DC offset at output - 18 volt. What componet is faulty?
  • gpinchik Oct 01, 2008
    ONKYO A -8190 amplifier.I can email you circuit diagram ASAP. minus 18 volt output.
    Brigadier General:
  • 6,966 Answers
Re your post "...I can email you circuit diagram ASAP..." perhaps you could post/upload the schematics to http://megashares.com/ and thereafter post the link here.
Initially,
  • have you checked the the counterpart, +18?
  • have you measured the voltages without load?
  • it could be not a power supply problem but the outputs loading the PSU.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 01, 2008
  • Louie  Role
    Louie Role Oct 01, 2008
    Hi again,
    There are four (4) versions of an Onkyo A-8190: UD, UG, UQ and UW/UWX. The difference mainly is on the power supply section. But what is common is TA7317P (protection IC), Q701, you may want to start there or the output transistors 2SA1491 & 2SC3855.
  • Louie  Role
    Louie Role Oct 06, 2008
    Hi again,
    Got the schematics that you provided. A question pls, at what point did you measure the -18VDC, speaker terminals?
    If yes, then most likely a problem with the output transistor pair as initially posted. Additionally, if it is only on one channel, then you can use the other channel as reference when doing voltage measurements or in passive/resistance checks.
    Good luck and pls postback updates.
  • 6,487 Answers
CAn you please inform us what is the model and brand of your unit so we can help you better...
What size (DC Output Volts) adapter do you use for a Samsung chrome notebook if it says 40 watts?
Most laptops, notebooks use adapters rated for about 18 volts.
To be sure check the manual that came with for that spec.
Sep 02, 2015 | Samsung Computers & Internet
Kenwood with dc offset
DC offset is most often caused by the bias level for the output transistors changing for some reason. This could just be that the control is dirty and needs to be cleaned and re-adjusted, or the biasing network has a problem, most likely the diode or transistor that is being used to set the reference. The diode or transistor is often mounted to the heatsink for thermal feedback, which allows the bias to change depending on how hot the output transistors are getting, There is no mention as to how high the DC offset is. The usual range for DC offset adjustment is less than +/- 1 volt. If your offset is higher than this, there usually is a problem with the bias circuit that needs to be repaired. If it is MUCH higher, then one of you output transistors or driver transistors is most likely defective.
Jun 16, 2014 | Audio Players & Recorders
My kenwood ddx616 indash keep showin DC OFFSET ERROER?
You could have a speaker wire or speaker tensile (flex) lead that is shorting to ground, on a floating ground BTL head unit (all that claim 18-25 watts RMS per channel) all 8 speaker wires are always floating at about half of the supply voltage, IE if the voltage is 14.4 with the engine running the speaker wires will all measure about 7 volts to ground.
The flex leads are the wires on a speaker that go from the terminals to the cone.
Jan 30, 2012 | Car Audio & Video
How to get a symmetric DC power supply : i.e +18 Volts -18 Volts and ground from this kenwood power supply PDS36-20
You can't do that because it's not a split supply. There's just a single output referenced to ground, so all you can get is one voltage at whatever you select from 0 to 36 volts.
Aug 01, 2011 | Kenwood (PDS36-20) Power Supply
DC Offsets on output - protection don't allowd to switch on
you don't want to do this( bypass the protection0
that d.c. output will burn the coils in your speakers with out making a sound!! you have a biasing problem
or like you said a d.c. offset problem it is best to work on this problem with out a load on the amp, this will allow you to trace back where the trouble is starting at. caps will cause this sort of problem but leaky transistors can also do this, even diodes.
this will require an experienced trouble-shooter.
Apr 26, 2010 | Audio Players & Recorders
Lambda ews600-18 voltage goes down.
there is a short circuit protection and overoad protection to smps so o/p capacitor may short or secondary diode may short .so check voltage at primary when switched off after 33seconds whether switching process is going or not for that check dc volt at i/p capacitor then check volt at collector of transistor if metr shows 1digit then switching is going if not then meter shows full dc volt check component near about that
Apr 13, 2010 | Lambda 40-Watt Power Supply
TV Needs new 5 volt regulator
Check for DC output at D653, if you have voltage there find Q682 and measure the voltage at the emitter. You should get 5 volts.
Just a question, if you are missing the 5 volts; do you have any other functions on the TV not working?
Apr 17, 2008 | Emerson EWF2004 20" TV
AVR-1603 - no Sound exept over Headphones is a weak signal
First check the outputs at the output fets/transistors for any DC voltage. Reference your voltmeter to the speaker - terminal. If there is ANY DC offset, the amp is shutting down the outputs to protect your speakers from DC. Is the power supply + and - 47 volts? If only one supply is there That is your problem because the supplies should be symmetrical. Also look for any wiring problems from the amp to your speakers... any shorts? Try disconnecting all your speakers to totally eliminate any speaker problem and see if the relays still click. You should hear only ONE click when you first turn the amp on (delay of about 2-5 seconds). If they keep clicking the amp outputs are next. Also, is there any indication on the front panel of what is failing?
Jul 29, 2007 | Denon AVR-1603 Receiver
Protect mode
You may have loosened a solder joint on one of the components inside with your air blast. A repair tech would monitor the outputs DC offset voltage and he will probably see one that is not zero volts and while wiggling various things he should see a sudden change in the DC offset voltage on the bad channel when he touches the bad connection. Then it's just a matter of resoldering the connection. Good luck on this one.
May 02, 2007 | Sony STR-DE425 Receiver
220 people viewed this question
 Grubhead
Grubhead
