Question about Microsoft Xbox 360 Console
Xbox 360 error
My xbox 360 says it has an error when you switch it on and that i have to go to xbox support
Does t say E74 on black screen????
Posted on Oct 01, 2008
I have an xbox360 I had almost a year I went to switch it onan a red light apear and tells me to go to xbox custemer care E37
If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
Fortunately, the Xbox 360 1 red light message is not something that you should worry about. In order to identify which of the two drives the Xbox 360 1 red light messages is referring to, just look the code number that the screen displays. DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.
Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at Fix-xbox360.info will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages. Check it out.
Jan 21, 2011 | Microsoft Xbox Console
Switchs on comes up with e74.has 1 red light flashing on front f unit
XBOX 360 Red Light error, or Red ring of Death RORD is a very common issue, and can happen anytime. There are different Error numbers related to RoRD, and appears on screen starting with "E".
Red light problem can be fixed! there is a XBOX 360 repair guide available that covers this problem and also all other common XBOX problems. You can get your copy XBOX 360 Repair Guide, you can download it and get help to fix your console. Please feel free to message me if you need further assistance
click here to download.....................
Oct 14, 2010 | Microsoft Xbox 360 Console
When switching on xbox 360 a red ring comes up and it says system error E74. could u posibley help me with this problem
TXT is a common error occurs in xbox 360
don't panic ,its not a big deal you can solve this quite easily ....... Repair Guide available for a wide range of such problems .. Download the Repair guide, it will help you solve your problem .........
Click Here ......
Oct 13, 2010 | Microsoft Xbox 360 Console
Everytime i switch on it shows errror E74
The E74 error code occurs when the Xbox 360 console experiences a general hardware failure.
To confirm your console is displaying the E74 error message, follow these steps:
  1. Turn off the console.
  2. Turn on the console.
  3. Verify that your console displays the E74 error message.
If your console continues to display the E74 error message, it requires a repair.
Login at the following website to start an online repair support case
(Free repair if console is still under warranty, $99.00 if not)
http://support.xbox.com/support/en/us/nxe/LiveIDSignIn.aspx?redirectUrl=http://support.xbox.com/support/en/us/nxe/registerdevice.aspx?step=repair
or contact Xbox support at 1 800 4my xbox
(Free repair if console is still under warranty, $120.00 if not)
Jul 23, 2009 | Microsoft Xbox 360 Console
I am getting an error message E73 on my XBox 360
there are a lot of diffrent walktroughs on you tube for this problem decide whitch is best for you. or go to www.xbox.com/support/contact
Jul 20, 2009 | Microsoft Xbox 360 Console
Xbox F73 Fault
E73: I/O Hardware Error - Couldn't calibrate HSIO Bus from edram: this error is likely caused by a problem with the Ethernet port or supporting control devices
Jul 12, 2009 | Microsoft Xbox 360 Console
Dynex 4 port hub xbox 360 IP address error
Here is a link to their Support site: http://support.xbox.com/support/en/us/nxe/default.aspx Select "Troubleshooting/Connection" errors page. On the LEFT, select "Network Help". That should put you in the area you need.
Jun 12, 2009 | Dynex 4-Port 10 Mbps Ethernet Hub
Error code from my xbox 360
http://llamma.com/xbox360/repair/Xbox-360-error-codes.htm
Jan 18, 2009 | Microsoft Xbox 360 Console
XBOX 360 SOMETING DOES NOT SWITCH OFF AND PRESS THE POWER SWITCH
if your xbox 360 is one of the older ones or the first released xboxes then it could be the start of the 3rrod problem this type of error can occur when the motherboard starts warping and the solder joints are broken which can cause similar problems such as this. i would also try getting the very latest game you can and doing an update to see if this helps. you may also be able to download the update from www.xbox.com. burn the update to a dvd and then place the dvd inside your 360 and when asked if you want to update select yes and see if this helps.
Dec 11, 2008 | Microsoft Xbox 360 Console
Xbox error
check this out
http://www.llamma.com/xbox360/repair/Xbox-360-error-codes.htm
Aug 19, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
