Question about Xerox WorkCentre XL2120 Laser Printer
Troubleshooting with Xerox WorkCentre PE114_16_16e
My printer doesn't work at all; I got the message: Printer status error. I checked the cables USB Poort and electric, seems to be OK. Could somebody help me?
  • 79 Answers
Hi better u try just uninstall ur old print driver then reinstal again.. than u try.
Posted on Oct 01, 2008
When I start my hp psc2110 printer I hear a wonky repeating noise that sounds like my printer carriage is stuck or something and then the error message states "scanner failure"... Please align print...
First off all connection unplug printer power and USB cable. Some time wait and replug power first then wait any error show or not, if ok then USB cable connect. If same error show then i suggest you printer driver uninstalled and restart printer and PC. Some time wait and start both device and check it virus and removed it then you new fresh printer driver installed it. If you problem solved then ok, otherwise same issue USB cable so change USB cable.
I share a informative links please read it...
Print cartridge alignment failed Error Message Displays on the All in...
Thanks,
HP Phone Number
Jun 26, 2014 | HP PSC 2210 All-In-One InkJet Printer
Mfc7340 will not print--it was working just fine and then it errors out. Uninstalled and reinstalled and it shows ready but errors out
Hello ,
First, please make sure there is no error message displayed on the LCD screen of the printer
Now we will check the status of your printer in the printers menu in the control panel.
The printer’s status should be set to “ready”
If the printer is “paused” simply clear the print queue, right click on the printer and select “resume printing”.
If the printer says “offline”, follow these steps.
  1. Clear the printer queue
  2. Shut down the computer
  3. Unplug the USB cable from your computer and your printer
  4. Unplug the power cable from the printer and wait 15 seconds
  5. Plug the USB cable back into the printer and the computer.
  6. Plug the printer’s power cable back in.
  7. Turn your computer back on.
Your printer status should be back to ready now and you are able to print.
Thank you,
Mar 26, 2010 | Brother Office Equipment & Supplies
To my disappointment I called Hp and spoke with their technicians for the second time regarding Ink System failure 0xc18a0001? I reset the IDS by pushing the * and # key then hit 123 and I got the message...
Hi ok try I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Oct 10, 2009 | HP Photosmart C6180 All-In-One InkJet...
Hp printer stopped printing with a "usb" error 237
The remedy is to reinstall the driver for your operating system which will be available at the mfr support website.
Also check the status of the USB on your PC by looking at the device manager.
Oct 01, 2009 | Office Equipment & Supplies
Hp laserjet 5p will not print with new computer (Vista)
check cable for error take a other printer to try
mostaly if you connect usb in the usb port then it select the poort 1 or 2 or 3 and find the printer if you chanche it for a other poort it wil not see the printer
Sep 27, 2009 | HP LaserJet 5p Printer
OKI C3200, status monitor
Check our USB cable. It should contain AWG marking on it. Depending on AWG number there is a limit to USB cable length as follows:
28AWG = 0.81 m
26AWG = 1.31 m
24AWG = 2.08 m
22AWG = 3.33 m
20AWG = 5.00 m
Make sure your cable does not exceed the maximum length according to its marking. Replace the cable if it exceeds the length.
Jun 07, 2009 | OKI C3200 Led Printer
Printer not working
Hello Kathi1603,
Please try these few things to see if they will get your printer running again. First off, check to make sure your USB cable is properly connected at both the computer end and printer end. If that's OK..then power cycle the printer.. try to print a test page by going to the control panel from your start button and then select Printers and Faxes.. using the right mouse button for your printer, selcet Properties then pick 'print a test page' see if that works.. If that fails, then transfer the USB can;e to another USB port on your computer and retry all the previous things.. When all else fails, restart your computer and see if you can print a test page to your printer.. Hope this helps get you going..
Sep 28, 2008 | HP Photosmart C4280 Aio Printer
Can't print
is this connected with a usb cable? did you try checking the printer status under control panel? try to download a HP Printing Diagnostic utility from hp.com.
Jul 30, 2008 | HP PSC 2110 Color Printer
Error light and no printing
What does the status monitor message say? The red light is the most general error. It's bit like taking a 747 back to Boeing and saying there is something wrong with it.
If you do not have the status monitor installed, download it from Konica Minolta and run it. Once the status monitor is running it will read the error from the printer.
Sep 05, 2007 | Konica Minolta magicolor 2300DL Laser...
Xerox WorkCentre XL2120 Laser Printer Logo
894 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
