Question about Siemens Efficient Networks SpeedStream 2623 (SS2623) Wireless Router
How do i change the WEP key or even view it?
Tried for sooo long, im not good with computers so a little help would be appreciated. I have a Siemens Speedstream and i cannot get my Wii to connect to the router that is supposedly emiting a wireless network. I neeed to change the WEP key but cannot access the Router options!!!!! I have tried many different things and cannot find a solution. HELP!
  • justsayNO Feb 20, 2009
    I've had several visits by the ISP Tech relating to Time Warner Internet Wireless Router "NETGEAR WGR614v6" which I use on both a Laptop and PC, both running WIN XP SP3. The last Technician set up a new WEP KEY that he said was more secure than my previous one. Since I'm in an Apartment Building, I find that there are up to twelve (12) other
    wireless networks in range of my WiFi. Recent Security hardware that I added indicates I get hacked everyday and I suspect that my WEP KEY has been compromised. I found out that the "cable guy" used a very simple, easy to guess, WEP KEY. How can I change it.
    Thank You
    Scholar:
  • 89 Answers
To access the SpeedStream 2623 management interface:
1. Open your Web browser and enter the SpeedStream IP address http://192.168.254.254 in the browser Address box. The SpeedStream 2623 will automatically switch to port 88 for management access.
2. On the Login Screen, enter admin in the Password box; then click Login to display the Status screen of the management interface.
3. Under Simple Setup , go to Wireless Settings - take note of the SSID (this is the name of your wireless network). By default the SSID is "SpeedStream".
4. Still under Simple Setup , go to Wireless Encryption:
Option 1:
A. On the Simple Setup > Wireless Encryption screen, select Automatically.
B. Enter a password or password phrase.
C. Click Generate.
D. Take note of Key 1. This is the key that you will have to use on the Wii to connect wirelessly.
E. Save Settings and Continue.
Option 2:
1. On the Simple Setup | Wireless Encryption screen, select Manually.
2. Enter a password or password phrase.
3. In the bottom half of the screen, select #1.
4. Enter five hexadecimal keys; e.g., a number or letter in the range of 0-9 or A-F.
5. Click Enter to save settings and continue.
You're done with the router. Go to the wireless settings of your Wii and configure it to connect to your wireless network. For a step by step instruction go to this site:
http://www.wiichat.com/nintendo-wii-online/5820-official-wii-wireless-internet-connection-guide.html
If you need further assistance, post a reply and I'll try to answer it ASAP.
Good luck and have a nice day!
Posted on Oct 01, 2008
I have a 2wire 1000SW router/modem connected by an ethernet cable to a Hewlett Packard media center PC running Windows Vista. The internet Wifi connectivity problem arose after I visited a best Western...
If you check your router you will find a reset button or a little hole in back insert pin in hole and press for 10 seconds your Moden should have reset now you will have to put in your login and password to access modem
Feb 28, 2017 | 2wire Computers & Internet
I had to reset my router and even reboot it because i couldn't get it to connect to my xbox. problem still hasn't worked. but now i cant even set up my wep key. it only has two options. the wep mode and...
Try cable connection, the X-Box will run better on online games anyway with cable connection.
WEP mode was obsolete years ago and represents a real security hazard.
Changing the router for a router with AES2 will enhance your security. Cable will make security better too.
Sep 08, 2017 | Toshiba WRC-1000 Router (PA3227C1ETC)
Im trying to change my wep key but its not reconising the old wep key code
to change the WEP key on the router , you will need to access the router set up.
For this you will need 1 computer online through the router.
You will need to connect the computer to the router with the ethernet cable.
Click Here for step by step solution
Nov 01, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How do i get my wep key
Option1:
You can find the WEP key of your Wireless network after login to the Router. The WEP key is saved in the Router. Check the User Guide of the Router for the instruction to login to your Router.
Option 2:
If you are using a Computer with your wireless network and if the Wireless Key (WEP key) is saved in the Computer than you can use any application like "Wireless Key Viewer" or SIW for view the saved WEP key in the Computer.
Good Luck!!!!!!!!!!!!!!!!!!!!!
Sep 21, 2009 | Computers & Internet
How do I find my wep key as I need this to connect my printer to my router in order to use this on my network
Option1:
You can find the WEP key of your Wireless networl after login to the Router. The WEP key is saved in the Router.
Option 2:
If you are using a Computer with your wireless network and if the Wirelees Key (WEP key) is saved in the Computer than you can use any application like "Wireless Key Viewer" or SIW for view the saved WEP key in the Computer.
Sep 15, 2009 | HP DesignJet T3100PS Clr Inkjet 44"...
Cant access internet siemens speedstream n6520
I solved this problem, by hitting the reset button on the bottom of the modem, now I have no problems
Jul 28, 2009 | Siemens SpeedStream 2624 Router...
Wireless internet connection issues
Verify you have the correct WEP key, if its wrong it will look like it's connected but not do anything, you could aslo try to connect via a cable into your router to confirm it works, if it does then you have a WEP key issue, if it doesnt then you need to dig a little deeper.
Mar 29, 2009 | Linksys Wireless-G Broadband Router
Wep key
Use a computer that is currently connected to the router. Open Internet Explorer and go to http://192.168.2.1 It will ask you for a user name and password that you created during set up. The password is blank by default. You are then logged into the router and can view or change the WEP key, or any other settings for the router.
Jun 01, 2008 | Dynex Computers & Internet
Siemens gigaset se587 wlan dsl wpa
You can try this link, this has a step by step instruction and screen shots as well. I hope this one helps.
http://portforward.com/english/routers/wireless/Siemens/Gigaset-SE587/wireless.htm
May 04, 2008 | 3Com 7760 (3CRWE776075US) 802.11a/b/g...
Siemens Efficient Networks SpeedStream 2623 (SS2623) Wireless Router Logo
2,119 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
