My Kenwood amplifier is having problems, whenever i turn it on. all seems well until i play some music through it, after 30seconds to a minute the music will cut off and a distinct click is sometimes heard. its really annoying
  • bmcondon Oct 05, 2008
    That really helped thanks mate A+++++
    Scholar:
  • 142 Answers
Your amp is going into protection. The click you hear is a relay meant to protect your speakers and stereo. Check your speakers with an ohm meter for the the proper ohms ( listed on the speaker ) and physically try to push each woofer and midrange cone in gently to make sure it moves and is not stuck or frozen in place. A speaker may read correctly on an ohm meter if the woofer is ok but if the tweeter or midrange is not working it will cause the amp to go into protection mode. When you play music stick your ear up to each tweeter\midrange\woofer to ensure they are working.
Your stereo could also be the culprit although usually if it plays music it is ok as long as you are not hearing loud pops. Loud pops are voltage spikes that indicate that a transistor\IC is breaking down and will eventually short. Good luck!
barneyluc
Posted on Oct 01, 2008
I have a kenwood stereo for 2000 saab 9-5. the tuner works but whenever i change it to cd you can no longer hear any music. it must be the wiring but i dont know which color wire is connected for the cd...
It sounds you are using an amplifier and using the blue wire (power antenna remote turn on) instead of the blue/white wire (amplifier remote turn on). Try hooking up the blue/white wire to turn your amp on. When leaving tuner mode, the blue wire shuts off, turning off the amplifier.
Sep 28, 2011 | JVC AM FM CD DET FACE CAR STEREO
After driving for about thirty minutes my amp will just cut off, it seems a little hot and then it will turn back on in about 10 minutes. I'm not playing my music loud at all and I have all kenwood...
sounds like your speaker is either the wrong resistance for your amp ie your amp may state 4 ohms and your speaker is 2 ohms which means that the speaker is shorting out the amp and its going into protection mode or the speaker could be burning out and shorting out the amp
May 30, 2011 | Car Audio & Video
Amp is connected to speakers but the volume coming out of the speakers is very very quiet. Speakers have been tested seperately and are known to work. Have turned the input sensitivity to max, this makes...
sounds like you need to turn up your gain and bass. while amp is on and your favourite music playing, turn up the diles on your amp until you get the sound you want one by one.
Feb 28, 2011 | Kenwood KAC-529S Car Audio Amplifier
Amp overload protection mode
it sounds like the ground is bad to begin with and check the positve cable for oxidisation on the battery terminal and at all other places that the power wire is connected to
Aug 09, 2009 | Kenwood KAC-8104D Car Audio Amplifier
Kac-ps201t problem
I had a similar problem with a KAC-X812D Kenwood amplifier.
My problem turned out to be that the RCA inputs were so sensitive, they picked up interference from my head unit through the RCAs.
I replaced the head unit with a newer model, and had no problems after.
This may not be your case, but hope it helps.
Dec 15, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Kenwood amp kac-x401m
How long will the bass play before the amp kicks into protection mode and how loud are you listening to it? I've noticed with my amps that if they don't have enough air flow they will get hot and kick into protection mode. They will also kick into protection mode if you are running it at more than it can handle. Check your adjustments on both your amp and the head unit. Make sure you are not running more bass than the amp can handle.
Nov 04, 2008 | Kenwood KAC-9152D Car Audio Amplifier
My amp is turning on but!!!
you probably blew it up. Whenever you smell that smell it is almost always a capacitor in there that blew.
Jun 17, 2007 | Kenwood Excelon KAC-X521 Car Audio...
My Kenwood 800watt amplifier
Sounds like you have overloaded your amp. When you bridge you MUST make sure that you still have the proper speaker load. One 4 ohm speaker on one channel is fine, but when you bridge that same 4 ohm speaker, it gives you a 2 ohm load on each of the two channels that are now bridged. If you made the mistake of wiring two 4 ohm speakers in parallel (plus to plus and minus to minus) then when you bridge you will be driving a one ohm load on each channel. This is very close to a dead short. Stop using your amp at once until you get your speaker load correct. This will damage your amp and it will cause you to have to go to a repair shop to fix it. DO NOT RUN YOUR AMP ANYMORE UNTIL YOU FIX THIS. Good luck.
Jan 22, 2007 | Kenwood KAC-9152D Car Audio Amplifier
Head unit is on but no sound coming out
I Had That Happen To Me Its A Ground Problem. Check The Negtive Speaker Terminal And The Ground Wire Runing To The HeadUnit This Should Fix It.
Dec 17, 2006 | Kenwood KAC-9152D Car Audio Amplifier
150 people viewed this question
 Grubhead
Grubhead
