Question about Dryers
I would like a diagram of a Kelvinator 439 dryer which would have been manufactured in the 70's or 80's. I have purchased a new belt but can't work out how the spring and pulley are attached.
  • 11 more comments
  • lncbain Oct 07, 2008
    I requested a diagram in relation to a Kelvinator clothes dryer but that is not what was sent to me. I need a diagram of how the lower pulley is connected to the bottom of the system along with the spring and the belt.
    Sure that solution that was posted has nice pictures of the pulley but it doesn't even mention the spring or how the pulley is attached and where it is attached. When the belt snaps it is obviously designed with the spring and the pulley to disengage for safety reasons so when I opened the dryer they obviously weren't in the positions they need to be and that is what I need to find out. How is the pulley ahich would include the spring attached to the Kelvinator dryer at the bottom near the motor. There are a couple of slits where it appears that the pulley slips into but when you attach the spring it pulls it straight out of the slits.
  • lncbain Oct 23, 2008
    Could someone please solve this problem. All of the diagrams that have been provided are of no use and I found them myself on the internet. I need to find out how the pulley including the belt is attached. I am not very happy.
    Scott that was not helpful. I am able to get inside the dryer but I do not know how the pulley system is attached to the dryer. Please advise I believe we need to find a diagram or video for a Kelvinator as stated.
    The diagram is not inside the appliance.
  • lncbain Oct 27, 2008
    Please supply a diagram of how the pulley is attached to the dryer.
    That is exactly the photo I need for a Kelvinator 439 model. It is similar but still a little different.
    wayneard - It appears to be the same as the one that has Kelvinator listed but this diagram still does not show me how to attach the pulley and spring to the dryer.
    electech1 - The digram second from the bottom appears to be the same set-up as mine but I need to know how to attach the pulley and spring to the dryer which is not shown on the diagram.
    This diagram is not helpful
    I have already pulled the dryer apart.
    electech1 - The model number is 5039-439-0
  • lncbain Oct 28, 2008
    that is a washing machine??????????????????
    Sergeant:
  • 306 Answers
    Genius:
  • 1,011 Answers
  • 958 Answers
if i may help, as you have stated that it is like the one in the kelvinator..
so here is the step by step procedure.
lay the belt on the drum and hanging near the motor.
now install the tensioner pulley on the motor as in the drawing.
then the spring should be pulling the bottom part of the tensioner towards the right.
then pull the pulley towards the right, the spring would be stretched, then put the belt under the motor pulley and on top of the tensioner pulley while being stretched to the right.
then slowly move the tensioner pulley to the left while the belt is on it's top.
then it will cathc the belt on top and make a tension out of it.
it is being pulled by the spring to hold it towards the left ( the pulley)
i hope that you can follow that.
tnx for using fixya,
drcool
Posted on Oct 27, 2008
    President:
  • 1,952 Answers
Sears has a good repair site on the web. The model number must be entered and it has good pictures. Bacically those belts went over the top of the drum to a spring loaded tensioner pully on the front bottom right side then up to the motor pully and back up the right side. Remove the front panel of the dryer with a yellow handle nut driver or 3/16 socket to access the belt.
  • 535 Answers
Here is the diagram of dayer
  • 905 Answers
Whats the model # ?
Posted on Oct 23, 2008
  • 6 more comments
  • jason Oct 23, 2008
    its like one of these two for that year
    thii is your type
    or if a modern type then this one
  • jason Oct 27, 2008
    the pully is attached to the motor and the spring is on the motor then the spring attaches to the pully pulling the pully toward the motors shaft
    I'll look for better illustration
    can you see the model # on the back off the dryer , not the model type but there is a model # somewhere on the back, I can't get illustrations without the model #
    EXAMPLE
    ok this is the best i could do in a hurry
    i have lokked and looked but your dryer is so old they don't have anything on it except parts
    if you upload pictures of the motor in the dryer and the pully and spring , then i can manipulate the pictures to show you how they go on
    otherwise there is no diagram available for that model as i'm sure you already have tried to search for one , so if you can upload pictures i can manipulate them to make them look like they are put together
    sorry , but i have been looking for a long time , but i can't find anything , again only thing i can do is manipulate some pictures
    electech
  • jason Oct 28, 2008
    do you see that the pully just hooks on to the motor , and the spring hooks to the end of the pully and then hooked to the bottom to pull tension on the belt
    without the belt in place the pully and spring will just be loose
  • jason Oct 29, 2008
    i believe you gave me a serial #
    the model # will start with letters
    President:
  • 1,901 Answers
How about this one:
    Sergeant:
  • 213 Answers
Dear sir you want to know how pulley was attached
  • Dryers Master
  • 13,433 Answers
The diagram is inside the appliance.
    Guru:
  • 558 Answers
You can watch out repairing video sequence of Kenmore Dryer if it help you out From you tube:
Let me know if it is helpful to you or not.
Posted on Oct 22, 2008
  • Puneet Jain
    Puneet Jain Oct 22, 2008
    You Tube Dryer Repair Video
  • Dryers Master
  • 19,396 Answers
Here is the belt routing:
Frigidaire - Franklin, Kelvinator belt routing ...
To find a complete disassembly diagram, enter model number here.
  • Dryers Master
  • 6,487 Answers
You may want to check this link and for a manual , just go to page 85 and check if that is the diagram that you're looking http://www.denek.com/diagramas/Lavadoras-y-Secadoras-de%20Importacion.pdf
Hope that helps.........
Posted on Oct 01, 2008
    Genius:
  • 3,422 Answers
Please click on the below link.All the steps are mentioned clearly with pics
http://repair2000.com/wpoolbelt.htm
Tip
Kelvinator Dryer Belt Diagrams and Replacement
Your dryer belt has broken and you have a new belt to install, but you do not know how to route the belt properly. Here are some pictures or diagrams to help you see how the belt needs to go. Of course the belt needs to go around the drum so that is not included.
The important part is the routing around the motor and the tensioner pulley.
!970- 1995 models use this diagram
Style: Flat with ribs
Installation Tips: Ribs face toward drum
1995 – present models use this diagram
Style: Flat belt
Installation Tips: Side of belt with words faces away from drum
on Mar 06, 2010 | Dryers
Frigidaire gallery heavy duty dryer
Good Afternoon Friend, thank you for your question!
I understand you are seeking a replacement dryer belt for your Frigidaire laundry center, GLET1031FS. The replacement dryer belt part number that you would need to order is 137292700.Most parts can be purchased directly from the manufacturer or through a parts distributor in your area (part numbers may vary based on distributor). Hope this helps! - Z
May 19, 2014 | Washing Machines
HOW TO FIT A DRUM BELT ON A TUMBLE DRYER KELVINATOR
Normally you loosen the bolts to the motor after fitting the belt around the drum. DON'T try to streach the belt to fit over the motor pullery.
Dec 19, 2011 | Dryers
We need to know where the tension pulley goes and we need a diagram to show us how it goes in
You can view an extensive list of dryer belt diagrams at the following website:
http://www.repairclinic.com/Dryer-Belt-Diagrams?red=Dryer-Repair-Help
The diagrams are listed by manufacturer and model. If you still need assistance in determing which diagram to use, please post back with your MODEL NUMBER and let me know. I hope you find this information helpful.
NOTE: If the link does not work for you, go to repairclinic.com and click on the "Get Repair Help" link at the top of the page. Select "Dryer", followed by the "Click here for belt installation diagram" link.
Nov 23, 2010 | Dryers
Need to replace dryer belt.
screw on bracket of motor for tentsion release
Jan 24, 2009 | Whirlpool LEW0050P Electric Dryer
I tryed fixing my kenmore dryer but the belt is loose and i found what looks like a half moon type of pully
If you are talking about the idler pulley, which isn't a pulley at all, it is highly recommended that you replace it with a standard idler pulley. This was orginally designed as an attempt to save money by the manufacturer, but turned out to cause premature belt wear in many cases. A replacement idler assembly (part number 691366) is a better option. As far as reinstalling the dryer belt, you can find diagrams at repairclinic.com under the "Special Features" section under "Repair Help". There is a link for "Dryer Belt Diagrams". Your dryer is manufactured by Whirlpool. Your diagram will be either "H" or "K" depending on how the dryer is constructed. If your dryer has a removeable back panel, use "H". If dryer does not have a removeable back panel, use "K". HINT: Most dryers with removeable backs have the lint screen on the top of the dryer. If you need additional assistance, please post back and let me know. I hope this helps you.
Jul 23, 2008 | Dryers
Kemore Dryer 11064602300 belt replacement
Go to repairclinic.com. Click on the "Repair Help" heading on the left-hand side of the screen. On the next page is a "Dryer Belt Diagrams" heading on the left hand side. Your dryer belt diagram will be either "H" or "K" listed under the Whirlpool section. Your Kenmore is manufactured by Whirlpool. I hope this helps you. Please post back if you need further assistance.
Jun 06, 2008 | Kenmore 62822 Electric Dryer
Dryers Logo
273 people viewed this question
Top Dryers Experts
