Question about Krups Small Appliances Espresso Machine
XP7240 has stopped ectracting milk from canister,just blows steam
Hi, my Krups machine does not extract the milk from the canister anymore, it just blows steam out the nozzle. First it started extracting the milk, but it came out boiling hot with no foam.Now it does not **** the milk out at all, only blows steam. Any possible solution please? Thanks very much
  • 5 Answers
Do not push steam nozzle to much on the dispenser. Just pull it back 1mm or something. If pushed to the end there is no ejection and milk is not extraced fro the canister.
Posted on Aug 07, 2009
Steam nozzle attachment
stop looking, it works better without it!
Nov 14, 2011 | Krups Gusto 880-42 Espresso Machine
I have a Krups coffee/espresso maker, with a milk steamer. It makes great coffee and espresso; however, the steamer is not working. It is not clogged; I cleaned the handle with a fine needle, and water...
There must be a blockage in that steam pipe, I think you need to dismantle the machine and remove all of the steamer parts off the boiler and look for the cause of the problem. Oftentimes it will be old hard milk that has been drawn up the pipe and gone hard from the heat. Once cleaned out prevention by blowing a large amount of extra steam through it after each use is the solution.
Apr 22, 2017 | Krups Gusto 880-42 Espresso Machine
KRUPS XP7240 leaking water
My XP7240 has the same problem. I went through all cleaning cycles and the filter in the boiler still gets clogged up with coffee oils. This causes back pressure and blows the boiler seal out. Easy replacement if you can turn a screw driver.
Part number for Seal: MS-5015004. You might as well change the Jack too. (the part that slides into the boiler that compresses the ground coffee. (this is a redesigned double seal unit) Part Number MS-0697072.
Both these parts you can get at http://www.krups.com/Tools/Contact/Contact.htm choose your country and email the parts list. Mine cost in Australia $27.00 including shipping.
Good luck.
May 31, 2010 | Krups Small Appliances Espresso Machine
My milk steamer is no longer steaming. Some steam comes out but not enough to steam the milk. The expresso part is working fine as I recently used a Krups descaling kit on it.
From your message that it is clear that the steam is coming but it is not sufficient to heat the milk, so kindly call the customer care to sort the problem as you can't do it
Thank you.
May 08, 2010 | Krups XP4030 Espresso Machine
Frothing
You should try to hold the steam end half a centimeter lower the top surface of the milk and try to have it with a slight angle in the pot with milk and near to side of the milk pot about 1 centimeter. If the steam end goes very near to the top surface of milk and for seconds goes above and then back into milk this can create the bigger bubles foam milk.. So with a very steady hand you can create very nice smooth foam. Also remeber that should stop heating anymore the milk after 72 degrees selcius the point at which you can not leave your hand out on the pot for more one second this point you must stop. After the 72 to 75 degress you could burn the milk protein and any foam already created will desapear just like that.
Try also in youtube "milk frothing" and you find many videos on how to do it.
Good luck.
Remember top vote for this answer
Mar 09, 2010 | Coffee Makers & Espresso Machines
Krups xp7230, no water running through nozzles
Yes, you're machine is identical to the xp7240. Look up the post on leaking xp7240 and follow the instructions on how to open the machine and fix the valve.
Jan 06, 2009 | Krups XP7230 Compact Super Automatic...
Steam Nozzle
I've only had it fly off once.  I think I didn't put it all the way on.  Also make sure you clean the nozzle every time you use the steamer.  Milk will clog the nozzle otherwise.  My maker is right beside the sink and I rinse the nozzle immediately after steaming milk.  I also run it through the dishwasher at least weekly.  (This isn't a substitute for immediate clearing of the nozzle.)   A clogged nozzle will always blow off the end.
Aug 12, 2008 | Krups XP4030 Espresso Machine
Hi, we have a Krups espresso machine, model fnd1. We can't seem to make the milk steamer work, it will make the milk REALLY hot, but not foamy. Do you replenish the steam supply somewhere? Is there a...
suggestions include very cold milk.  having the nozzle just barely in for frothing.
On my model there's an air passage in the nozzle that foams quite nicely.  If you have that too, it might be clogged with milk.  You have to keep these clean with every use.
Jul 11, 2008 | Krups XP4030 Espresso Machine
Krups FND1 water escape
What position do you have the knob in? According to your manul it should be in position 9 not in position 8 for steaming.Good Luck.
Apr 11, 2008 | Coffee Makers & Espresso Machines
Krups Small Appliances Espresso Machine Logo
160 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
cyfred
Level 1 Expert
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
