Question about Frigidaire PLEF398AC Electric Kitchen Range
Error code f9 on self cleaning range. - Frigidaire PLEF398AC Electric Kitchen Range
I get a f9 message when I turn my oven onto clean and then it shuts off and goes to clock...what's the problem
Posted on Oct 21, 2008
If it is a GE wall-mounted oven, check if your model and serial number are listed in the recent recall.
And consider yourself lucky that your oven actually shut down rather than catching your kitchen on fire, as mine did.
Lastly, I have to add that so far, GE customer service SUCKS.
Posted on Dec 16, 2008
Frigidaire gallery error code f9
How do I reset an F9 on Frigidaire oven? ' ShopYourWay
www.shopyourway.com > Manage My Life > Questions
Oct 26, 2009 - My Frigidaire oven, model feb24s5asb, door is locked and says f9. The door locked is beeping, I need code to know what the code means and how to unlock it.How do I reset an f9, door ... F-9 Error Possible causes: Door motor failure/jammed. Latch motor switch failure. ... Frigidaire Ovens Gallery 30 in.
F9 Error Code - Can't get it to stop beeping - Appliance Repair Forum
forum.appliancepartspros.com/.../400915-f9-error-code-cant-get-stop-be...
Jan 9, 2012 - 6 posts - ‎5 authors After that it flashed betwed F9 and dr and won't stop beeping. ... say that the last time I used the self clean, the dorr would not unlock and I got similar error codes. ...Frigidaire BFEF374EB1 Frigidaire Canada/electric Range Frigidaire Door Lock F9 error code and now F1
1 post
Dec 6, 2010
Frigidaire Door Lock and F9 error code
Jul 10, 2010
Frigidaire Error Code F20 - Upon Cleaning
Dec 3, 2008
Frigidaire error F-9
Feb 18, 2008
More results from forum.appliancepartspros.com
Oct 29, 2015 | Toaster Ovens
Frigidaire smooth top electric range flashes f9 after cleaning
The "F9" error code means the EOC (electronic oven control) has found the lock motor switches to be out of sequence or shorted.
Test switches and if there is nothing wrong then replace the EOC.
What is the model number?
Nov 28, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
I was baking at 350degrees. My oven turned itself off and the error code F9-3 is flashing. please assist if abe.
The F9-3 error code means that either of the two oven self clean latches is stuck so ya need to check and see in both ovens if their is something from obstructing the lacth
if you also get a F9-4 that would mean its just the lower oven
a F9-5 would be just the upper oven
but for the F9-3 it could be either oven
Aug 28, 2011 | Maytag MER6772 Gemini Electric Kitchen...
While self cleaning, we experienced a power surge. now the doors will not open and we can not get it to reset. F9-2 is the error message.
Hi happytrailri,
The F9-2 error code is a Latch, Unlock Upper. Check for obstruction in door lock mechanism.
Hope it helps.
Thank you for using FixYa.
(Positive feedback will be greatly appreciated.)
Jul 10, 2011 | Maytag MER6772 Gemini Electric Kitchen...
I got a F9-4 code for self cleaning
Hi szambarano,
The F9:-4 error code description is Latch Unlock Lower. Check for obstruction in door lock mechanism.
Hope it helps.
Apr 14, 2011 | Maytag MER6772 Gemini Electric Kitchen...
Self clean cvode F9
Hello there:
F9 Problem with door lock circuit such as pinched wire between Electronic Range Control (ERC) and door lock switch Check wiring and test operation of switch
replace parts as necessary
May 15, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore Electric Range model 790 has F9 & F1 code error
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Apr 20, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Frigidaire PLEF398AC Electric Kitchen Range Logo
539 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
