Question about Handmark Software Pocket Money V2.1 (new 140/old 150) for Mac, PC
E check register for Blackberry
On 9/28/08 I purchased online "echeckregister" for my Blackberry 8330 for $9.99. I received a text link which I downloaded, but kept getting a message stating that the download failed, along with a message reading: "907 Invalid COD, a network error occurred". I called Blackberry, who told me that I would have to contact Handmark support to correct this problem. Thus this message. My email address is rcrane@caseyciklin.com and my Blackberry cell phone no. is 561-352-1048. I would appreciate any assistance you can kindly provide to me. Please contact me.
Thank you, Robert Crane.
Some text messages not coming through on blackberry bold
Firstly, I suggest you do a battery pull. A battery pull fixes everything with a BlackBerry.
If that doesn't work, you need to go to Options, Advanced Options and Host Routing Table.
Then press the BlackBerry button and select register.
This will register your device with your network and should push through your text messages again.
Mar 12, 2011 | RIM BlackBerry Bold Smartphone
Blackberry 8320 keeps resetting - get "your handheld has been registered... message"
HI,
In your initial sync window in Desktop Manager, UNcheck the box that states something like "Update time and date on sync"
Sep 12, 2008 | AT&T Blackberry Curve 8300 Smartphone
Outgoing SMS Text Problems
check the blackberry fqa.com you will find your answer easy
Jun 01, 2009 | RIM BlackBerry Storm 9530 Smartphone
Using bb7520 for Boost mobile how can i get it to text?
At this time, you cannot. There are workarounds online for receiving text through email, but you cannot at this time text on Boostberrys. Search online at google by typing in boostberry and there are a ton of sites that have tips and ideas.
May 22, 2009 | RIM BlackBerry 7520 Handheld
I need a copy of the manual for my blackberry 8703e smartphone
I have provide a link to easy access the manual and you can save the manual from the adobe reader to your computer to access it later.
please make sure you have adobe reader installed before viewing the manual.
Here is the link:
http://www.sprint.com/cdma/assets/pdfs/phone_guides/blackberry/8703e_ug.pdf
Mar 22, 2009 | RIM BlackBerry 8703e Smartphone
Blackberry curve 8330's blocking mobile network
Sounds like you're in a dead zone. If not then ...
Check in the upper left corner... IF:
1x = you are not connected to any data at all - No emails, text, internet will work send/receive.
1xev= you're connected to data but not blackberry usually the same as above though sometimes you might get lucky and receive only text/pix messages.
1X= Phone calls only. Usually no data (email, text, web, etc)
1XEV = everything is connected and you should be working fine.
If you have 1XEV (upper case and lower case matter ALOT...everything should always be UPPERCASE) and you're still having that problem then go to:
options> advanced options> host routing table
In the host routing table click the button to the left of the roll ball (called the blackberry button) and click on "Register now" and just leave the phone alone for a minute so it can register all your service books again. Then try the web again.
If all else fails pullthe battery and try again ..> Still no good? Call your carrier.
Hope this helps
Mar 16, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Can't send pictures!!
First, try performing a hard reset: remove the battery from the BlackBerry while it is still powered on. Leave it out for 30 seconds, then reinsert.
If that doesn't work you might try re-registering on the network. Go to Options > Advanced Options > Host Routing Table. Highlight a table, press the menu key, then select Register now.
Also, make sure that Browser Push is enabled. Go to Options > Advanced Options > Browser Push and make sure Enable Push, Enable MDS Push and Enable WAP Push are enabled.
Oct 02, 2008 | RIM BlackBerry Curve 8310 Smartphone
Phantom Phone Calls and Texts
Sounds like a software problem.
Upgrade your handset software and remove all applications during process so the upgrade replaces all existing apps with new ones.
Gadget
Aug 18, 2008 | RIM BlackBerry Pearl Smartphone
Wnt let me make a call out
It sounds like the device was originally activated and worked with a Blackberry enterprise Server, where the administrator had voice calls blocked for the users, so that they did not run up bills - in other words, it was programmed just to do email. If this is the situation, there may not be a solution available to you.
Call your phone carrier and ask them to help - make sure you have the correct "plan"...
Jan 26, 2008 | RIM BlackBerry 7290
Handmark Software Pocket Money V2.1 (new 140/old 150) for Mac, PC Logo
327 people viewed this question
Top Handmark Software Computers & Internet Experts
Laxman Bisht
Laxman Bisht
Alun Cox
Tarpan Shrivastava
Tarpan Shrivastava
Are you a Handmark Software Computer and Internet Expert? Answer questions, earn points and help others
