Question about Xerox DocuColor 12 Printer
Fiery patches Where to get some importat patches for fiery models X12,XP12 and EX12. I want the system software XPe version with bios for the above fieries.
  • 2 more comments
  • ekambaram_v Oct 01, 2008
    Thank you sir, I need some more patches other than those available from this site.
  • gfditto Mar 05, 2009
    WHERE CAN I GET THE COMMAND WORKSTATION FOR DOCUCOLOR X12 ? I THINK IT SHOUL BE EASY FOR MY TO WORK WITH THIS SOFTWARE
  • Anonymous Mar 18, 2014
    how can i print on a dc12 fiery x12 with mavericks. Workaround?
    mavericks x12
  • 79 Answers
Hi better u try to xerox.com/drivers..
Posted on Oct 01, 2008
I have Dc 12 color xerox with fiery. i am facing a problem the the fiery is running till loading then nothing display or nothing showing more means steady at loading . . .
please give me guidence step by step
Posted on Nov 19, 2011
Patch installation sequence for the Fiery X12 with DC12. Hi, I had a problem with Rip and I installed the 1.5 system, but the system can not find the DC12, it says "Error network controller." I have...
You need install patch "1-56CTS.ps". Try to find it via web.
Also install Fiery Downloader app. Go to File->Download and choose file "1-56CTS.ps". Then reboot a fiery and problem must go away.
Oct 29, 2013 | Xerox DocuColor 12 Printer
Hi Dear Can use xerox DC12 with MAC OS without
There are some Mac OS drivers.I think your printer is not compatible with Mac.
The level of functionality and compatibility with the new Mac OS X 10.6 drivers are identified in the following document.
> For a list of Xerox equipment compatible with Mac OS X 10.6, click here.
DocuColor 12 Copier/Printer
Dec 14, 2010 | Xerox DocuColor 12 Printer
Fiery EX12 hangs on booting no further process is...
You will need to reload the software in the Fiery.
May 20, 2010 | Xerox DocuColor 12 Printer
Xerox Docucolor 12 copier doesn't print when sending to FieryEX12
There is no 1 part that deals with this issue i'm afraid. The copy from the glass uses all the boards in the same path that a print uses. It definately rules out the machine fault. I would guess that the machine isn't set up properly to receive these fierys. Just make sure all connections are secure, if not try other cables.
Jan 18, 2009 | Xerox DocuColor 12 Color Copier
Docucolor 12 Not Printing with another Fiery
could be a few things, the ips pwb in the machine might be faulty, which can cause these types of issues, a driver issue woth the video boards on the fiery, or other pwbs on the machine itself. You would have to run the machine for a while on another fiery to make sure no other faults occur before condemning the machine or the fiery
Jan 17, 2009 | Xerox DocuColor 12 Color Copier
Fiery xp12 is loading without end
Have you checked the paper trays are filled and ready? Also unplug for a couple of min's and see if that clears the memory as it may be trying to forfill a print request the never compleated.... Had this happen a few times....
Hope this helps.....
Nov 03, 2008 | Xerox DocuColor 12 Printer
Xerox Fiery Xp12 - Problem (INVALID LICENCE) apears on the screen
You will need to use what came with your machine.
The note from Xerox states this.
NOTE: You will need the Fiery Restore / Update Server Software CD and the User Documentation v2.0 CD that came with your EX12 v2.0 Software
And here is the loading process
  1. Visually check to make sure the Fiery LCD is at the Idle screen before you proceed. This will make sure the Fiery is not in use.
  2. Insert the Fiery Restore / Update Server Software CD into the Fiery EX12.
  3. Press [Menu] button on the Fiery Server.
  4. Press the [Down arrow] button.
  5. Press the [Shut Down] button.
  6. Press the [Reboot System] button. The message 'Rebooting System' will display and disappear after a few moments. The Fiery Server will reboot and complete internal testing. The Restore / Update CD menu will be displayed.
    NOTE: Ignore the message 'It's now safe to power off the system'.
  7. Press the [Up arrow] or [Down arrow] button to scroll to 'Restore System' so this is highlighted. Press the [OK] button. The 'All data will be Deleted. Continue?' message will be displayed.
  8. Press the [Up arrow] or [Down arrow] button to scroll to 'Yes' so this is highlighted. Press the [OK] button. The 'Restoring System...' message will be displayed.
    NOTE: The System Restore will take approximately 7 minutes, during this time the message 'Restoring System...' will continue to be displayed.
  9. Press the [OK] button when the 'Restore Complete!' message is displayed.
  10. Press the [Up arrow] or [Down arrow] button to scroll to 'Exit' so this is highlighted. Press the [OK] button.
  11. Remove Fiery Restore / Update Server Software CD from the EX12.
  12. Power OFF the Fiery Server. The power switch is located on the rear of the server, above the power cord.
    NOTE: Wait 10 seconds before powering ON.
  13. Power ON the Fiery Server. The Fiery Server will boot and complete a self-test.
  14. The EX12 will prompt you to insert the User Documentation CD. Insert the CD and the Fiery will continue with the process. When the process is complete, the Fiery LCD will display the message 'Please remove CD'.
  15. Remove the User Documentation CD
  16. Power OFF the Fiery Server. The power switch is located on the rear of the server, above the power cord.
  17. Power ON the Fiery Server. The Fiery Server will boot and complete a self-test.
  18. Using the Configuration Report as reference, re-enter the network settings on the EX12.
  19. Install any required patches, as needed. Refer to the Updated Information section on the Configuration Report.
  20. If needed, restore any data that you previously archived. See the Related Items.
Jan 10, 2008 | Xerox DocuColor 12 Printer
Xerox DocuColor 12 Printer Logo
819 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
