of your hand above the TV or even a thermometer on top the TV without touching the TV body and see how the TV temperature fluctuates during the 12 months of ambient temperature. In Summer, it my run hotter and in Winter it may still run hotter because of these reasons... the TV is close to the heater, it is inside a wall unit or it is in a corner where no air circulation is present. In the wall unit, no air circulation is present and the heat you feel above the TV is actually whatever bit of cool air it can draw from the rear part of the TV openings to cool the components. I know that most TVs are always close to a heater, fireplace, or a radiator that generates heat towards the TV. Again, if you put a thermometer on the TV and observe the different temperature range, you will notice a raise in temperature on the thermometer when you have the TV placed by a wall whose outer wall is facing the hot Summer sun, or when you have any means of heating system to keep your house warm in winter (while you live inside wearing a T-shirt and shorts), a warm fireplace (gas or wood) next to the TV, and or an electric radiator, or an integrated home heating system. These affect the appliances that rely on cool air circulation. And TV's are the first to suffer from excess heat and they seize unexpectedly. So, the first thing is to keep the home temperature under 25C by reducing the heating system and wearing proper winter clothes instead of T-shirts, etc. If the TV is next to a fireplace, that room is really warm and is suicidal for the TV. Move it where it is cooler and not in direct heat from the fire. Stand by the TV and see if you can feel the fire heat radiating in your face. If it does then that is no place for your TV. Move it away and rearrange the seatings so that you can watch the TV and still have the heat radiating to you, and not the TV. of all the modern technology we have today, the TV still doesn't come with a cooling fan like a computer and yet they generate more heat than a computer. If you have some wiring experience, go to an electronic store and buy yourself a large (4 inch) silent cooling fan, either mains operated or 12v. Mains is usually plugged directly in the mains socket, but 12v fans need a 12v, 1 amp transformer.
With some plastic covered wire ties, insert them in and out of the cooling grille at the back of the TV, usually the lower ones because that's where the cool air enters and exists at the top as hot air. Then attach the fan against the grille with one end of the tie inserted in the corner holes of the fan body and with both tie twist them tight and firm. You must make sure that the fan is placed where there is a large slotted area to freely allow as much air as possible, otherwise it either makes air noise or it will not cool effectively. Most TV rear cover has a generous amount of apertures in the form of vertical slots or hundreds of holes for cool air to enter, but a fan will force more cooler air, therefore the TV will run cooler. Then you connect the fan wires to the transformer. It's a pretty straight forward wiring if you're know a thing or two about wiring, plus - less (+) (-) voltages and cable colors. if not have it already wired and working by an expert to save you the stress of this wiring. But I believe the placing of the fan on the rear of the TV should be a piece of cake for you if you followed the simple advice above on attacking and tying fan on the lower rear part of the TV. Alternatively, if you've got money, let an qualified expert do the work foe you for a small fee. You just buy the fan and the transformer to suit. Don't forget to ask questions when you buy them, does the voltage on the transformer match that of the fan? Remember the fan will run all the times so, when you switch the TV on you want the fan on too. So, to make it easier for you, buy one of those remote controlled power boards on the market today. Plug a divider on one of the socket on the board and connect the TV cable plug in one side and the transformer on the other side. Since it is the TV that you watch most often, use socket one (number 1 on the remote). When pressing number one on the remote you have power for the TV and the fan. When you finish watching TV, press the same number one button to turn its power off or press the main button on the remote that removes all power to all devices, therefore it will save you electricity by disconnecting any power to any appliance connected to power board's sockets. Hope this explanation helps you one way, or another. Cheers.
Dec 28, 2014 | Philips 32PFL3403D/27 32 in. LCD TV
Amana agent egypt
Try the router in a different location, something may be interfering with the signal. A TV, Computer, Air conditioning, anything electrical may be radiating a signal to upset the signal from your router. Placing tin foil behind the aerials can assist in directing the signal too.
Dec 21, 2013 | NetGear Computers & Internet
Where is the thermosted i need to replace it
They ar normall under the housing on the cylinder haed that the top radiator hose fits on. However I have noticed lately that some manafactures are placing them on the bottom radiator hose housing that bolts on to the block
Feb 03, 2013 | 2009 GMC Sierra 1500
S40 will start to go away from home but will not crank/start to come home. New battery, cables and starter has been checked....all good. Any thoughts? Seems like it coulf be a number of things...
2006?? sorry most likely this is the same software as europeon models and if it is then its encrypted to make work for dealers only.Keep the key away from mobile phones and computer /tv screens ,this will affect the readability of the chipped key
Jan 02, 2010 | 2006 Volvo S40
I have a leak on the radiator where the upper radiator hoe connects
to the thermostat and then the upper engine part of the cooling system of the jeep . to know the points of placing it back to its position you'll have to see the or remember how did you take it off . To the engine.
Aug 01, 2009 | 2000 Jeep Grand Cherokee
Where is the radiator drain plug on a 2000 cadillac deville
Drain plug should be on the drivers side of the radiator, lower back (towards the engine) When placing the drain plug on place use some oil on the O ring to ensure a good seal when tightening it back in place. Good luck and keep me posted.
Jun 30, 2009 | 2000 Cadillac DeVille
Sony KU-27FS16 TV
there is an apparatu use to degauss the color of tv, usually technician has.but ,if you don't have that apparatu, you can use the magnet of the speaker by placing it nearer the screen and moving it from left to right...
Sep 22, 2008 | Sony KV-27FS16 27" TV
Speakers for home thearter
Hi dogbert007,
Luckily, shielding your TV from the magnetic field produced by audio components is necessary due to the technology in a Cathode Ray Tube (CRT) display. If you have an LCD television, you should not have to worry about placing them within a few feet as you plan.
Thank you,
Jason,
Go Ahead. Use Us.
Jul 10, 2008 | Televison & Video
Connecting my home theather system to my ps32la30q television set!!1
Make sure you have connected your cable to audio lines out not any of the line in's on the tv then check to be sure you are connected to the line in on the home theater amp
Feb 16, 2008 | Proscan 32LA30Q Television
Televison & Video Logo
Top Televison & Video Experts
