Question about Whirlpool LER4634J Electric Dryer
Fitting the belt to the hoover 5050ed
Does anyone have a diagram
  • 550 Answers
Nope,, but
all dryers are generically the same
remove the front panel and door
pull the drum
loop the belt around the drum, at apporximately the wear marks of the old belt
reinsert the drum
loop the belt around the motor pulley
pull the tensioner pulley hard against the spring to the end of its travel
loop the belt around the tensioner pulley
allow the tensioner to move back under spring pressure to tension the belt
rotate the drum by hand to make sure the belt is aligned and not coing to jump off the pulleys
reinstall front panel & door
fitting the belt to  the hoover 5050ed - 26740a0.jpg the tensioner may be on the bottom belt run pusshing up, or the top run pulling down
breaking belts sometimes pull the tensioner out of its mounts, there is only one place that the tensioner will reinstall.
Its a standard whirpool dryer, rebadged as hoover, so the local parts guy has the belts rollers felts and glides as necessary, they are common to all the dryers whirlpool makes.
Posted on Oct 07, 2008
    New Friend:
fitting the belt to  the hoover 5050ed - d9b671e2-9b79-4145-a1e4-c55efd7e1c35.jpgHoover 5050ED Drive Belt
Posted on Mar 28, 2013
What belt fits the hoover preferred?
Hello, this is Ava with Think Crucial.
In order to know the right belts to use for your Hoover cleaner, you would need to get either the model number of your unit or the part number of the belt. Hoover upright model number can be found either at the back or at the bottom of the unit while the part number can be found in the manual that came with your vacuum or you can do a quick search online. You may also contact Hoover (800) 944-9200 for further assistance.
You can purchase a wide variety of high quality Hoover replacement parts for your Hoover vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=hoover
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Oct 10, 2014 | Vacuums
HOOVER AUTO DRY 5050ED KEEPS STOPPING
hi there, I have repaired many of these dryers. It will be a faulty heater element, most likely. They cost about $40. If you get a tradesman to fit it, they will prob charge you about $200 all up. Maybe its better to buy a new dryer for around $300? Good luck.
Lance in brisbane.
Jun 17, 2012 | Hoover Dryers
Can not find a proper fitting v-belt to fit my hoover wind tunnel cyclonic. i even ordered it from hoover.
The correct belt is # 38528034 ( package # 40201200 ) This belt may seem loose when it is installed, because there is an "idler bearing" that pushes down on it when the handle is released and dropped back.
Mar 07, 2011 | Hoover U5780-900 Windtunnel Cyclonic...
5050ed buzzes onstart up ,needs little manual turnover to start
it can be the idler pulley that tightens the drum belt,the drum belt itself has gotten old and glazed from age,or the motor that turns the drum the bearings can be getting dried out from age and heat and getting tight requiring help to start,also the motor start switch on this motor can be getting bad contacts inside this switch,all these issues require you to dismantle the unit to some extent to check them
Jan 29, 2011 | Hoover Dryers
I need a replacement belt for Hoover Elite upright vaccum ,model no. U5043-930. What belt do I get?
Your vacuum cleaner originally came with Hoover belt part number 38528027, however Hoover has now discontinued this part number, and replaced this belt with the new belt which is part number 38528040.
The new belt is a little bit smaller then your old one, but unfortunately this is the only belt that Hoover currently makes that will fit your model.
Here's a direct link to our website if you still need to purchase one:
http://www.govacuum.com/agbelhoovpar7.html
I have also uploaded the parts diagram and instruction manual for you. The parts diagram gives you every single part number for all parts on your vacuum should ever need to know another part number. The owners manual will give you step by step instructions on how to change the belt, as well as other maintenance instructions.
Part Diagram for Hoover U5227-930:
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/Part-diagram-hoover-u5043-930.pdf
Owners manual is actually for the commercial version of your vacuum, but this will be identical to your instruction manual which Hoover doesn't have available for free:
http://www.hoover.com/pdfs/manuals/C1414900.pdf
I hope that this information was helpful to you. If it was, please be so kind and rate my repair helpful by clicking the thumbs up icons in the top corner of the repair.
Thank you very much,
Chris J.
GoVacuum
Apr 04, 2010 | Hoover U5227-930 Elite Upright Vacuum
Can't get the dryer to work! - Hoover 5050ED Heavy Duty 5.0 Kg Auto Dry Plus
ditto and exactly 2 years later! Someone please help!
Mar 03, 2008 | Hoover Dryers
Whirlpool LER4634J Electric Dryer Logo
752 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
