Question about Coleman Mach 15 Air Conditioner
Coleman rv a/c
My a/c works fine unless it's HOT outside. It will run great for 1/2 to 1 hour, or until the compressor cycles off. When it stops running, it suddenly slows down, dragging the power with it until a breaker trips or I turn it off first. Then it will not restart for a half-hour or so. I can hear the compressor humming, cycling, trying to start, but it will not start. Problem happens in both high or low cool settings. Works fine in cooler temps. Blower fan runs normally at all times. I'm no a/c expert, but it acts like the compressor is building too much head pressure. Suggestions??
    New Friend:
Sounds like compressor is overheated may to add freon
Posted on Oct 18, 2013
    Scholar:
  • 121 Answers
It is definitely with the compressor. It should more like you may have a weak winding in the compressor, you can a hard start capacitor (sp5 ) that will help the compressor on restart. Note that this is a last chance solution for a compressor.
Posted on Oct 01, 2008
Coleman 8000 compressor only comes on and cools when cool outside like in Am or late pm
Clean the coil inside and outside. try putting it in a window on a shady side of the house. I worked on a outside unit wher it was 90degrees outside but 107 degrees where it was in a hot location, close to road on sunny side of house.
Jul 28, 2012 | Dometic Rooftop RV Air Conditioner
Compressor stops running and keeps cycling every few minutes. It buzzes as if the compressor is gone. the compressor is hot. If the thermostat is turned to off for 6 to 8 hours and then turned back on the...
you can replace the relay with a 3 in 1 made by supco. i generally just use a supco 0410.
www.supco.com
it is a start relay, overload, and start capacitor all in one. works great for residential systems.
Nov 06, 2009 | Frigidaire FRS3R5EMB Side by Side...
Compressor on my RV coleman ac unit bogging down
Take a look at your start capacitor. This the capacitor that kicks the compressor over when it tries to start. If the capacitor is bad, it cannot kick the compressor back over after the first cycle because the head pressure has not evened out yet. It is located in the upper unit on the side panel in a small box. Be careful, highly charged capacitors can zap you if you are not careful. Disconnect power and touch across the terminals with a meter or a screwdriver to discharge the capacitor.
Hope this helps,
Jeff
Jun 29, 2009 | Coleman Mach 15 Air Conditioner
Fan stops
The cooling fan for the condenser is probably running, getting hot and seizing up. Check to see if the fan is free spinning after it stops. Take a probe and try to spin it manually. If it turns freely, then it could be going bad with it's electrical windings, the internal coils that create the magnetic field that spins the rotor of the fan motor. I suspect it is seizing up, however, once a fan seizes up, it usually stays that way and won't spin even after it cools down. It could be a capacitor that is going bad and not starting the fan after it gets hot. A capacitor is a small round shaped can type with usually 2 wires hooked in series with the motor it is trying to start. That is what it does, help start the device (compressor or fan motor). Good luck.Ken from Henderson NV.
May 30, 2009 | Dometic Rooftop RV Air Conditioner
Compressor will not come on. Fan runs great.
I fixed it. I had a dirty connection on the starter relay for the compressor. Thanks again for the help.
May 17, 2009 | Dometic Rooftop RV Air Conditioner
Ac compressor does not turn on when car has been sitting & it's hot outside. Works fine in the morning.
either the freon charge is about 1/3 low, or the expansion valve needs to be replaced. Freon is getting into the evaporator, but not in great enough volume to cool the air unless it is coming in cool to start with. check your ac charge, and if it is full, then have it emptied, change out the expansion valve, and recharge it
May 14, 2009 | 2002 Jaguar S-Type
Coleman tsr mach 3 RV Air Conditioner
I don't think you need a new one just a good cleaning and service. The unit has a liquid high temperature line near the compressor with a fan blowing outside air across it this coil gets clogged over time with air-borne dirt and pollen and leaves and such and must be cleaned regularly or the unit will be unable to remove the heat from the coil and during the peak demand (3pm) the circuits that protect the compressor and the trailer wiring from being overloaded and burning or melting will trip. From what you have described it sounds like the RV is working as it should with a condenser coil that needs to be cleaned. GL and happy camping!
P.S. I've only serviced the occasional RV unit but in those cases I laid a piece of plywood on top of the Rv for work platform removed the retaining screws from the top cover and used a spray bottle with a good heavy foaming cleaner a shop-vac and a brush to get the job done.
Jun 11, 2008 | Heating & Cooling
Coleman rv roof air conditioner
(1)Check compressor contactor or relay if it stock in the close position
(2)Check for welded contact points
(3)Check switch control for defect
(4) Check if compressor contactor still geting power when it is off
Let me know what works for you.
Mar 30, 2008 | Heating & Cooling
Coleman Mach 15 Air Conditioner Logo
504 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
