Question about Carrier 38CKC042 Air Conditioner
My digital thermostat has shut off after a power failure. There is absolutley no display appearing. I pulled the thermostat off thinking maybe the batteries were no longer working but came to find out that the thermostat does not have batteries. I then went and bought a brand new thermostat that does have batteries for the display but when I properly installed the new one, the display worked (of course because of the batteries) but niether the heater nor the airconditioner comes on when I tried to set the temperature to have it come on. I also tried the Fan On option and the Fan won't even come on. Of course before I went and bought the new thermostat I checked the breaker to the AC and turned it off for a few minutes but that didn't help and I also looked next to the actual unit outside and did find a box attached to the house and thought that should be the individual breaker for the unit but when I opened the box there was no lever to trip inside or on the side of the box, just a wierd looking black hook looking think that had ON, OFF on it.The only thing I could do with that is pull it straight out toward me and I turned it aroung in my hand and inside of it was like some metal prongs that locked it in from where I Pulled it out from. What else can I do or can you please tell me where I can find something I should trip (like a breaker) on the actual AC unit. HELP! Any suggestions? I am not sure of the unit model number because I am at work. I just picked on from the list. The unit is only 4 years old
  • roycasipit Oct 01, 2008
    I have the same problem. But now, my problem is locating the inside unit. Normally, how big is it? I opened up an air filter upstairs just to see if there's a way to access it but everything is completely walled up and sealed.
    Scholar:
  • 121 Answers
What you have is a 24v control circuit problem. There is a transformer in the air handler ( inside unit ) you will have 220v on the one side and 24v on the other. If you have 24v from transform there is a small fuse on the pc board that could blow during power problems. On the inside cover you should find a wiring diagram.
Posted on Oct 01, 2008
I have a HVAC thermostat that had "always-on" backlit display.It still works but the display goes off in a few seconds.How can it be fixed to always stay on?
If the display on your thermostat resembles the illustration, it is an LCD not backlit (as in TV). The reason the display turns off is to prevent premature failure.
Aug 10, 2016 | Honeywell TH5110D1006 Focus PRO 5000...
How to adjust oven controll to the right temp.
You may find that your new oven cooks differently than the one it replaced. Use your new oven for a few weeks to
become more familiar with it. If you still think your new oven is too hot or too cold, you can adjust the thermostat yourself.
Do not use thermometers, such as those found in grocery stores, to check the temperature setting of your oven.
These thermometers may vary 20-40 degrees.
NOTE: This adjustment will not affect the broiling or the self-cleaning temperatures. The adjustment will be retained
in memory after a power failure.
Adjust the oven thermostat-Do it yourself!
To Adjust the Thermostat
Touch the BAKEand BROIL HI/LOpads
at the same time for 2 seconds until
the display shows SF.
Touch the BAKEpad. A two digit
number shows in the display.
The oven temperature can be adjusted
up to (+) 35°F hotter or (-) 35°F
cooler. Touch the + pad to increase the
temperature in 1 degree increments.
Touch the - pad to decrease the
When you have made the adjustment,
touch the START/ON pad to go back to
the time of day display. Use your oven
as you would normally.
or self-cleaning temperatures. It will be retained
Dec 02, 2014 | Hotpoint RGB745 Gas Kitchen Range
MY SHARP AR-5316E DISPLAYS H4 AND IS NOT WORKING
Dear friendscom, H4 :Heat roller abnormally low temperature.
__ possible cause __
  • Thermistor failure
  • Heater lamp failure
  • Thermostat failure
Perform the following procedure to reset the code:-
"#" key-- Interrupt key-- "C" key --Interrupt key--14--print
Jan 12, 2011 | Sharp AR-5316 Advanced Digital Imager...
Showing a LP on display. What are the possible problems?
Here is the reason for that problem per the manufaturers web-site
http://www.haywardnet.com/products/Manuals/pdfs/Manual122.pdf
The low-pressure switch senses the refrigerant pressure in the sealed refrigeration system to
protect against certain conditions that could be detrimental to compressor life. The switch shuts
the unit down in the event of loss of refrigerant, fan motor failure, evaporator freeze-up and
airflow blockage. The switch automatically resets when the pressure rises to normal operating
pressures. The display will show "LP" if this switch is tripped.
Evaporator Freezing
The low-pressure switch will shut the heat pump down when the evaporator starts to freeze.
When the unit starts to freeze the low-pressure switch will be tripped, causing the display to read
"LP" This will prevent the evaporator from becoming damaged or deformed.
If the air outside the heat pump is not warm enough to produce heat, the system will shut down.
The actual point at which your unit will shut down due to low temperature varies depending on
which model you purchased, current weather conditions, and the amount of sunlight reaching the
heat pump. The shutdown can occur anywhere within a wide range of temperatures, usually 45°F-
55°F. This is not a "fixed" range. We stress that climate conditions, sunlight, and various models
respond quite differently to low ambient temperature. A shutdown occurs because low
temperatures will activate the systems low-pressure safeguard switch (digital thermostats will
display a code "LP".) The unit will start up again when the temperature has raised enough to reset
this switch. Note: Low ambient temperature does not necessarily affect the Chiller models
or the cooling cycle of the heat/cool units.
If this post has helped you, please take the time to vote positively for me on this site. If you need additional help, I can be reached @: adamh@newconceptchem.com
thanks,
adam
Oct 23, 2010 | Hayward Heatpro 81k Btu Swimming Pool Heat...
KitchenAidKEBS107: NO HEAT after power failure during self clean
Thermostat on the back needs replacement. The problem is caused by overheating the oven. Improper installation or inadequate blower. Depending on the model, the oven might need a new blower in addition to the thermostat. Try calling KitchenAid to find out if the oven needs that blower and get the part number for the thermostat, they might have replaced it with the one with higher temperature rating.
Nov 26, 2009 | KitchenAid KEBS177 Electric Single Oven
Stopped working halfway through playing a disc .absolutely dead now no display
if the unit is absolutley dead, nothing no go what so ever, my advice is check out the power supply.
Jul 06, 2009 | Cyberhome DVR 1600 DVD Recorder
Dryer shuts off, no heat, AD code
During normal operation, the display may show: “ad” - dryer is in an auto dry cycle. “dn” - cycle is done in auto dry. “PF” - a power failure to the board has occurred. “Err” - an error has been detected. “LOC” - control lock is activated. “PAU” - cycle has been interrupted.
Jun 18, 2009 | Frigidaire Affinity ATF7000ES Front Load...
My digital thermostat has shut off after a power failure. There is absolutley no display appearing. I pulled the thermostat off thinking maybe the batteries were no longer working but came to find out that...
You have to realize there are three components to the electrical supply... 1. power to the outside condensing/compressor unit-you found the service disconnect at the unit. Make sure that you put the black thing back in the slot with ON reading up. OFF up means the prongs do not connect the unit with the current. In order to confirm that you have power at the outside unit use a voltage tester. If no voltage, check the breaker on the panel in you residence (probably labeled AC). 2. Power to the inside blower/furnace--again this is in the residential circuit panel. COnfirm voltage at the unit with a voltage tester. 3. Power to the thermostat system usually 24 volts run through a transformer that may be attached inside the blower unit or may be seperate and attached to an outlet. Again you need to confirm that this transformer is working with a voltage tester (you should have 24 vdc on the out side of the transformer). Assuming you have power to all three components, the system should work normally. If not, send pictures of the wiring to your termostat...
Oct 01, 2008 | Air Tools & Compressors
My canon power shot A720 IS won't turn on...
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
May 17, 2008 | Canon PowerShot A700 Digital Camera
Carrier 38CKC042 Air Conditioner Logo
209 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
