You mean the security unlock?Try default codes like 0000 or 1234.You mean the network unlock? I suggest you can approach Unlock-zone.com and specify the country,locked network.Based on the availability you can get the unlock code along with free unlock instructions for your Samsung A167.
To unlock your phone from INDONESIA network lock,you can use unlock code to unlock it.But you also need to specify the current network it is locked now correctly and IMEI also.Then get unlock code for your SAMSUNG A167 model phone at Unlocking4u.com and unlock it easily using the free unlocking instructions at Mobileunlockguide.com
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000
IF Problem not Solved So Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator Enter The Puk code and Yes Enter The pin code and Yes So Puk code Open and Problem will Quickly Solved
You can get the unlock code for your Samsung A167 from your service provider or from reliable online sites!!! I would suggest unlocking4u.com , here they provide accurate codes at reasonable price!!!
call your carrier. (at&t, verizon etc.) give them your imei number. you can find it under your phone battery on a sticker. it is 15 numbers long. call your carrier and give this code to a mobile customer care representative and they should give you a 8 digit subsidy unlock code. Then once you get your subsidy code power your phone off take the battery out along with the sim card, replace the battery but leave the sim card out and power the phone back on, then when it gets to the menu screen punch in #7465625*638* and after that last star put in the 8 digit subsidy code your carrier gave you and your phone should say network lock deactivated. hope this helps.
