Question about HP PSC 1610 All-In-One InkJet Printer
Paper jam A 4x6 photo paper is jammed...cant reach it and cant get it to feed through!!!
    Novelist:
    Scholar:
  • 111 Answers
It's pretty rare to not be able to manually clear a paper jam. Occasionally, after you clear a jam, some paper gets stuck in the mechanism where your fingers can't reach. In that case, part of the printer mechanism needs to be taken apart to get to the jam. Like I said, it's pretty rare, but when it happens, your only option is to take the printer to a certified printer repair shop or back to the place where you bought it to get it worked on. Unless you know what you're doing, I wouldn't recommend using tools inside the printer yourself. You run the risk of damaging the mechanism and making your current problem worse.
The HP web site does publish a couple of solutions. Have a look at the information on the following two links and see if there's anything you may not have tried yet:
Clearing a Paper Jam
Clearing a Carriage Jam
Post back whether or not either of these links worked out for you. Good luck.
Posted on Oct 07, 2008
Repeat paper jam
there likely a jam in there your not seeing or feeling
Jan 26, 2013 | HiTi P510L Digital Photo Printer w/Breeze...
C5180 sounds like printing then jams
try aligning the heads, and cleaning ink cartridges
Nov 18, 2012 | HP Photosmart C5180 All-In-One InkJet...
I cant fix the paper jam problem. every time i take the paper jam out it jams again
I have had paper jams in five different places on this machine. It has jammed at the pickup point from the tray, in which case you have to remove the paper tray and pull the jammed paper out. It has jammed at the manual paper feed tray, in which case you just have to pull the jammed paper out of the feed rollers. It has jammed at the toner/drum, in which case you have to open the front cover and pull the toner cartridge out to remove the jam. It has jammed in the back of the machine where the paper feeds through to the output tray, in which case you have to open the small back panel and remove the paper. And it has jammed in the output rollers, in which case you have to reach inside the output tray and remove the paper. Then once the jam is cleared there are times when the machine has to be unplugged for up to 8 hours to reset before it will function properly.
Aug 16, 2010 | Brother MFC 8840D All-In-One Laser Printer
I put photo paper in the feeder but it won't feed.
check if cable between PC and printer is connected if not connect printer to PC cable........if cable is connected check if printer driver is connected if printer is not connected install drivers for printer into your computer.....if driver is installed do a clean up for your printer - check for any jammed paper, check rubber roller is grippable....etc..
Nov 05, 2009 | HP Photosmart C7280 Printer
Willl not feed 4X6 photo paper it jams up and
try feeding the paper in one sheet at a time.
Sep 14, 2009 | HP Office Equipment & Supplies
HP PSC 1610 All-In-One InkJet Printer Logo
136 people viewed this question
Ben Johnson
