My Cytron laptop keeps switching off due to overheating, then when I switch it back on its ok
  • 67 Answers
Do not obstruct the exhaust of the laptop. If problem persist, try a laptop cooler.
Posted on Oct 01, 2008
Bike shuts off while riding
I would suggest the ignition switch is defective, examine the connecter to the switch for signs of overheating of the plastic connector shell and wire connectors inside the shell, if it shiows signs of heat then replace the connector and the switch. If the connector is ok then replace the switch itself. You may need to find the connector in a salavage yard or check with the delaer.
Oct 07, 2014 | 2001 Suzuki SV 650 S
HP laptop will not switch on. I recently had the screen changed on the laptop due to vertical lines showing on the screen, and managed to resolve that problem, but this led to the problem with the laptop...
my bet is overheating too.
you have to take a look to the cooler, dust can block the air flow. bad news is you will need to open the laptop to be able to clean it. also, the overheating problem may lead to motherboard problems..
Sep 18, 2011 | HP Pavilion zd8000 Notebook
Brother MFC 465CN won't print due to "Unable to
Hi Good day!! try this method
1.pull out the AC plug
2.put back the AC plug while holding down the "menu" button and keep holding it (15 sec)
3.now you are entering the MAINTENANCE mode and "error 46" pops up in the display
4.select 8 by using the arrow buttons ,push OK and select 0 and push OK
5.00:00 00:01 OK (the display is showing this message)
6.now push the MONO button 25 times until you see PURGE: xxxxx
7.Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
8.the purge counter indicates now: purge: 00000
9.switch off the printer ,switch it on
ready to print
Nov 19, 2010 | Brother Office Equipment & Supplies
I have a ACER 5735 . The laptop shuts down suddenly while its on and sometimes im not able to switch on the laptop and even if i switch on , then once again the power goes off immediately . What would be...
The reason for the sudden shut down of your computer is because of overheating of the 'case', where the CPU is mounted. Overheating can be due to dust accumulation on the heat sink, which prevents dissipation of heat. The possible solution to combat overheating issue is to keep the laptop dust free by cleaning out debris at the vents frequently. Note that a laptop has a much smaller cooling area in comparison with desktops and hence laptops tend to accumulate dust a lot quicker than desktops. This is because all the dust/debris, in the case of laptops, accumulate in the cooling fins.
Get more information to fix Acer shut down issue :
http://supportforacer.iyogi.com/aspire/shut-down-2.html
Hope this information helps you.
Aug 28, 2010 | Computers & Internet
This ge model aew10ajs1 keeps shuting off an doing its owen thing i checked for loose wires an the outlet is good the coil is a little dirty but not bad
the motor may be overheating due to a clogged filter. there are temperature switches in them that are safety switches in them to keep them from catching fire.
Aug 12, 2010 | GE Vacuums
My laptop takes a number of attmpts to switch on!!
Sounds like it may either be your motherboard or your RAM. I would suggest reinstalling the OS or resetting the machine back to the factory state. If it does not solve your problem then you have to consider the possibility that it is the hardware which is having issues. You may have to send it in to Packard if reinstalling the OS does not work.
May 21, 2010 | Computers & Internet
Hi, i currently have 2 faulty laptops with the same problem, when you try to switch them on theres no power, but if i leave the laptop for a few days it will come back on no problem last a few hrs or so...
Do the fans kick in when the machines are working? First thought is overheating problem, could be due to fans not working correctly or dust, and if it is maybe need to re-apply thermal compound to cpu (arctic silver).
hope this helps get back to me if i can help further
Oct 29, 2009 | ASUS Computers & Internet
Fujitsu siemens notebook s6120 laptop switching itself off
the processor fan might not be working due to which the laptop gets heated up and switches off. if u dont replace it u might end up burning the processor.
May 17, 2009 | Fujitsu Siemens LIFEBOOK S-6120 PC...
My laptop keeps freezing and it gets slow sometimes and i cant even play my music or look at my movies
thats because of overheating your laptop can become slow.....due to this only you cant play music or movies....due to overheating your computer may be overloaded and due to this your laptop will be hanged.....the solution is.... you should increase the speed of the ram or you should increase the processor speed of your laptop.....these ways you can solve the problem on your laptop.....for that you have to buy a new ram or processor....and fit it.....if you dunno how to fit.....where you buy itself ok.....there shop guys will fit it for you.....dont worry..... this will give 100% solution....because i am a software engineer and i used to it....try this.....
Sep 18, 2008 | Computers & Internet
KEEPS SWITCHING OFF AFTER ABOUT HALF HOUR OK WHEN YOU SWITCH BACK ON HAVE CHECKED TIMER THAT IS OFF
This may be an overheating problem.
Place a large floor fan so it will blow into the back of the tv.
If the tv stays on longer or stays on all the time after that.
If it is an over heating problem, then you may have transformer flyback that needs replacement.
Jun 12, 2008 | Samsung Televison & Video
Computers & Internet Logo
97 people viewed this question
David Payne
David Payne
