Question about D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B)
Printers Can I connect my printer to an ethernet port and thus make it available for everyone who is logged on to the network to use?
  • D-Link Master
  • 6,487 Answers
Yes, you can for us long that the printer is setup as a network printer and drivers are all installed on each computer everyhting should be able to use that printer that is connected to your router....
Hope that helps.........
Posted on Oct 01, 2008
How to connect the printer to network
There is an ethernet port on the copier...Just connect network cable and setup TCP/IP. Make sure printer kit is available, otherwise u're not able to print.
Sep 29, 2013 | Toshiba e-Studio 282 Printer
Wanna connect mulitple computers to my Printer
Yes, you can definitely share one printer to multiple computers. All you need to have is a ethernet hub or some call it network hub and Cat5 cable. Ethernet Hub is a simple, small and inexpensive gadget to connect multiple computers together.For the Cat5 cable is popularly known as LAN cable. For you to share your printer, connect it on a ethernet hub as well as your computers using a Cat5 cable. Once everything is connected to the Ethernet hub fix the network and that's it. Everyone that is on the network can use the printer.
I hope I answered your question.
Thanks a lot!
Jul 25, 2011 | Ricoh Aficio GX3050N All-In-One Printer
I need to connect my printer to my wireless router.
Assuming your printer is network compatible:
  • If it uses Wireless, use your printer's configuration to connect to the D-Link's network. You may also want to use the D-Link's built-in DHCP controls to assign a single IP to your printer for simpler setup
  • If it has an Ethernet port, connect a cable from the Printer's Ethernet port to one of the 4 ports on the back of the router. This should connect the two and all going well, most printers will sort themselves out from here.
If your printer is not network capable, you will have to connect the printer to a computer then use Windows sharing options to share that computer's printer with the network.
Hope this helps, Alistair
Mar 15, 2011 | D-Link DIR-615 Wireless Router
Scanner driver for cannon ir3300 connected to lpt1 port
Canon Network ScanGear only works over an ethernet connection. There is no scanning available via LPT1 port.
Dec 23, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Want to connect aDI-604UP wired router to a DIR-615 wireless router to use as a printer port wirelessly
Hello Richard.
For this, you have two types of connection
1. LAN_LAN (ethernet to ethernet) -->wireless router is acting as a switch
2. LAN_WAN (ethernet to internet)-->wireless router is acting as a wireless router
in this case, you need the LAN_LAN connection
Physical connection:
plug an ethernet cable from the ethernet port on the wired router and connect the other end of that cabl to the ethernet port on the wireless router
log-on to the setup page of the wireless router, do this while the wired router is turned off.
-open your internet browser, type on the address bar. Then type the username & password for the router ( default admin as the username, password : ).
Under the setup tab, click manual configuration. Then click network settings, change the router ip address to & disable the DHCP server. save the settings. Just personalize the wireless network.
Hope this helps.
Sep 15, 2010 | D-Link DI-604 4-Port Cable/DSL Router...
I recently purchased a new pc hp2009m and the cord on my lexmark e250dn does not fit my pc how can i adapt please advise. Colin
This printer has three standard ports: bi-directional parallel, USB, and ethernet (RJ-45). Most likely your previous computer had a parallel port. The simplest solution is to get a USB cable (Male type A to Male type B - 6' or less in length is recommended.) Install the software on the computer then connect the cable to the port on the back of the printer and to the computer (the square end goes to the printer and the rectangle fits the computer). The USB port is in the same area on the left side of the back of the printer as the parallel port.
Alternatively you could get a network switch and connect the printer as a networked printer. The ethernet port is near the middle of the back of the printer. has the software and drivers for support OS versions.
I hope this helps.
(Getting a bidirectional parallel to USB adapter is cludgy when you have a USB port available.)
Jul 01, 2010 | Lexmark E250dn Laser Printer
Can i hook this up to a wireless rourter. it
Without an ethernet port, you can't connect to a router. However, adapters are available which can adapt usb to ethernet. Check your local computer store.
Oct 23, 2009 | HP PSC 1610v All-in-One Printer
Network printer
Connect one end of an ethernet cable into the ethernet port on the printer and the other one into a free port on the router. Then, using the install CD, tell it that you are attaching a printer on the network. The software should automatically detect the printer on the network and set itself up for it.
Jun 26, 2008 | Computers & Internet
Dell 3000cn Network Connection not working
First of, the ethernet must be 'on'. If dhcp available, set it to auto (or dhcp.. anyways..) and let it reboot, just in case :)
if not, try setting the IP-setting yourself. They should be somewhat similar to the settings on your local computer(s).
To add the printer to your computer, select 'Local' printer and specify 'tcp/ip' as which port its connected to. In the new window the ip to the printer should be entered. :) (at least for XP this is..)
Hope this gave you the correct solution..
Mar 18, 2008 | Dell 3000cn Laser Printer
Brother 2700CN Color Laserwriter--Loss of Ethernet Connection
No lights on network card mean that you will need to replace network port/card on printer if cable and connection is sound
Nov 28, 2007 | Office Equipment & Supplies
D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B) Logo
32 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
