Question about Whirlpool Heating & Cooling
Air conditioner motor
We just moved into a older house built back in 97 the air conditioner unit is a whirlpool unit and up to this point we have had no problems with it. now all of a sudden we turn down the air and the outside unit wont work i can her it turning on but the big fan on top of it wont spin. and while the unit is on it gets hot but the fan wont spin i press the red reset button and nothing happens what should i do my wife and i dont have a whole lot of money.
    Scholar:
  • 121 Answers
Your condenser fan costs less an $100 if you install it yourself. First with the system on and calling for cooling take a screw driver and spin the fan blade. If the fan comes on then it has a bad bearing, if it doesn't it's electrical. With power off remove the access panel and inspect the wiring etc.. Possible run capacitor.
Posted on Oct 01, 2008
I have Whirlpool window unit ACM082PR2. Water is draining into the house. The unit is level. I don't what to do to get to stop draining in the house. Bruce Hansen
Hello, you want the unit tilted back in the window somewhat, the unit should not be level because this will cause the wateR to settle in the front of the unit and drip. Also, if the unit has a drain plug remove it so the water can drain out of the unit.
Jun 16, 2011 | Whirlpool ACM082 Air Conditioner
Unit will only hum and won't start up on its own unless I spin the squirrel cage ( with unit off ) by hand. After spinning cage for varying amounts of time it will free up the resistance and I will turn...
The motor needs the bearing oiled...to do this you will need to get a bottle of oil at your local HVAC supply house that has a long pull out spout on it... then place a few drops of oil on the shaft by the motor... if possible then tilt the unit so that the oil will run back the shaft and then get the motor to run... the oil will work its self into the bearing...this will lube the bearings and free them up... you will have to do this for both sides of the motor...
If the motor has little tubes sticking out also place a few drops of oil in each tube...
heatman101
Apr 23, 2011 | Whirlpool ACQ122XK Air Conditioner
The outside unit of a whole house air conditioner
replace start run capacitor of motor fan
Aug 17, 2009 | Heating & Cooling
Whirlpool window air conditioner 20000 btu's not cooling properly
It is possible the cover needs removed and the condenser coils are in need of a good cleaning. (the one in the back that is outside).This assuming the compressor is running and it has not developed a leak and lost the coolant charge. Eric
Aug 15, 2009 | Whirlpool ACQ158XP Wall/Window Air...
Air conditioner comes on but nothing moves
Take the front cover off..
Inside you will see a barell fan..
Turn the unit on and give the fan a good spin by hand.. If it comes back on - the fan was stuck.. And is a sign of the fan motor on is way out - or maybe a bad capasitor.. If the fan does not come back on - the fan motor could be bad or maybe the capasitor..
Note;
Thank you for posting your question on FixYa.com
We are helping people on a points system.
If the information provided here was at all helpful,
please be kind - rate well and close the post.
Thank you – and enjoy your day ;o)
Aug 04, 2009 | GE AJCH10ACB Built-In Room Air Cool Unit
Does not cool ?
there are 3 possiblities
  1. something obstructing the lower fan motor (or exhaust motor)
  2. bad fan capacitor
  3. or bad motor
to check any of these you will need to disassemble the unit to get to the blower. there are several screws located at various points on the plastic housing covering the unit. Once removed you should be able to check for motor obstructions visually. for checking the motor and capacitor you will need a volt/ohm meter and ideally a capacitor checker. you could try to spin start the motor while it is powered up this could be a possible sign of a bad capacitor if it will start when you do this or if the motor will spin freely while powered down and will not spin start when powered up. I know that is kind of confusing but its how they work.
regards
Jul 13, 2009 | Whirlpool ACQ088 Air Conditioner
Acq158xpo whirlpool window ac power on unit humms
hello there!
well,humming that's the motor stuck up,it can't start up,the running winding of motor has built up current because it can't move on,the start winding is not wotking,check starting capacitor ,using multi tester have set to RX100 test rod on both terminal pointer will deflect to "o"reading,then reverse the test rod on terminal of capacitor this will deflect also to "0" but gradually go back to original position at high value.if this happen your capacitor is good.but if not deflect.defective capacitor,replace defective capacitor,
if capacitor is good,check relay coil,or check motor starting winding resistance,if you get high resistance more than 100 ohms
you motor is defective replace motor,
have a nice day,don't forget to rate me,thank's a lot
Apr 28, 2009 | Whirlpool ACQ158XP Wall/Window Air...
Whirlpool portable AC, compressor works, but no exhaust fan
  3. or bad motor
to check any of these you will need to disassemble the unit to get to the blower. there are several screws located at various points on the plastic housing covering the unit. Once removed you should be able to check for motor obstructions visually. for checking the motor and capacitor you will need a volt/ohm meter and ideally a capacitor checker. you could try to spin start the motor while it is powered up this could be a possible sign of a bad capacitor if it will start when you do this or if the motor will spin freely while powered down and will not spin start when powered up. I know that is kind of confusing but its how they work. GO FIGURE.  thanks Peyton
Mar 15, 2009 | Whirlpool ACP102PS Portable Air...
WHIRLPOOL 2 TON CONDENSING UNIT
check wiring for condensor fan motor,make sure wire nuts and connections are tight,if still no luck then i'm afraid you have a bad condensor fan motor
Nov 08, 2008 | Whirlpool Heating & Cooling
Heating & Cooling Logo
106 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
